How to get better results when posting about problems
Before opening a new topic, please read:
  • Please help us to help you. If you cannot be bothered to spend even a little time in properly posting your question (it’s your issue - not ours), then you cannot expect that people - although good-willing - will bother to reply.
  • Please be aware that anyone that helps you here is volunteering their time, knowledge, and skill. No one is being paid to help you.
  • If you need help with how to do any of this please ask and someone here will walk you through it.
  • First of all please use “Search” function of the forum. Look if there is already any topic similar to yours.
  • Please read the Release Notes and Errata for your version of OMLx before reporting an issue. If you feel something should be added to these please report that.
  • Look at the Resources category (Resources Index): most of the more common questions are already answered there. You will find also detailed How-to.
  • Choose the proper category/section of the forum.
  • Choose a meaningful descriptive subject title (example: no: “Help me!”, “It’s broken”, etc.)
  • Posts like “Graphics broken” are useless unless you tell us what your graphic hardware is and what your graphic driver is. Again if you don’t know how to do this just ask us and someone will walk you through it.
  • Posts like “System broken after updates” are just as useless, unless you tell us what packages have been updated recently. Please attach the list of latest updates.
  • Tag your post with relevant information.
  • Write in correct language form. If you are not an English native, please check your text before posting by means of online translators. Or write in your language and then use a translator and post that. (May be helpful to mention you used a translator.)
  • If you are English native please write your text to be easily understandable by non-native English users. That means: use simple basic writing. Avoid slang, avoid idiomatic expressions unless you are sure they are actually worldwide recognized.
  • If console output is not in English preface commands with LC_ALL=C prefix - example:
    sudo LC_ALL=C dnf <your_command>
    This is because English is the common language used by all of our developers and package maintainers so this makes it easier for all to understand posted code.
  • Do not type in ALL CAPS, this is like shouting and perceived as rudeness.
  • Specify your OpenMandriva version in use (currently: Cooker, ROME/rolling, Rock/5.0 version/update channel) and the arch (x86_64, znver1, aarch64); whether in VirtualBox or on real hardware.
  • Specify your desktop environment: Plasma, LXQt, or other.
  • Be precise in description of your issue: explain exactly what happens, in which condition, and what instead is the expected result. If necessary, give steps to reproduce your issue. Give external links (other projects bug-trackers, upstream Erratas, FAQs, or How-tos, etc.) it you think they may be relevant.
  • Provide screenshots if relevant. (Use the upload icon with the up arrow.)
  • Provide logs and/or output of journalctl pertinent to issue. (journalctl is the system log.)
  • Provide output of command: inxi -Fz. (This provides hardware information.)
  • In order to get your problem solved you may be asked by the person/s who is willing to help to copy and paste the full console output.
    When we write ‘the full log’ we need the whole log. It means: starting from the command you typed (included) to the end. NOT just the part you assume is relevant to the case.
  • Post your code as code, (use the </> icon). Or if there is a lot of output (more than 20-30 lines) put the code in a .txt file and upload it with the upload (up arrow) icon. For really big files consider using Pastebin or a similar external service.
  • Depending on your experience, give as much additional technical information as you think may be relevant, such as hardware, version of software, logs etc. If you don’t know what or how to do, we’ll help.
  • Be patient, we are a small team, do our best. We may ask you for additional information, or give you actions to do.
  • If your problem is solved, please mark which reply solved the problem.
  • If you have found a solution on your own, please share it so that it will be available also for others at a later time.
  • Also please post a short note about how your problem has been resolved, which way you have found is the best among different solutions that may have been suggested. Again, this can be of great help to others afterwards.
  • To share knowledge is the basis of OpenMandriva and Open Source philosophy.
    We would not be here, each one with her/his/their know-how, if others had not shared their own knowledge earlier.
    You will soon find that it can be fun and gratifying, other than very much appreciated.
  • Be kind. Do not scrimp use of “Please” and “Thank you”. “Like” the posts to make people earn karma points in our forum instance. Make clear your appreciation for people who were dedicated in solving your issue. Courtesy never hurts.
  • FWIW: Other Linux distributions such as Arch Linux, Fedora, Gentoo, openSUSE, and Ubuntu all have some pretty good wikis and documentation.
We are not here to “RTFM (Read The Freaking Manual)” or do internet searches for you. If you are newbie we are happy to point you to links so you can RTFM for yourself and in the process learn something. Or we can help you get started with internet searches.
OM Welcome crashes debug
The Steam Client is crashing
OpenMandriva keeps freezing the whole machine
Howdy from Oklahoma
Rimuovere programmi inutilizzati di gnome
Remove gnome very old apps
How to switch to Plasma 6?
Backdoor in xz might affect cooker and rolling users. Update as soon as possible!
Message when I try to update with command line
Driver audio
Welcome to OpenMandriva forum
Skype not working (Solved)
Openmandriva lx 4.0 lx 4.1
Instrukcja openmandrivy 23,08 plazma
nVidia drivers available for OM Lx 4.1
Nothing provides libxslt needed by nordvpn-3.7.3-1.x86_64
Scanner requires root password
Problemas para instalar OpenMandriva 4.1
Plasma6 Wayland + Nvidia drivers Problem
Not working: Backlight screen brightness adjustement
OpenMandriva Lx rolling-slim-plasma6x11.x86_64 live boot errors
Odpowiedź dla polskiego użytkownika/Response to Polish user
Updates on Rock
Need Guidance as In what category should I post?
