Firewalld Service Will Not Start
KDE
The firewalld service will not enable. Many distros use this with zones for Home, Work, Public, etc. I did sudo dnf install firewalld plasma-firewall firewall-config firewall-applet. Install is successful. Then I run sudo systemctl enable --now firewalld which gives this error:
Job for firewalld.service failed because the control process exited with error code.
See "systemctl status firewalld.service" and "journalctl -xeu firewalld.service" for details.
systemctl status firewalld.service:
× firewalld.service - firewalld - dynamic firewall daemon
     Loaded: loaded (/usr/lib/systemd/system/firewalld.service; enabled; preset: enabled)
             └─10-timeout-abort.conf
     Active: failed (Result: exit-code) since Thu 2026-07-23 23:44:18 CDT; 1min 19s ago
 Invocation: aae93973064b4bb09f08c6f8a6c42d6c
       Docs: man:firewalld(1)
    Process: 120395 ExecStart=/usr/bin/firewalld --nofork --nopid $FIREWALLD_ARGS (code=exited, status=1/FAIL>
   Main PID: 120395 (code=exited, status=1/FAILURE)
   Mem peak: 31.8M
        CPU: 395ms
Jul 23 23:44:18 BOM-PC systemd[1]: Starting firewalld.service - firewalld - dynamic firewall daemon...
Jul 23 23:44:18 BOM-PC systemd[1]: firewalld.service: Main process exited, code=exited, status=1/FAILURE
Jul 23 23:44:18 BOM-PC systemd[1]: firewalld.service: Failed with result 'exit-code'.
Jul 23 23:44:18 BOM-PC systemd[1]: Failed to start firewalld.service - firewalld - dynamic firewall daemon.
journalctl -xeu firewalld.service:
░░ A start job for unit firewalld.service has begun execution.
░░ The job identifier is 23107.
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://openmandriva.org
░░ An ExecStart= process belonging to unit firewalld.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
░░ Subject: Unit failed
░░ The unit firewalld.service has entered the 'failed' state with result 'exit-code'.
░░ Subject: A start job for unit firewalld.service has failed
░░ A start job for unit firewalld.service has finished with a failure.
░░ The job identifier is 23107 and the job result is failed.
...skipping...
I did read this:
I am on a new install and tried this. I got the same error on znver1.
Verified. @bero
Jul 24 05:14:17 heisenberg-linux systemd[1]: Starting firewalld.service - firewalld - dynamic firewall daemon...
░░ Subject: A start job for unit firewalld.service has begun execution
░░ The job identifier is 7466.
Jul 24 05:14:17 heisenberg-linux systemd[1]: firewalld.service: Main process exited, code=exited, status=1/FAILURE
Jul 24 05:14:17 heisenberg-linux systemd[1]: firewalld.service: Failed with result 'exit-code'.
Jul 24 05:14:17 heisenberg-linux systemd[1]: Failed to start firewalld.service - firewalld - dynamic firewall daemon.
░░ The job identifier is 7466 and the job result is failed.
Hi @NLA Welcome. I’m in the process of setting up another ROME machine right now myself and ran into this issue, so I looked at the config. The config is located at (well linked to) /etc/systemd/system/multi-user.target.wants/firewalld.service for reference. What I found was that there are a lot of systemd hardening options enabled which on a macro level are the reason why the service fails to start. I’m quite sure that DevicePolicy=closed by itself would cause the failure, and I don’t ever use these in my firewalld configs, so I commented them out and made a couple of other changes in order for the file to look more like what I normally use. Please see the contents of my file below. I’m not advising you on what to do, but rather sharing what I did, and what I’m cool with. Alternatively, you could look into experimenting with all of these configs to find something that works, which is not a path I went down. At any rate, edit the file how you desire, save and run ‘systemctl daemon-reload’ to pick up the changes, and ‘systemctl start firewalld’ to start in order to test. Good luck.
[Unit]
Description=firewalld - dynamic firewall daemon
Before=network-pre.target
Wants=network-pre.target
After=dbus.service
After=polkit.service
Conflicts=iptables.service ip6tables.service ebtables.service ipset.service nftables.service
Documentation=man:firewalld(1)
[Service]
EnvironmentFile=-/etc/sysconfig/firewalld
ExecReload=/bin/kill -HUP $MAINPID
StandardOutput=null
StandardError=null
Type=dbus
BusName=org.fedoraproject.FirewallD1
KillMode=mixed
#DevicePolicy=closed
#KeyringMode=private
#LockPersonality=yes
#MemoryDenyWriteExecute=yes
#PrivateDevices=yes
#ProtectClock=yes
#ProtectControlGroups=yes
#ProtectHome=tmpfs
#ProtectHostname=yes
#ProtectKernelLogs=yes
#ProtectKernelModules=no
#ProtectKernelTunables=no
#ProtectSystem=yes
#RestrictRealtime=yes
#RestrictSUIDSGID=yes
#SystemCallArchitectures=native
[Install]
WantedBy=multi-user.target
Alias=dbus-org.fedoraproject.FirewallD1.service
Edited out an extra ``` seen after posting.
