How to upgrade kernel 6.4.11
The urls for the repositories are correct.
The distro-release packages are the latest and look correct.
ls -lh /var/cache/dnf/rolling-x86_64-be271eac6fa7887a/packages
razem 0
[root@corei5 radek]# ls -lh /var/cache/dnf/rolling-x86_64-be271eac6fa7887a/repodata
razem 5,2M
-rw-r--r-- 1 root root 5,2M lip 15 19:44 0942f7d4420f08c63f42182af24386c5f9a1bcd109437b1bb5dc19b990ec0350-primary.xml.xz
-rw-r--r-- 1 root root 2,4K lip 15 19:44 repomd.xml
That looks correct. This is a mystery to me. Contacting OM devs. You can speak directly to OM devs at OpenMandriva Chat.
One other thing I can think of is outdated rpm or dnf packages for some reason. So output of these would tell us that:
rpm -qa | grep rpm
rpm -qa | grep dnf
rpm -qa | grep rpm
rpm-provreq-qml-6.2.0-1.noarch
rpm-helper-0.24.20-3.noarch
python-dnf-plugin-rpmconf-4.1.1-1.noarch
lib64rpm9-4.18.2-1.x86_64
deltarpm-3.6.3-4.x86_64
python-rpmconf-base-1.1.10-1.noarch
python-rpmconf-1.1.10-1.noarch
lib64rpmbuild9-4.18.2-1.x86_64
lib64rpmsign9-4.18.2-1.x86_64
lib64rpm-4.19.92-2.x86_64
distro-release-rpm-setup-24.90-14.noarch
lib64rpmbuild-4.19.92-2.x86_64
lib64rpmsign-4.19.92-2.x86_64
python-rpm-4.19.92-2.x86_64
systemd-rpm-macros-255.7-1.x86_64
rpm-plugin-syslog-4.19.92-2.x86_64
rpm-plugin-systemd-inhibit-4.19.92-2.x86_64
rpm -qa | grep dnf
python-dnfdaemon-0.3.22-1.noarch
python-dnf-plugins-extras-common-4.1.1-1.noarch
python-dnf-plugins-core-4.5.0-1.noarch
lib64dnf-0.73.1-1.x86_64
python-libdnf-0.73.1-1.x86_64
dnf-data-4.21.0-1.noarch
python-dnf-4.21.0-1.noarch
dnf-4.21.0-1.noarch
dnfdragora-2.1.6-3.x86_64
dnf-automatic-4.21.0-1.noarch
Good plan :+1:
I’d suggest meanwhile to read general instructions (often are the same we repeat again and again :stuck_out_tongue: ) in the topic above mentioned about ROME major upgrades.
Also feel free to ask if you have any doubt.
ok thanks for your time and support. I will install fresh plasma6 ISO… When can i expect it?
The current ROME Plasma6 ISOs are very stable. The next ones for the release only have a handful of upgraded packages like new kernel 6.10.0. Edit: IMO there is no reason to wait.
Started copy of cooker to rolling repos right now
https://forum.openmandriva.org/t/rome-major-upgrade-expected/4707/37
I’d hope for release in 2/3 days :crossed_fingers:
Developer says the possible reasons for the problem Error unpacking rpm package kernel-desktop-6.9.9-1.x86_64 are bad download or not enough disk space. Disk space might be worth looking in to. Run the command df and locate your / partition and that will tell you how much available disk space you have.
@constantius24 if you still have the broken system and you have checked that you do in fact have enough disk space there is another option. Open Konsole and download the .rpm for the latest ROME x86_64 kernel (now it’s 6.10.0):
wget https://abf-downloads.openmandriva.org/rolling/repository/x86_64/main/release/kernel-desktop-6.10.0-1-omv2490.x86_64.rpm
Then try installing it with the rpm command:
sudo rpm -ihv kernel-desktop-6.10.0-1-omv2490.x86_64.rpm
Edit: Could be wrong on this point but as far as I can see a new kernel install should require less than 200 MB.
Ah, another good point from OM dev @bero.
There is no problem that would result in ā€œError unpacking rpm packageā€. The only explanations are bad download and/or disk full. Given it seems to be only the kernel-* packages, I’d guess /boot partition full
So if you installed your system with a separate /boot partiton and if that is to full that would explain this error. Obviously I do not know your system but this one makes more sense to me than anything I have heard on this issue. But you would have to have a separate /boot partition.
Wanting to upgrade a ~1 yr old rolling system (with all the changes in-between) hardly can lead to anything good.
Despite good willing people around to help.
