ROME major upgrade expected
BIG fat warning remind: (repeat never hurts and saves headaches)
2024-03-19T23:00:00Z
ROME users attention please:
The process to copy cooker repositories to rolling (ROME) started.
We’ll keep you informed when it will be the time to perform distro-sync again.
Stay tuned.
Because of the significant upgrade this time, please:
- read carefully the notes posted above in this same topic
- start the upgrade process from console command which can create the transaction full log, example
sudo dnf --refresh --allowerasing distro-sync 2>&1| tee dsync-log.txt
Properly report issues
Should you encounter any problem, console displaying conflicts errors or any weird message hold on trying to upgrade; open a new topic with a descriptive title in Support category and attach the full dsync-log.txt file. Not an excerpt, not a summary, not what you think is relevant. The full log means all the log :wink:
Chance are that the testers already faced the issue and found a fix or a workaround.
Depending on installed packages, it may also be necessary to temporarily remove the falkon-kde package, because falkon is moving to the Plasma 6 version even on systems using Plasma 5 desktops – the Qt5 version of QtWebEngine is just too far behind to be useful anymore.
sudo dnf remove falkon-kde
Take this quote seriously folks.
We are close to giving the OK to proceed but we are not there yet.
Upgrading/distro-sync ROME (2024-04-20)
2024-04-18T22:00:00Z
The process to copy cooker repositories to rolling (ROME) started again.
We suggest to not update the system or install software until we communicate that you can safely perform distro-sync.
Stay tuned.
2024-04-20T00:00:00Z
OK should be safe to dsync or distro-sync your ROME/rollling system following instructions here.
2024-05-19T22:00:00Z
Instructions will follow. Stay tuned.
2024-05-21T22:00:00Z
Process finished.
Please read detailed instructions HERE.
See also (use a translator if needed)
Aggiornamenti di maggio 2024
2024-06-01T22:00:00Z
2024-06-02T22:00:00Z
Process finished.
It should be safe to distro-sync ROME system again.
Details here
Aggiornamenti di giugno 2024
2024-07-14T22:00:00Z
We suggest to not update the system or install software until it’s finished.
It should not take long time.
Stay tuned.
2024-07-17T22:00:00Z
Earlier process finished, but restarted a new one right now to include the latest and brightest from cooker.
Stay tuned.
2024-07-18T22:00:00Z
Process finished.
It should now be safe to distro-sync ROME system
2024-09-17T22:00:00Z
2024-09-20T22:00:00Z
Process finished.
Please note:
We renamed the Unsupported (misleading name) repositories to Extra.
So the files in /etc/yum.repos.d/ must be updated.
If at the end of the process we are presented with a series of questions like this one, mentioning the configuration files in → /etc/yum.repos.d/ ← we will have to answer (Y)
:warning: - Yes - :warning:
2024-11-22T23:00:00Z
The process to copy cooker repositories to rolling (ROME) is starting.
Stay tuned.
2024-11-24T23:00:00Z
Process finished.
Please read the notes here above in this same topic, and also this.
Please read also Change in VirtualBox behavior
2025-01-11T23:00:00Z
The process to copy cooker repositories to rolling (ROME) just started.
