I tried to run the flatseal program “ com.github.tchx84.Flatseal ” from the console and I get this message
Ostrzeżenie: Nie można uruchomić programu „/usr/bin/com.github.tchx84.Flatseal” z parametrami „”.
Ostrzeżenie: Child process set up failed: execve: No such file or directory
Flatpak version works normally! Only the system version does not work
Lutris has a Polish language option since 0.5.19 but on openmadriva I think it’s broken because there’s only English using the command
LANG=pl_PL.UTF-8 lutris
The default English does not continue to work. I suspect that in openmadriva lutris has only English version available pomino that there is translation to other languages.
It’s not lutris fault because on other distributions work normally Polish version is detected in arch, debian 13 alpha/beta
These errors from lutris how to run just 2 install package and 1 command
(lutris:48049): dbind-WARNING **: 16:57:01.477: AT-SPI: Error retrieving accessibility bus address: org.freedesktop
.DBus.Error.ServiceUnknown: The name is not activatable
2025-05-15 16:57:01,993: The Battle.net source is unavailable because Google protobuf could not be loaded: Descript
ors cannot be created directly.
If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.
19.0.
If you cannot immediately regenerate your protos, some other possible workarounds are:
1. Downgrade the protobuf package to 3.20.x or lower.
2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slowe
r).
FIX sudo dnf in python3-pip at-spi2-core
pip install protobuf==3.20.*
I wonder that in rock system browsers are not acullized for example firefox or ungoogle chromium, I know there is a porblem with dependencies, but it can be dangerous?
If nothing can be done it’s hard I’ll use flatpak ungoogle chromium. Why is there a different icon in the flatpak version and in openmadriva there is the usual one from chromium?
Sorry if a little unclear as I am not so much into Linux (Use chatgpt sometimes to learn something)
Error with flatseal using system log journalctl -xe | grep Flatseal
maj 16 09:01:22 openmandriva-x8664 systemd[1138]: Started app-com.github.tchx84.Flatseal@a72ff129590c4c77962f9c02311e7efd.service - Flatseal - Flatseal.
maj 16 09:01:22 openmandriva-x8664 (Flatseal)[2207]: app-com.github.tchx84.Flatseal@a72ff129590c4c77962f9c02311e7efd.service: Failed to execute /bin/com.github.tchx84.Flatseal: No such file or directory
maj 16 09:01:22 openmandriva-x8664 (Flatseal)[2207]: app-com.github.tchx84.Flatseal@a72ff129590c4c77962f9c02311e7efd.service: Failed at step EXEC spawning /bin/com.github.tchx84.Flatseal: No such file or directory
░░ Subject: Nie można wykonać procesu /bin/com.github.tchx84.Flatseal
░░ Proces /bin/com.github.tchx84.Flatseal nie mógł zostać wykonany i się nie powiódł.
maj 16 09:01:22 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@a72ff129590c4c77962f9c02311e7efd.service: Main process exited, code=exited, status=203/EXEC
maj 16 09:01:22 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@a72ff129590c4c77962f9c02311e7efd.service: Failed with result 'exit-code'.
maj 16 09:02:43 openmandriva-x8664 systemd[1138]: Started app-com.github.tchx84.Flatseal@44d17c305d4f46109e2219cbd7c2d631.service - Flatseal - Flatseal.
maj 16 09:02:43 openmandriva-x8664 (Flatseal)[2240]: app-com.github.tchx84.Flatseal@44d17c305d4f46109e2219cbd7c2d631.service: Failed to execute /bin/com.github.tchx84.Flatseal: No such file or directory
maj 16 09:02:43 openmandriva-x8664 (Flatseal)[2240]: app-com.github.tchx84.Flatseal@44d17c305d4f46109e2219cbd7c2d631.service: Failed at step EXEC spawning /bin/com.github.tchx84.Flatseal: No such file or directory
maj 16 09:02:43 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@44d17c305d4f46109e2219cbd7c2d631.service: Main process exited, code=exited, status=203/EXEC
maj 16 09:02:43 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@44d17c305d4f46109e2219cbd7c2d631.service: Failed with result 'exit-code'.
maj 16 09:03:02 openmandriva-x8664 systemd[1138]: Started app-com.github.tchx84.Flatseal@9ec89221d0e342b5bcbd966e5b07a513.service - Flatseal - Flatseal.
maj 16 09:03:02 openmandriva-x8664 (Flatseal)[2252]: app-com.github.tchx84.Flatseal@9ec89221d0e342b5bcbd966e5b07a513.service: Failed to execute /bin/com.github.tchx84.Flatseal: No such file or directory
maj 16 09:03:02 openmandriva-x8664 (Flatseal)[2252]: app-com.github.tchx84.Flatseal@9ec89221d0e342b5bcbd966e5b07a513.service: Failed at step EXEC spawning /bin/com.github.tchx84.Flatseal: No such file or directory
maj 16 09:03:02 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@9ec89221d0e342b5bcbd966e5b07a513.service: Main process exited, code=exited, status=203/EXEC
maj 16 09:03:02 openmandriva-x8664 systemd[1138]: app-com.github.tchx84.Flatseal@9ec89221d0e342b5bcbd966e5b07a513.service: Failed with result 'exit-code'.
Indeed, it was a packaging error. Until recently, Lutris insisted on building the package using python installers, which caused problems with the Polish language, among others. I have now changed the packaging to meson and the Polish language is now installed correctly. Fix coming to Rome and Rock soon.
By the way, I have added an addon to Lutris that provides support for Blizzard as a source - it should only work after installing the Battlenet client.
The error you were getting was that the component that Lutris was using contained a very old version of protobuf - unfortunately distributions cannot provide such outdated components, because this is a security issue and should be solved by software like Lutris, not us.
Nevertheless, I hope that this “workaround” worked.
Unfortunately I can’t reproduce this. The application works fine for me (cooker system, gnome with Polish language).
Probably because the person maintaining the chromium package in OM chose to do so. You’d have to ask @bero about that.
Thanks for your help again. After a new installation, one more dependency is needed, gjs is needed for flatseal (maybe some program had such a dependency (gjs) before and that’s why libgthread was needed)
