User information: We also make kernel-rc versions available for users. rc=release candidate for next main line Linux kernel. Usually they work really well, and if they don’t you would still have whatever other kernel-desktop versions anyway.
The command to install the desktop version:
sudo dnf in kernel-rc-desktop --refresh
Current version is kernel-rc-desktop-6.10.0-0.rc7.1. kernel.org should be releasing the mainline kernel 6.10.0 in a few days.
By the way. I have installed om rome a few month ago. I never look at forum. I upgraded system just running dnf upgrade like fedora distro. Now i can see you use specific commands to upgrade system. I did dnf upgrade just yesterday. Which way should i use to do major upgrade especialy to plasma6.,? According to info from may ? From june? Install system from frash iso,? What is rome rc2024-07?
Best regards
The best way to update the system is the above commands from console.
Just in case there are specific instructions to follow, limited to a specific time-frame update, we write them here: https://forum.openmandriva.org/t/rome-major-upgrade-expected/4707.
Additional links, if any need for further explanation, are and will be provided in the same thread.
Hence you may want to have a look there before major upgrades.
Postedit:
No, you don’t want to switch Plasma5 to Plasma6 at this moment
Even if someway doable it’s like looking for troubles.
For sure better to do a fresh install with Plasma6 environment. Final release will be published in a few days.
You want to find the cache for the main repository for rolling. For me it is rolling-znver1-a1a6dcd30d9cf805 for you it will be something like rolling-x86_64-xxxxxxxxxxxxxxxx.
Then:
ls -lh rolling-x86_64-xxxxxxxxxxxxxxxx/packages
Then:
ls -lh rolling-x86_64-xxxxxxxxxxxxxxxx/repodata
So let’s start with the output of those 4 commands and see if we can figure this out.
Note: Please post code as code with the </> icon in the box where you write your post. If files are larger than 20-30 lines put them in a .txt file and post that here.
Edit: If we need to get OM devs involved we will. This is definitely not a problem I have seen before.
That is the problem, the cause would be what is causing that .rpm to not unpack. This is speculation but one of the first things I would suspect is a corrupted .rpm download or an .rpm that does not match the metadata of the main/release repository or that does not match what is in the distro-release-repos-pkgprefs-24.07-1.noarch package. So one more command to post the output of please:
[rolling-x86_64]
name="OpenMandriva Rolling - x86_64"
baseurl=http://mirror.openmandriva.org/rolling/repository/x86_64/main/release/
http://abf-downloads.openmandriva.org/rolling/repository/x86_64/main/release/
# Alternative if mirror.openmandriva.org is down
# mirrorlist=http://mirrors.openmandriva.org/mirrors.php?platform=rolling&arch=x86_64&repo=main&release=release
# fastestmirror=1
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-OpenMandriva
type=rpm-md
enabled=1
