Some minor things with ROME upgrade (09-11-2025)
KDE Plasma6
Changes after latest ROME(rolling) upgrade
Desktop wallpaper changed from default:
You should be able to figure out how to change this if this affects you and if you want to.
The default KSplash screen changes to “Breeze” instead of "OpenMandriva:
That is where to change this back or to whatever.
There is a new default browser Helium a version of Chromium ungoogled that is supposed to be better. This does not get installed. So if you want this:
sudo dnf in helium
dnfdragora and associated packages get removed. I believe because dnfdragora is not upgraded to qt6 but I am not sure. For me this is OK. Anyway it will not install anymore:
Repositories loaded.
Problem: package dnfdragora-2.99.1-1.x86_64 from rolling-x86_64 requires lib64yui-qt, but none of the providers can be installed
  - conflicting requests
  - nothing provides libcgraph.so.6()(64bit) needed by lib64yui-qt-4.6.2-8.x86_64 from rolling-x86_64
  - nothing provides libgvc.so.6()(64bit) needed by lib64yui-qt-4.6.2-8.x86_64 from rolling-x86_64
If losing dnfdragora is any concern file your complaints with the home office. Perhaps a better approach would be to learn to use dnfdrake.
This is all I have seen so far. Overall the upgrade went very smoothly here and this was a really big upgrade with some big changes.
sudo dnf in dnfdrake
I do not know if it was intended to install dnfdrake and make it the default. But it does not get installed with the upgrade.
Cooker chat has it. Happy Journey Around the Sun Day!
