ROME users attention please
The process to copy cooker repositories to rolling just finished.
The time has come.
Current ROME users please stop any update.
If you plan to convert your system, which receives updates from cooker branch, to real ROME rolling release you should switch the update channel to rolling right now.
Also, please give us the time to make some testing so that we can provide advices and workaround if anything will need of some fine-tuning.
Change repos but do not dsync your system yet. We need to do some testing and maybe fix a thing or 2. After changing repos check and be sure you only have rolling repos by running in terminal (Konsole) dnf repolist.
Example from one of my ROME systems:
And ROME (Rolling) users should always use dsync to upgrade your system. Like:
$ sudo dnf --refresh dsync
or perhaps better:
$ sudo dnf clean all ; sudo dnf dsync
There are technical reasons for this. To keep ROME rolling the distro-release* packages will be upgraded from time to time. To be sure dnf syncs with the latest in distro-release* package list we have to use the dsync command and not use upgrade. This is also why you don’t want to use dnfdragora or Discover to upgrade a ROME (or Cooker) system. If you use dnfdrake you need to edit the upgrade command to use dsync rather than upgrade.
dsync is an abbreviation of distro-sync. Either is fine but I prefer the shorter command. :wink:
Users that want to upgrade an existing Rolling system can follow this guide.
all went very well here , :slight_smile: :slight_smile: :slight_smile:
Summary
[andy@n17 ~]$ sudo dnf clean all ; sudo dnf dsync
83 files removed
Transaction Summary
Upgrade    46 Packages
Downgrade  13 Packages
Total download size: 151 M
Is this ok [y/N]: y
Downloading Packages:
(1/59): distro-release-OpenMandriva-4.50-0.1.13-omv40  52 kB/s | 8.5 kB     00:00
(2/59): distro-release-common-4.50-0.1.13-omv4050.noa 129 kB/s |  72 kB     00:00
(3/59): distro-release-desktop-4.50-0.1.13-omv4050.no 3.0 MB/s | 2.9 MB     00:00
(4/59): distro-release-desktop-Plasma-4.50-0.1.13-omv 667 kB/s | 629 kB     00:00
(5/59): distro-release-repos-keys-4.50-0.1.13-omv4050  99 kB/s | 9.2 kB     00:00
(6/59): distro-release-indexhtml-4.50-0.1.13-omv4050. 9.2 kB/s |  30 kB     00:03
(7/59): distro-release-rpm-setup-4.50-0.1.13-omv4050. 153 kB/s |  15 kB     00:00
(8/59): distro-release-repos-4.50-0.1.13-omv4050.x86_ 4.5 kB/s |  14 kB     00:03
(9/59): distro-release-rpm-setup-build-4.50-0.1.13-om 172 kB/s |  19 kB     00:00
(10/59): distro-release-rpmlint-policy-4.50-0.1.13-om  89 kB/s |  11 kB     00:00
(11/59): neofetch-7.1.0-1-omv4090.noarch.rpm          258 kB/s |  88 kB     00:00
(12/59): distro-release-repos-pkgprefs-4.50-0.1.13-om 888  B/s | 7.2 kB     00:08
(13/59): fwupd-1.8.4-2-omv4090.x86_64.rpm             1.2 MB/s | 5.3 MB     00:04
(14/59): lib64KF5Solid5-5.97.0-2-omv4090.x86_64.rpm   280 kB/s | 198 kB     00:00
(15/59): lib64fontenc1-1.1.5-1-omv4090.x86_64.rpm     8.1 kB/s |  18 kB     00:02
(16/59): lib64fs6-1.0.9-1-omv4090.x86_64.rpm           81 kB/s |  25 kB     00:00
(17/59): lib64fwupd2-1.8.4-2-omv4090.x86_64.rpm       338 kB/s | 309 kB     00:00
(18/59): lib64xau6-1.0.10-1-omv4090.x86_64.rpm         68 kB/s |  12 kB     00:00
(19/59): distro-release-theme-4.50-0.1.13-omv4050.noa 3.0 MB/s |  49 MB     00:16
