- OpenMandriva Lx version:
Rock/4.3
All
- Problem description (screenshots if relevant):
Get ready for 5.0
- Relevant information (hardware involved, software version, logs or output…):
Quote from wise contributor:
You will find that backup your data and doing a fresh install will result in more quicker and less troublesome outcome than to try distribution (system) upgrade (
distro-syncordsync) and spend ages to fix what can go wrong, not speaking of leftovers and every sort of junk that may got collected over the time. And having to do a fresh install anyway.
Note: 5.0 isn’t out yet, but it’s getting very close.
OK, before we have a plethora of users trying to upgrade from Rock 4.3 to 5.0, I wanted to try and help users, especially less technically savvy users, try to avoid problems.
The best suggestion for upgrading is do not do this, do a fresh installation; this is better in to many ways to list here. Back up your most important data and do a fresh install.
In light of this, start figuring out how to save all the data you want to keep now, rather than the day you try to install or update your system. I advocate that users create a separate partition to store important data separate from the installed system (this can be done during installation). If you don’t know how to do this, we can help. The technical way of saying this is “don’t store important files on any system partition.” The user can also create a separate /home partition during installation, and on future installations you format your / (root) but do not format your /home, thus preserving any data stored in /home.
If you choose to upgrade rather than do a fresh install, remember that when we tested this, we tested on systems installed from the 4.3 installation media without changes. Users who have configured a lot of things or installed a lot of third-party software need to be aware that we have no way to test user changes on their systems. And yes, this tends to be a source of problems when users, especially non-technical ones, try to do a system upgrade.
If you decide to do it anyway, here are some tips.
A. Disable any third-party repositories.
B. Disable any unsupported, restricted, or non-free repositories.
C. Doing this with dnfdragora or Discover will not work.
D. Doing this withsudo dnf upgradein the terminal (Konsole) will not work. -
What will work then @ben79???
A. First, make sure your 4.3 system is up to date.
B. There are complete instructions for upgrading Rock/4.3 to Rock/5.0 here.
And by all means, ask questions if you have them.
