I've found this fix works for me, can someone explain why?
  • OpenMandriva Lx version:
    Rome
    Wayland KDE
    Certain QT flatpaks (masterpdfeditor) were displaying
Failed to create wl_display (No such file or directory)
qt.qpa.wayland: Failed to initialize EGL display 3001
qt.qpa.plugin: Could not load the Qt platform plugin “wayland-egl” in “” even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
    Solved by adding export QT_QPA_PLATFORM=xcb to ~/.config/plasma-workspace/env/exports.sh
Software probably doesn’t work well under Wayland. xcb reverts back to X11. I use it too.
When I was playing with KDE on Wayland last night I was running into apps not launching like that. I got around it by installing “qt5-qtwayland” and “qt6-qtwayland”.
Apparently those packages are needed to have QT5 and QT6 apps to interface properly, the app in question that was not launching for me until after I installed was dnfdrake.
@seth_reee thanks for chiming in and welcome to OpenMandriva!
Welcome! We are glad to see you here.
This typically means it was not built with Qt6.
Welcome message:
Welcome @tux_peng and @seth_reee to OpenMandriva and our forum. This forum is for users of OpenMandriva Linux operating systems.
Some hopefully helpful suggestions:
We request that problems reported in forum or in a bug report be limited to one problem per thread or report.
We suggest that if your problem reported in the forum or on OM-Chat is not resolved in a few days to please file a proper bug report.
If you have not already done so scroll thru the “Big Fat Warning” at the top of this page and read the information or use the links provided.
Before reporting any problem please read this.
We are simply and respectfully trying to get people to be aware that as a very small group we are volunteering, unpaid, our time, knowledge, ect, to help you.
I encountered this too. I needed to install them to run Raspberry Pi Imager.
