2024-06-02T22:00:00Z
- OpenMandriva Lx version:
ROME (ROME uses rolling repositories)
Plasma6, Plasma5, LXQt
OK to dsync users systems after latest ROME major upgrade
It is OK to upgrade users ROME Plasma5 and LXQt systems IF user has upgraded previously following the instructions here. If you have not upgrade with those instructions yet you will need to do so at this time.
Normal upgrade instructions for any Cooker or ROME system in Konsole or other terminal:
sudo dnf --allowerasing --refresh dsync 2>&1 | tee rome-dsync.log.txt
sudo dnf autoremove 2>&1 | tee rome-autoremove.log.txt
sudo dnf clean all
Do not use Discover or dnfdragor to upgrade your ROME/rolling system, they use the wrong command.
Note: The dsync and autoremove commands create the obvious .log files which you can post in this forum or in OM Issues if you encounter some problem. You will want to have the log files if you post about a problem.
