Edit: We depend on and deeply appreciate the feedback we get from users, good or bad. Those who communicate with us help make OpenMandriva Lx a better distro.
- OpenMandriva Lx version:
ROME/rolling (ROME is the release name, ROME uses rolling repositories)
Important: Do not use Discover or dnfdragora to do this. Will not work, will lead to problems.
These are instructions for Plasma5 and Plasma6 (only if you already have a P6 system, most of you will not). These are not instructions for upgrading from Plasma5 to Plasma6. If you want to use ROME Plasma6 it is strongly, hugely, majorly, advised to do a fresh install for Plasma6. Building and testing new ROME Plasma6 isos is in progress, it may be 1-5 days before these are ready for prime time.
For LXQt users it is strongly, hugely, majorly, advised to do a fresh install for LXQt 2.0. We will post upgrade instructions for LXQt after we have tested, but be smart and do a fresh install. The LXQt instructions will involve more steps to upgrade properly. Building and testing new ROME LXQt isos is in progress, it may be 1-7 days before these are ready for prime time.
Major upgrade of Plasma5 — Plasma 5.27.11, KDE Frameworks 5.116.0, Qt 5.15.12, kernel-6.9.1
Major upgrade of Plasma6 — Plasma 6.0.4, KDE Frameworks 6.2.0, Qt 6.7.0, kernel-6.9.1
Major upgrade of LXQt from 1.4 to 2.0, plus switch from openbox window manager to plasma6-kwin, Qt 6.7.0, kernel-6.9.1 and new OM configs
Plus a lot more upgraded system packages
To upgrade a Plasma5 (or Plasma6) ROME system:
The steps (in order):
Preparation:
sudo dnf clean all
sudo sh -c "echo keepcache=True >> /etc/dnf/dnf.conf"
With this command you avoid emptying the cache and therefore having to unnecessarily download the mass of packages again if something needs to be corrected.
If you have it, do:
sudo rpm -e --noscripts spice-vdagent
sudo dnf rm falkon-kde kio-kcm_trash
The distribution upgrade or dsync:
sudo dnf --allowerasing dsync 2>&1 | tee rome-dsync.log.txt
Don’t add any clean all or --refresh. If it is necessary to repeat the command, remember to make a backup or add a progressive number, for example:
sudo dnf --allowerasing dsync 2>&1 | tee rome-dsync2.log.txt
The goal is not to overwrite the log files in case they are needed for problem solving.
If you are using ROME in Qemu emulator:
sudo dnf install spice-vdagent
Remove no longer needed packages previously installed as dependencies:
sudo dnf autoremove 2>&1 | tee rome-autoremove.log.txt
Restore the /etc/dnf/dnf.conf file using some editor like Kate or in terminal nano or vim:
You can delete the inserted line, or comment it by adding a hash sign like this:
# keepcache=True
Note: These commands:
and:
Create the obvious .log files which you can post in this forum or in OM Issues if you encounter some problem. You will want to have the log files if you post about a problem.
Author Edit: The steps are accurate to the best of my knowledge at this time. If a user has added a lot of software or done a lot of system configs they may encounter difficulty. This has been tested on default systems with no extra software installed using rolling/main/release repos only and no configuration done. So if you do encounter issue you may consider to disable any and all 3rd party repositories, disable any unsupported, restricted, or non-free OM repositories and try again. We test this the way we do because:
- We can not predict what users may or may not do or add to their systems
- The purpose is to upgrade the operating system, upgrading changes a user may have made is the users responsibility. If you do have problems post with the .log.txt files and we will do our best to help.
