I am working on my Z800 Workstation. I have a full installation of Lx 4.2 Rock. I attempted to convert to Rolling. The only instructions I could find were for converting from 4.1 Rock to 4.2 Rolling, rather than from 4.2 Rock to 4.2 Rolling. I followed the directions there.
Everything was fine until I was done getting everything installed, upgraded, reloaded, etc., and ran the terminal commands listed to be done after converting but before rebooting.
It didnât look right and gave a few error messages. So I said, oh well, and rebooted. I opened Terminal and ran sudo dnf upgrade. I got this:
[zaivala@zaivala-FuzZ400 ~]$ sudo dnf upgrade [sudo] password for zaivala:
File â/usr/bin/dnfâ, line 57, in
from dnf.cli import main
File â/usr/lib/python3.9/site-packages/dnf/init.pyâ, line 30, in
import dnf.base
File â/usr/lib/python3.9/site-packages/dnf/base.pyâ, line 29, in
import libdnf.transaction
File â/usr/lib64/python3.9/site-packages/libdnf/init.pyâ, line 12, in
from . import conf
File â/usr/lib64/python3.9/site-packages/libdnf/conf.pyâ, line 13, in
from . import _conf
ImportError: libicuuc.so.68: cannot open shared object file: No such file or directory
So now what do I do?
I guess nothing is idiot-proof, and Iâm just the idiot to prove it.
I clicked on the menu button to reboot to something else, and got an error. It says it copied the error message to my clipboard. Here goes:
file:///usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/main.qml:27:1: plugin cannot be loaded for module âorg.kde.plasma.private.kickerâ: Cannot load library /usr/lib64/qt5/qml/org/kde/plasma/private/kicker/libkickerplugin.so: (libicuuc.so.68: cannot open shared object file: No such file or directory)
I found ufw, could not remove it. grep told me it was there, but did not tell me where it was.
Attempting to prove Iâm not a complete idiot, I just ran sudo dnf remove ufw. That apparently worked. Am I supposed to remove firewall? You didnât say.
Last metadata expiration check: 8:57:13 ago on Mon 31 May 2021 12:45:41 AM EDT.
Dependencies resolved.
Nothing to do.
Complete!
I still get this when I click on the Application Menu⌠and the only way to leave the system using GUI is hold the power button down⌠have not tried TerminalâŚ
OK, but⌠I did not upgrade from 4.1 Rock to 4.2 Roll. I upgraded from 4.2 Rock. At any rate, something is going on in Terminal and Iâll let you know if itâs working when Iâm done.
The command to upgrade Rolling system is: $ sudo dnf clean all ; sudo dnf --allowerasing distro-sync
It is the only one command that rolling users must run in console to get their system update.
FYI: Do not use discover, do not use dragora, never. Or they will get into troubles for sure.