(20/59): lib64xfont2_2-2.0.6-1-omv4090.x86_64.rpm      44 kB/s | 106 kB     00:02
(21/59): libxau6-1.0.10-1-omv4090.x86_64.rpm           77 kB/s |  12 kB     00:00
(22/59): mdadm-4.2-4-omv4090.x86_64.rpm               1.2 MB/s | 374 kB     00:00
(23/59): om-update-config-0.2-1-omv4090.x86_64.rpm    137 kB/s |  23 kB     00:00
(24/59): python-qt5-5.15.7-1-omv4090.x86_64.rpm        76 kB/s | 7.1 kB     00:00
(25/59): python-qt5-bluetooth-5.15.7-1-omv4090.x86_64 547 kB/s |  96 kB     00:00
(26/59): python-qt5-core-5.15.7-1-omv4090.x86_64.rpm  2.1 MB/s | 625 kB     00:00
(27/59): python-qt5-dbus-5.15.7-1-omv4090.x86_64.rpm  231 kB/s |  67 kB     00:00
(28/59): python-qt5-designer-5.15.7-1-omv4090.x86_64. 740 kB/s |  79 kB     00:00
(29/59): python-qt5-enginio-5.15.7-1-omv4090.x86_64.r 257 kB/s |  28 kB     00:00
(30/59): python-qt5-location-5.15.7-1-omv4090.x86_64. 902 kB/s | 113 kB     00:00
(31/59): python-qt5-multimedia-5.15.7-1-omv4090.x86_6 657 kB/s | 207 kB     00:00
(32/59): python-qt5-multimediawidgets-5.15.7-1-omv409 342 kB/s |  37 kB     00:00
(33/59): python-qt5-gui-5.15.7-1-omv4090.x86_64.rpm   447 kB/s | 658 kB     00:01
(34/59): python-qt5-network-5.15.7-1-omv4090.x86_64.r 178 kB/s | 179 kB     00:01
(35/59): python-qt5-nfc-5.15.7-1-omv4090.x86_64.rpm    82 kB/s |  50 kB     00:00
(36/59): python-qt5-opengl-5.15.7-1-omv4090.x86_64.rp 195 kB/s | 136 kB     00:00
(37/59): python-qt5-positioning-5.15.7-1-omv4090.x86_ 115 kB/s |  59 kB     00:00
(38/59): python-qt5-printsupport-5.15.7-1-omv4090.x86 8.4 kB/s |  64 kB     00:07
(39/59): python-qt5-qml-5.15.7-1-omv4090.x86_64.rpm    19 kB/s | 144 kB     00:07
(40/59): python-qt5-quick-5.15.7-1-omv4090.x86_64.rpm 909 kB/s | 231 kB     00:00
(41/59): python-qt5-remoteobjects-5.15.7-1-omv4090.x8 375 kB/s |  38 kB     00:00
(42/59): python-qt5-sensors-5.15.7-1-omv4090.x86_64.r 153 kB/s |  61 kB     00:00
(43/59): google-chrome-stable-105.0.5195.52-1.x86_64. 2.8 MB/s |  87 MB     00:31
(44/59): python-qt5-quickwidgets-5.15.7-1-omv4090.x86 3.2 kB/s |  24 kB     00:07
(45/59): python-qt5-svg-5.15.7-1-omv4090.x86_64.rpm   320 kB/s |  35 kB     00:00
(46/59): python-qt5-test-5.15.7-1-omv4090.x86_64.rpm  185 kB/s |  35 kB     00:00
(47/59): python-qt5-webchannel-5.15.7-1-omv4090.x86_6 113 kB/s |  19 kB     00:00
(48/59): python-qt5-webkit-5.15.7-1-omv4090.x86_64.rp 505 kB/s |  48 kB     00:00
(49/59): python-qt5-serialport-5.15.7-1-omv4090.x86_6 4.2 kB/s |  31 kB     00:07
(50/59): python-qt5-webkitwidgets-5.15.7-1-omv4090.x8 502 kB/s |  78 kB     00:00
(51/59): python-qt5-websockets-5.15.7-1-omv4090.x86_6 272 kB/s |  30 kB     00:00
(52/59): python-qt5-x11extras-5.15.7-1-omv4090.x86_64 138 kB/s |  12 kB     00:00
(53/59): python-qt5-xml-5.15.7-1-omv4090.x86_64.rpm   588 kB/s |  71 kB     00:00
(54/59): python-qt5-widgets-5.15.7-1-omv4090.x86_64.r 2.9 MB/s | 941 kB     00:00
(55/59): python-sip-qt5-12.11.0-1-omv4090.x86_64.rpm  811 kB/s |  62 kB     00:00
(56/59): python-qt5-xmlpatterns-5.15.7-1-omv4090.x86_ 295 kB/s |  47 kB     00:00
(57/59): dnfdrake-3.3.2-1-omv4090.noarch.rpm          926 kB/s | 101 kB     00:00
(58/59): solid-5.97.0-2-omv4090.x86_64.rpm            933 kB/s | 143 kB     00:00
(59/59): python-qt5-sql-5.15.7-1-omv4090.x86_64.rpm    11 kB/s |  88 kB     00:08
Total                                                 3.4 MB/s | 151 MB     00:44
