External HDD fails to mount
I did not know that I was supposed to answer no to this at all.
@rugyada said
But I didn’t know that answering yes would be a problem, so I did it to proceed thinking this wasn’t a problem.
I installed ntfs and lib64ntfs now, and this doesn’t allow me to open the “Liam’s Gameplay” HDD from Dolphin, I still get the original error. This discussion is getting really difficult to follow along for me, so forgive me if it should be obvious what I should do next, but I’m not really sure what I should be trying now.
Well, at least we are back to the original problem. Major progress has been made.
You will need to find the device path again to be able to mount it. Do you remember how to do that?
lsblk -ao path,label,uuid,fstype
Somehow I still remain a little bit sceptical about the possibility of changing ownership on ntfs files just by simple mount and chown. But I really am curious. What should happen? Which user at the ntfs access control side corresponds to random user from Linux side?
I know you don’t think I can’t do that, but here is my proof. I am not changing ownership of the files, but of the partition.
  1. Oh danggit! Now nobody is going to test and I will have to find the possible error messages myself… Bummer! (but perhaps hilarity could ensue? tempting!)
  2. I wish I knew how that should work. Kernel.org gives something haphazard and links to linux-ntfs.org, which seems to be hijacked by some company and mainly sells stuff. Because of course they do.
It is absolutely vital that I do not damage or lose access to the files on my “Liam’s Gameplay” HDD, and I can’t copy the files off it for backup. So I’d like to be certain there are no risks before changing ownership.
This is all making me wish I just set the HDD to ext4 in the first place, lol.
It’s that time of night again though sorry, so I’ll have to hop off and continue this tomorrow.
Sleep well! Computers can wait and they do not complain.
In the mean time, just for fun, I just created 10 megabyte empty file, made it a loop device, then installed ntfs on it an mounted. Result:
[root@computer mymount]# mkdir test
mkdir: cannot create directory ‘test’: Read-only file system
But we will wait. Perhaps this is not undoable.
@OTZ can you chmod with 755 permissions and see if that fixes it? I’d rather someone test it before we tell the OP to try things again.
If it were me, I would just put the drive in /etc/fstab and be done with it, but that is just me. This would not do anything to the drive.
Once I have the UUID of the drive is all I need to write a line to paste into his /etc/fstab
Example to start from
UUID=xxxxxxxxxxxxxxxxx /gameplay rw,auto,user,fmask=133,dmask=022,uid=1000,gid=1000
So we also need the userid and groupid. Mine is 1000,1000, but mine is not standard.
id
Read only is read only. No modifications are possible.
Real problem is still that all this should happen by magic, automatically.
Did you also do the sudo dnf in ntfs* lib64ntfs*? Because one of those packages says ‘read-write drivers for NTFS’
I would help test this out, but I am at work and likely won’t be able to touch my computer until Friday.
No, actually, did not… Good point! But what should we do with:
We have been warned to not do things against the suggestions, so I’m currently playing it safe like Zaphod.
There is also still something else broken at Liam’s system.
Hard to tell, his error in dolphin is so vague it basically just says “hey, something broke”
The following does not really help here, but rather verifies that OMLx works as intended. After realising that the system naturally, normally and magically recognises what is going on device-vise, I could do this:
[root@computer user]# truncate -s 10M tenebrae.temporalis
[root@computer user]# ls -l tenebrae.temporalis
-rw-r--r-- 1 root root 10485760 Feb 20 09:03 tenebrae.temporalis
[root@computer user]# losetup -f
/dev/loop0
[root@computer user]# losetup /dev/loop0 tenebrae.temporalis
[root@computer user]# mkfs.ntfs /dev/loop0
The partition start sector was not specified for /dev/loop0 and it could not be obtained automatically.  It has been set to 0.
The number of sectors per track was not specified for /dev/loop0 and it could not be obtained automatically.  It has been set to 0.
The number of heads was not specified for /dev/loop0 and it could not be obtained automatically.  It has been set to 0.