Cant upgrade OM Rome Plasma 6 (due to third party repo)
OnlyOffice Desktop Editors
Hello again - What has been happening in the meantime with OpenMandriva?
Corectrl is not start
F3d 2.2.1 -> 2.5.0
Malfunzionamento Nvidia sul portatile (schermata nera, switch dGPU / iGPU)
Repositories' mirrors not available
Nvidia Installation
Need to install 88x2bu rtl driver
Wysiwyg HTML editor
Finding and Downloading the iso is too complicated
I want to say Hi and have a question that does not fit anywhere else
Came here from Lunduke.com
Hi all, New to Open Mandriva
Desktop logs out to lock screen (nvidia)
*Working Solution* Niche Legacy Support for Broadcomm Wifi Cards
Realtek card support
Hello from Rhode Island
Crossover needs vte291, not avail on Rock
Rome Server Ryzen
Hello everyone! Came here after watching Luduke's video
Display issue when booting with HDMI present
Need help setting up hyprland
Freebasic package missing packages required to compile
Docking Station Recommendation
Are there sysvinit options for OpenMandriva?
Any interest in debuginfod services for automatic debug stuff downloading?
What to do if I used dnf update
Just curious about user ID
Bonjour la communauté!
Hp-setup for HP LaserJet Pro MFP 4101fdw Failures
A few words on OpenMandriva desktops editions
Installing specific 32-bit libs
Where to download ARM64/AARCH64 ISO
Ftrace support in default kernel
I'm A newcommer and I have successfully installed nvidia 470 driver
My first impression of OpenMandriva
Lutris error 256 in ge-proton on Far Cry 4
I think I ran into a problem with the kernel itself, and I don't know how to proceed
Feature request: secureboot
Documentation
Can't install fundamental libraries?
Where are i686 Repos?
Help installing linux kernel for surface
Framework 13 fingerprint scanner
Problem install kmail
Changes to grub2 not respected after updates
Hello, nice ta' meetcha!
Mullvad VPN
Looking for The right ROME Slim ISO
Boot stops on black screen - white cursor
AVIF format still unavailable w/codecs installed
Virt manager starts with error
No pdf manuals in Google search
I've found this fix works for me, can someone explain why?
Downloading extremely frustrating
How does one transfer apps from pop os to open mandriva?
Really tried
Trying to get an ISO but no ISO exists?
Clipboard is not functioning properly
Black Screen with blinking cursor apears 30 seconds after the desktop loads
Bluetooth Not Working - Beelink EQR
¿Es posible desinstalar Gnome?, ROME Xfce4
I can't uninstall any software on my system
Entire system broken along with dnf itself. Errors regarding libicu
Error in the "Getting Better Support" post?
How do I set up hibernate and sleep to work correctly?
Package 'kup' in rolling EXTRAS is missing dependency
Misc Questions
Thinking about switching to OpenMandriva
Install Wifi Driver Realtek rtl8821ce
KDE - DE is empty at startup after last update and removed unecessary packages
Upgrade Rock/5.0 to Rock/6.0 (April 23, 2025)
Yet Another new guy
Install abcde (a better cd encoder)
SDDM or Plasma6 desktop don't start
Flatseal not working (system pkg), Lutris side note, OM browsers digression?
Thumbnails Dolphin disappeared
Wayland causes CPU max, X11 works fine
I can’t install kwin-wayland
OM Welcome app crashes during first time live OM Plasma AMD Wayland evaluation
Microarchitecture support?
Basic package management for new users
How to enable and configure (basically) selinux in openmandriv rock 6 silm
I Need help with 5.1 suroundsound rome plasma slim
Install vulkan SDK on openmandriva Rock?
Support template in details
New User Hej from Denmark
Unable to start in live mode (VirtualBox)
Camera icon from gnome's screenshot menu doesn't appear
ROME 25.11 Update
ROME 25.11 Update
ROME major upgrade expected
Many questions, several bugs and a little feedback
X11 session randomly restarts after boot
Multiple annoying bugs
Open mandriva impressions and few others topics that don't fit / belong anywhere else
SDDM doesn't start X with -nolisten tcp?
Need help with ico changing an launching bat files
LOL after upgrade to om rc6 dnf is half broken (not complaining or seeking suport) its funny
OM doesn't boot after latest update
DSL connection is not working
[Poll] OMLx 4.0 wallpapers-extra theme
Newcomers Tips
Resources Index
About support category
Stampante Brother: pacchetto policycoreutils-python-utils mancante
To help with testing OMLx
Team Viewer
All OpenMandriva contributors are unpaid part time volunteers. There are no employees being paid to help you. All OpenMandriva contributors have more on our “To Do” and “Want To Do” lists than we can actually do. So when someone stops what they are doing to help a user with an issue that stops progress on other work that we are doing.
Because of this we won’t hesitate to ask users to do some work themselves to get an issue resolved. This means RTFM yourself and do your own internet searches.
So please go back to the first post in this thread and follow the suggestions as best you are capable.
