As I wrote in this post:
I have checked the Resources category (Resources Index )
Rome rolling
KDE
When you type in a command, that is not yet installed and the system recognizes the package to which it bel…
The cnf command is not working properly.
The issue was twofold, it wasn’t updated to pyton3 and the dnf command in it was called without sudo
Since there is no repo for this, or at least I couldn’t find one, I’m linking a patch file and an updated spec file.
patch
spec
This should fix the issue.
Cheers,
Mark, you would be welcomed to help with some of these solutions you keep finding. The Matrix chat channel for Cooker is the place to be. Element seems to be
the lease painful client. https://matrix.to/#/#openmandriva-cooker:matrix.org
As you wrote in some other post, it is a great place, but a huge time sink.
Will do though.
Thanks
The off topic room is a time sink. The Cooker channel is coding business. Most folks just stay out.
It would be best to submit a PR against the package. @bero should know which one.
That package doesn’t have a separate repo, so I’m not sure where to find it and create a PR.
It’s probably in this org:
A pinch of Community, a pinch of Passion, a pinch of Innovation, flavoured with Fun - OpenMandriva Software
Searched repos there.
As far as I know the source only exists in abf for OM
Last time anyone touched that piece of code was 10 years ago and many major distros are using it
Found them here:
Updated March 2, it says.
thanks.
Added a pull request
I was looking at the wrong organization all this time wondering how do they manage so much in just 133 repositories
system
(system)
Closed
June 9, 2025, 2:13am
11