Cluster size has been automatically set to 4096 bytes.
To boot from a device, Windows needs the 'partition start sector', the 'sectors per track' and the 'number of heads' to be set.
Windows will not be able to boot from this device.
Initializing device with zeroes: 100% - Done.
Creating NTFS volume structures.
mkntfs completed successfully. Have a nice day.
At this point Dolphin indicated new device, which was mounted. (So this is a one-click test.)
[user@computer ~]$ df /dev/loop0
Filesystem      Size  Used Avail Use% Mounted on
/dev/loop0       10M  2.5M  7.6M  25% /media/user/6BFBAFFD6D308508
[user@computer ~]$ cd /media/user/6BFBAFFD6D308508/
[user@computer 6BFBAFFD6D308508]$ ls -la
total 8
drwxrwxrwx  1 user user 4096 Feb 20 09:04 .
drwxr-x---+ 3 root root 4096 Feb 20 09:05 ..
[user@computer 6BFBAFFD6D308508]$ touch test
[user@computer 6BFBAFFD6D308508]$ mkdir testdir
total 8
drwxrwxrwx  1 user user 4096 Feb 20 09:07 .
-rw-rw-r--  1 user user    0 Feb 20 09:07 test
drwxrwxr-x  1 user user    0 Feb 20 09:07 testdir
[user@computer 6BFBAFFD6D308508]$ cd testdir/
[user@computer testdir]$ echo "OMLx rules!" > veritas.txt
[user@computer testdir]$ cat veritas.txt
OMLx rules!
That was fun. So far 39 days being relatively pleased with this system and not planning to move away.
Translated for you:
I suspect that this problem has to be solved from inside windows.
In one of the partitions I have windows7, not modern 11, so I can’t give you exact instructions, plus I’m going from memory.
Look for System > Disk Management, Partition Manager, Disks, or something similar and find the screen that shows the disk(s) with the partitions more or less as seen in Partiton Manager or GParted.
There should be an “Update” item (I see it on the right in a drop-down menu).
If I remember correctly I had clicked on the offending disk or partition before clicking Update but I can’t say for sure.
If windows and OM are on different disks, and you run dual boot from OM, I would recommend booting windows directly without going through OM’s grub (or any other possible Linux)
I’m a bit lost in this thread, so I may have missed you reporting wether you tried to “Update the disks status” from inside Windoze.
The only thing I did in Windows was test if the drive could be accessed. I just double-checked, and I can both read and write data on the HDD when it’s attached to the Windows 10 laptop.
I didn’t get to come on here and continue with the thread today, sorry. And I’m very busy tomorrow, so I’ll have to come back in a couple of days time.
What about “REAL SHUTDOWN” on Windows system instead of “system hibernation”. I know that Windows 10 (11 maybe too) by default are using quick shutdown / startup settings which can cause a trouble with accessing NTFS volumes under Linux. I think it is worth trying to do normal shutdown with this disk connected under Windows.
Second guess would be to try filesystem scan and repair under windows on that drive.
When I have first tried OM ROME and I was configuring my internal drives with ntfs partitions in fstab, I had similar problems with read only mounted partitions. I have changed UID of my user to 1000 (instead of 1001) and I have installed and configured ntfs-3g instead of default kernel ntfs. After that they started to mount as read and write:
UUID=C6A65999A6598B37 /mnt/C6A65999A6598B37 ntfs-3g uid=1000,gid=1007,defaults,noatime,umask=000 0 0
Yes, this is also mentioned in the linked topic.
I assumed it was done already :thinking:
Is that assuming I’m dual-booting Windows, or does Windows shutdown even affect the drive across different devices? Because my Linux desktop PC does not and never has had Windows on it. I only have Windows 10 on my laptop.
I didn’t translate my way through that whole topic, I only went as far as the message I quoted from it.
Liam, to do the shutdown thing, power up the laptop and plug in the drive. Do a shutdown, then unplug the drive.