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :                                                              1/1
  Upgrading        : python-sip-qt5-12.11.0-1.x86_64                            1/118
  Upgrading        : python-qt5-core-5.15.7-1.x86_64                            2/118
  Upgrading        : python-qt5-quick-5.15.7-1.x86_64                           3/118
  Upgrading        : python-qt5-xml-5.15.7-1.x86_64                             4/118
  Upgrading        : python-qt5-xmlpatterns-5.15.7-1.x86_64                     5/118
  Upgrading        : python-qt5-quickwidgets-5.15.7-1.x86_64                    6/118
  Upgrading        : python-qt5-bluetooth-5.15.7-1.x86_64                       7/118
  Upgrading        : python-qt5-dbus-5.15.7-1.x86_64                            8/118
  Upgrading        : python-qt5-designer-5.15.7-1.x86_64                        9/118
  Upgrading        : python-qt5-enginio-5.15.7-1.x86_64                        10/118
  Upgrading        : python-qt5-gui-5.15.7-1.x86_64                            11/118
  Upgrading        : python-qt5-location-5.15.7-1.x86_64                       12/118
  Upgrading        : python-qt5-multimedia-5.15.7-1.x86_64                     13/118
  Upgrading        : python-qt5-multimediawidgets-5.15.7-1.x86_64              14/118
  Upgrading        : python-qt5-network-5.15.7-1.x86_64                        15/118
  Upgrading        : python-qt5-nfc-5.15.7-1.x86_64                            16/118
  Upgrading        : python-qt5-opengl-5.15.7-1.x86_64                         17/118
  Upgrading        : python-qt5-positioning-5.15.7-1.x86_64                    18/118
  Upgrading        : python-qt5-printsupport-5.15.7-1.x86_64                   19/118
  Upgrading        : python-qt5-qml-5.15.7-1.x86_64                            20/118
  Upgrading        : python-qt5-remoteobjects-5.15.7-1.x86_64                  21/118
  Upgrading        : python-qt5-sensors-5.15.7-1.x86_64                        22/118
  Upgrading        : python-qt5-serialport-5.15.7-1.x86_64                     23/118
  Upgrading        : python-qt5-sql-5.15.7-1.x86_64                            24/118
  Upgrading        : python-qt5-svg-5.15.7-1.x86_64                            25/118
  Upgrading        : python-qt5-test-5.15.7-1.x86_64                           26/118
  Upgrading        : python-qt5-webchannel-5.15.7-1.x86_64                     27/118
  Upgrading        : python-qt5-webkit-5.15.7-1.x86_64                         28/118
  Upgrading        : python-qt5-webkitwidgets-5.15.7-1.x86_64                  29/118
  Upgrading        : python-qt5-websockets-5.15.7-1.x86_64                     30/118
  Upgrading        : python-qt5-widgets-5.15.7-1.x86_64                        31/118
  Upgrading        : python-qt5-x11extras-5.15.7-1.x86_64                      32/118
  Upgrading        : lib64fwupd2-1.8.4-2.x86_64                                33/118
  Upgrading        : lib64fontenc1-1.1.5-1.x86_64                              34/118
  Upgrading        : lib64KF5Solid5-5.97.0-2.x86_64                            35/118
  Downgrading      : distro-release-rpmlint-policy-4.50-0.1.13.noarch          36/118
  Downgrading      : distro-release-rpm-setup-4.50-0.1.13.noarch               37/118
