Hello, have a nice day, everyone.
I have been using OMLx successfully for at least 18 months. It is working mostly well on 3 different PCs. All of those 3 partitions share their roots. 1 original OMLx Plasma partition from spring 2023 evolved and branched out into those 3 OMLx Plasma partitions.
“Og1” = original OMLx Plasma partition on PC 1: still v24.08
“Cp0” = copy of Og1 on PC 2, now superseded by a fresher/newer copy, “Cp2”: v24.09 with force-installed rpm files (see below)
“Cp3” = copy of Og1 on PC 3: v24.09 working perfectly fine
Cp2's system specs:
ROME 24.09 znver1 with almost¹ all software in current version
“About System” (information) screen output:
Operating System: OpenMandriva ROME 24.09
KDE Plasma Version: 5.27.11
KDE Frameworks Version: 5.116.0
Qt Version: 5.15.15
Kernel Version: 6.11.0-desktop-2omv2490 (64-bit)
Graphics Platform: X11
Processors: *[older, non-antique mainstream one with > 10 threads]*
Memory: *[plenty]*
Graphics Processor: *[a tap older than CPU; still running fine]*
Description of the issue # 1 (screenshots if relevant):
1.) After the system update from 24.08 to 24.09 with correct instructions followed, Og1 and Cp0 and Cp2 all had the same problem: No Flatpak software could be started anymore. Every Flatpak program crashed at start without any error/warning/… message – only appearing and instantly disappearing in task bar. Same if started via Discover. Re-installation did not help. Checking ticks in Software Repository Selector, Discover etc. did not help. I triedreally a lotto solve the problem.
First I thought system update on Cp0 went wrong, especially because of issue 2.), but no, the same happened on Cp2 and Og1, too, for several times. At least 6 times on 2 different PCs the result of dsync system update led to Flatpak programs being unusable.
Today I learnt: After using rpm for forced installations of¹ = 1. lib64appstream4-0.16.3-1-omv2390.x86_64.rpm + 2. lib64flatpak0-1.15.6-1-omv2390.x86_64.rpm + 3. lib64flatpak-gir1.0-1.15.6-1-omv2390.x86_64.rpm and finally 4. flatpak-1.15.6-1-omv2390.x86_64.rpmon Cp2, every Flatpak program runs again. Everything seems to be fine now on Cp2. And Cp3 was working all the time; this issue never appeared on Cp3.
So for Og1, I wish to know how to exclude specific packages from being updated by dsync. That way, I would avoid having 2 conflicting versions each (of Flatpak and of its 3 dependencies) per system. Of course, this is only a temporary workaround until newer versions of Flatpak or its dependencies (or whatever) solve the problem.
- Relevant information # 1 (hardware involved, software version, logs or output…):
1.)
$ sudo dnf info *flatpak*
Last check for expired metadata: 0:15:23 ago on Sa, 19 Oct 2024 02:54:06 CEST.
Installed Packages
Version : 1.15.6
Release : 1
Architecture : x86_64
Source : flatpak-1.15.6-1.src.rpm
Pkg source : @System
Summary : Application deployment framework for desktop apps
URL : https://flatpak.org/
Licence : LGPLv2+
Description : flatpak is a system for building, distributing and running sandboxed desktop
: applications on Linux. See https://wiki.gnome.org/Projects/SandboxedApps for
: more information.
Version : 1.15.6
Release : 1
Summary : GObject Introspection Libraries for flatpak
Licence : LGPLv2+
Description : This package contains libflatpak GObject libraries.
Version : 1.15.6
Release : 1
Summary : Libraries for flatpak
Licence : LGPLv2+
Description : This package contains libflatpak.
Version : 5.27.11
Release : 4
Architecture : znver1
Source : discover-5.27.11-4.src.rpm
From Pkg src : rolling-znver1
Summary : Flatpak backend for discover
URL : https://www.kde.org/
Licence : GPLv2+
Description : Flatpak backend for discover.
Version : 1.15.10
Release : 1
Source : flatpak-1.15.10-1.src.rpm
Licence : LGPLv2+
: more information.
Version : 5.27.11
Release : 2
Source : flatpak-kcm-5.27.11-2.src.rpm
Summary : Flatpak Permissions Management KCM
URL : https://invent.kde.org/plasma/flatpak-kcm
Licence : GPLv2+
Description : Flatpak Permissions Management KCM.
Version : 1.15.10
Release : 1
Licence : LGPLv2+
Version : 1.15.10
Release : 1
Licence : LGPLv2+
Available Packages
Version : 1.15.10
Release : 1
Pkg source : rolling-znver1
Summary : Development files for flatpak
Licence : LGPLv2+
Description : This package contains the pkg-config file and development headers for flatpak.
Version : 6.1.5
Release : 1
Source : plasma6-discover-6.1.5-1.src.rpm
Summary : Flatpak backend for plasma6-discover
Licence : GPLv2+
Description : Flatpak backend for plasma6-discover.
Version : 6.1.5
Release : 1
Source : plasma6-flatpak-kcm-6.1.5-1.src.rpm
Licence : GPLv2+
Description of the issue # 2 (screenshots if relevant):
2.) After the system update from 24.08 to 24.09 with correct instructions followed, all of my OMLx partitions on every PC had 2 qarma packages installed. The older one cannot be uninstalled/erased via dnf. Both
$ sudo dnf --allowerasing --refresh dsync 2>&1 | tee rome-dsync2024-xy-bc.log.txt
and
$ sudo dnf autoremove 2>&1 | tee rome-autoremove2024-xy-bc.log.txt
are unable to solve the 2 qarma packages conflict.
Until now, I have not noticed a real problem stemming from this. So I did not try$ sudo rpm -eor such. I share it here just to give you complete info. -
Relevant information # 2 (hardware involved, software version, logs or output…):
2.)
$ sudo dnf info qarma
Last check for expired metadata: 0:00:20 ago on Sa, 19 Oct 2024 02:54:06 CEST.
Installed Packages
Version : 0.20240419
Release : 1
Source : qarma-0.20240419-1.src.rpm
From Pkg src : @System
Summary : Call Qt dialog boxes from the command line
URL : https://github.com/luebking/qarma
Licence : LGPLv2+
Description : Qarma allows you to display dialog boxes from the commandline and shell
: scripts.
: It is a drop-in replacement for the GTK based zenity tool.
Release : 2
Source : qarma-0.20240419-2.src.rpm
Licence : LGPLv2+
: scripts.
Here are my latest log files – covering both issues:
rome-dsync2024-10-06.log.txt (353,4 KB)
rome-autoremove2024-10-06.log.txt (1,1 KB)
rome-dsync2024-10-18.log.txt (1,4 KB)
Hoping for help and assistance
Kind regards
Tachyonenstrahl
