It has been said that Qt 5.8 is in cooker and should work pretty fine.
Yes, but meanwhile we may have KDE/Plasma packages that we should wait to install until we get QT 5.8 or 5.7.
I think that you are right
OMLx 3.02 development release build 834.
18 Feb 2017 - Fully updated, repo /testing enabled.
OMLx 3.02 development release build 891.
08 March 2017
I only tested live mode in vbox and Calamares didnāt start.
Havenāt tried in VBox yet but I have installed on 2 computers (hardware). Seems working well here.
So here now! I tried to start from terminal because I need to see its output but I types the wrong command. The working one is pkexec /usr/bin/calamares.
OMLx 3.02 development release build 927.
26 March 2017
But just try updating packages from main-testing repo⦠
The # 927 .iso works OK for me as does installed system as long as I donāt enable main-testing repo. #913 worked well also here. My installs are on hardware (usually) on 2 different computers.
I have noticed recently far fewer (almost none) segfaults, screen flashes, crashes, ect. Anyone else noticed this (hopefully) improvement. Seems Iāve noticed this since Qt 5.8.0.
OK, If I put these:
/^x11-driver/
/^x11-server/
libinput
lib64input10
in ā/etc/urpmi/skip.listā everything else in main-testing installed.
Imho as regular users should NOT have repo /testing enabled then thatās OK. In view of official release, with standard repositories enabled, I think we should test this kind of configuration.
Please correct me if Iām wrong ![]()
You are correct we should test install and configure with standard repos. And Iāll try to confine any other conversation about testing repos to āDevelopment Testingā form category.
927 doesnāt work for me. I have to download intel driver and modify xorg.conf by hand (Short version of what I did ) for to have OM Lx working.
A normal user is unable to do this
OMLx 3.02 development release build 993.
30 April 2017
Build 993 in vbox in live mode calamares aborts with the following error
QxcbConnection: could not connect to display
Iām the only one?
There is an i586 ISO # 994 also.
I have been ātoldā by calamares about no network
Rarely, some times it complains about not enough memory, or space, or suchā¦
Reboot always solved. Donāt know if this is your case
Perhaps yes. It installed here in VBox with no issues.