  Downgrading      : distro-release-repos-pkgprefs-4.50-0.1.13.noarch          38/118
  Downgrading      : distro-release-repos-keys-4.50-0.1.13.noarch              39/118
  Downgrading      : distro-release-common-4.50-0.1.13.noarch                  40/118
  Downgrading      : distro-release-OpenMandriva-4.50-0.1.13.x86_64            41/118
  Downgrading      : distro-release-desktop-2:4.50-0.1.13.noarch               42/118
  Downgrading      : distro-release-theme-4.50-0.1.13.noarch                   43/118
  Running scriptlet: distro-release-theme-4.50-0.1.13.noarch                   43/118
  Downgrading      : distro-release-desktop-Plasma-4.50-0.1.13.noarch          44/118
  Downgrading      : distro-release-indexhtml-4.50-0.1.13.noarch               45/118
  Running scriptlet: distro-release-indexhtml-4.50-0.1.13.noarch               45/118
  Downgrading      : distro-release-repos-4.50-0.1.13.x86_64                   46/118
warning: /etc/yum.repos.d/openmandriva-rolling-x86_64.repo created as /etc/yum.repos.d/openmandriva-rolling-x86_64.repo.rpmnew
  Downgradin ...
  Verifying        : python-qt5-x11extras-5.15.7-1.x86_64                     107/118
  Verifying        : python-qt5-x11extras-5.15.6-3.x86_64                     108/118
  Verifying        : python-qt5-xml-5.15.7-1.x86_64                           109/118
  Verifying        : python-qt5-xml-5.15.6-3.x86_64                           110/118
  Verifying        : python-qt5-xmlpatterns-5.15.7-1.x86_64                   111/118
  Verifying        : python-qt5-xmlpatterns-5.15.6-3.x86_64                   112/118
  Verifying        : python-sip-qt5-12.11.0-1.x86_64                          113/118
  Verifying        : python-sip-qt5-12.9.1-2.x86_64                           114/118
  Verifying        : solid-5.97.0-2.x86_64                                    115/118
  Verifying        : solid-5.97.0-1.x86_64                                    116/118
  Verifying        : dnfdrake-3.3.2-1.noarch                                  117/118
  Verifying        : dnfdrake-3.3.1-1.noarch                                  118/118
Configuration file '/etc/yum.repos.d/openmandriva-rolling-x86_64.repo'
-rw-r--r-- 1 root root 8587 Apr 11 09:54 /etc/yum.repos.d/openmandriva-rolling-x86_64.repo.rpmnew
-rw-r--r-- 1 root root 8587 Aug 31 08:12 /etc/yum.repos.d/openmandriva-rolling-x86_64.repo
 ==> Package distributor has shipped an updated version.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      M     : merge configuration files
      Z     : background this process to examine the situation
      S     : skip this file
 The default action is to keep your current version.
*** aliases (Y/I/N/O/D/M/Z/S) [default=N] ?
Your choice: y
Upgraded:
  fwupd-1.8.4-2.x86_64
  lib64fs6-1.0.9-1.x86_64
  lib64xau6-1.0.10-1.x86_64
  lib64xfont2_2-2.0.6-1.x86_64
  libxau6-1.0.10-1.x86_64
  mdadm-4.2-4.x86_64
  om-update-config-0.2-1.x86_64
  python-qt5-5.15.7-1.x86_64
Downgraded:
  distro-release-rpm-setup-build-4.50-0.1.13.x86_64
  neofetch-7.1.0-1.noarch
Complete!
Glad to hear that worked fine :wink:
Both of my Rolling VirtualBoxes (from ABF: Plasma # 1286, Xfce # 1308, converted from Cooker), are running quite well. Using kernel-desktop-gcc with both. :slight_smile:
It’s working perfectly on my laptop thanks to ben79’s guide.
Awesome work!