We used to put three ticks before and after a block, but now the trailing ticks are no longer needed. I found that confusing as well, but I don’t know when it started, as I was not here at the time.
Testing and just found that ip6tables is installed and that is listed in the line for Conflicts.
Maybe we don’t need firewalld?
iptables and nftables stuff both come in with firewalld as it stands a level above them as a management layer, so both are still needed in this case and configuration.
sudo dnf remove iptables-nft iptables-xtables iptables-utils iptables-service iptables6
That removed everything to do with iptables. After that, I was able to install the firewall using the Welcome app.
Welcome > Configure >  Security > Install and Configure your Firewall.
It all works fine after that. I enabled it using the Plasma System Settings app.
System Settings > Wi-Fi & Internet > Firewall
Even if you remove some part that it needs, it will reinstall what it needs. However, I no longer have the conflict that was preventing firewalld from starting.
I was wrong. It only looked like it was working. I don’t understand what is causing it to fail.
I believe that when you removed those packages, firewalld was also removed. Then when you went to OM Welcome and installed the firewall, it installs plasma-firewall which has firewalld as a dependency and then you were back where you started but with more packages.
I am left wondering if it is breaking existing firewalls as well?
Yes, I removed it as well. I cleared it all out and installed just firewalld and it still would not enable the service.
Thanks for bringing this up… LOL. If we look at the spec file here:
then we can see that it would break existing firewalld installs on upgrade if they had default configurations that worked previously. Why I LOLed is because it would also break what I did earlier in this thread on upgrade, which I don’t much care about for me because I’m fine once in a blue moon looking at the file. It’s probably not great to say to other people. This is where we get into the systemd topic people love… The correct way to do the edits for them to be preserved across upgrades is systemctl edit. Again, for my situation, I don’t get into all of that. I just make sure it’s running, set drop to the active zone, and test with nmap for the type of response I’m looking for. Also, it should be stated that there’s nothing wrong with the firewalld packaging, everything is done in the standard, right way.
If you want something done about this you need to take the issue directly to OpenMandriva Cooker Chat channel. Apparently not enough people have complained yet. Or something I do not understand.
It seems counterproductive to make the assumption that because some OM devs believe, probably correctly, that firewalls are useless that users, most especially new users coming from Windows, will accept this explanation. They do not, they will not, and we darn well know this.
I’ll keep bringing up the circumstance of using public wifi say for example the countryside of Ecuador or rural Mississippi.
I’ll point out here that removing a firewall (specifically iptables and nftables - though I don’t remember which one is the trigger) will also break virt-manager.
Here’s my firewalld.service file (I’m running ROCK) and it seems to work. I did have to fiddle with it a bit when I first set things up at the time and I wish I had kept better notes
There are differences in the file (Conflicts line and a whole bunch of stuff commented out - which I think you said you did?):
[Unit]
After=dbus.service
[Service]
# supress to log debug and error output also to /var/log/messages
StandardOutput=null
StandardError=null
Type=dbus
KillMode=mixed
DevicePolicy=closed
KeyringMode=private
LockPersonality=yes
PrivateDevices=yes
ProtectClock=yes
ProtectHome=yes
ProtectHostname=yes
ProtectSystem=yes
[Install]
Here is what the file looked like before I edited it:
[Unit]
Requires=dbus.service
After=dbus.service
[Service]
StandardOutput=null
StandardError=null
Type=dbus
KillMode=mixed
DevicePolicy=closed
KeyringMode=private
LockPersonality=yes
PrivateDevices=yes
ProtectClock=yes
ProtectHome=tmpfs
ProtectHostname=yes
ProtectSystem=yes
[Install]
If we go with the numbers as they are above: I deleted line 5, amended line 8, and commented out lines 20-35. Again, as stated above, this is what I did and what I’m cool with, not specifically suggesting it’s what anyone else does in a precise manner-just participating in the discussion. This is just how I roll, and it works for me and in general says nmap from my other hosts.
:smiling_face_with_sunglasses:
I’ll have to experiment. What I posted was the default config on ROCK. Hopefully I’ll be able to start playing around with ROME and COOKER again this weekend.
It looks like the ROME ISO has some…quirks. This issue, reproduced by at least 2 people, and then the snapper/libboost issue reported here:
also reproduced by at least two people.
I’m on ROCK, and was unable to reproduce either.
