Can You Trust Software Built by AI?
Myself, I trust sphagetti open source code way more than the giant blobs offered by Microsoft, especially when I can use AI to audit said spaghetti code.
Right there with you
If code written by AI is anything like everything else done by AI, then double check the output, at least twice. Even more on a bad day.
Exhibit A:
I need a 30 AWG solid wire / 32 AWG stranded wire stripper. According to AI, I need a Klein Tools #11046 wire stripper. Only one problem with the #11046. It strips down to 26 AWG solid wire / 28 AWG stranded wire. Therefore, AI has once again has spit out garbage because of a crappy programmer.
AI reminds me of Oliver Wendell Jones’ computer, the Banana Junior 6000, which was known to crank out defective answers when using defective software.
What do I need? A Klein Tools #11057 wire stripper. It strips down to 30 AWG solid wire / 32 AWG stranded wire. Electronics keeps getting smaller. Even the hardware built back in 1998.
Is AI going away? No. The proverbial cat is out of the bag. Like everything else on the computer, it can be useful or it can be about as useful as bull’s teats.
You absolutely can if you are the one who designed it and you know what went into it. If you are the software designer, engineer, code tester in a VM, and you error check and bug check it countless tests you can definitely trust it. The question isn’t whether you can trust it. It is whether you can trust the Cloud AI Providers with your code and and whether you can trust people not to scrape the databases of the providers and steal your ideas. I am sure this will happen at some point. Also on the rust thing … rebuilds are the problem.
Take for instance you have code built in C and it was built a certain way but then someone wants to port it to rust and make a rebuilt clone. The C version already had memory holes and bugs to begin with. It wasn’t rust’s fault. The rust clone only inherits the bugs that were already there. If you build from scratch it is a different story and it is highly highly advised to test, test, test, and test some more your code before releasing it to make sure that it isn’t full of bugs. AI can copy anything nowadays using REA ( Reverse Engineer Anything through Ghidra or similar software ) but the point is that this isn’t hidden or secret knowledge, actually pretty widely known at this point. The notion of not being able to trust AI as a whole is extremist in ideology. It is like saying if all things are not this shade of white then they are black. It isn’t a one size fits all clause. It is fine to do AI assisted development of code and for writing software it greatly speeds up the process but that is not the same as vibe coding. Vibe coding is where you just ask the AI to build you something and just trust whatever it gives you.
AI assisted software development is where you spec out what it is that you are developing and how you want it to work, which code you want used, and how you want the functions to work, down to all of the internals and the AI assists you in making the best choices for the development of the software as to either eliminate potential bugs or memory errors while optimizing your code. It is no more cheating than driving a car to the grocery store is versus someone walking. I know people love to hate AI but it is what it is. Do not just blindly trust what an AI gives you. Test it yourself in a VM and study the code. Compare its functions. We live in an age of AI where everything is starting to adopt it and the situation is that linux could benefit from this but we still want to maintain control over what goes into linux. We do not want to let AI run amuck rather. AI is an excellent audit tool and it is great for checking your own code to ensure that you remove potential future issues that it may have and it is also great for finding flaws and correcting them without having to destroy your eyeballs looking for these problems.
Many people argue against AI and it is true … I “could” spend years and years and years developing a program ( and be like Richard Stallman with his Hurd kernel ) or I could use technology and still audit the code and get it done way way way sooner and not get passed up by Microsoft. I dunno about anyone else but I don’t want Big Brother or Microsoft passing me up.
The wire stripper example is a good illustration of why verification matters more than trust. A model picked a plausible-looking part number, and only checking the spec sheet catches the mismatch. That is not really an argument against AI-assisted work, though; it is an argument against accepting output without checking it. Your point about AI-assisted versus vibe coding is the useful distinction here. If someone reviews, tests, and understands what the tool produced, the responsibility stays with them. If they skip that, the failure is theirs, not the model’s.
I 100% agree. It is a certainty that AI is going to make mistakes. It cannot be blindly trusted. It is imperative that people use error gates if they are coding with the assistance of AI. The tests make sure that everything is correct and functional. I like to do the workspace gates and any other form of gating and then actually test out the function myself to see if it legitimately works or if it is a false positive. If I cannot call the function and test it somehow then it does not meet my standards for error checking. I have to know that the AI isn’t just telling me something works for instance like telling me that it is coding a backend for a graphics server and saying that it has X11 support yet it does not support the extensions. I run into things like this all the time but I am verbose so I end up going back and correcting them to make sure that things work. The models do exactly what they are designed to do. They are only as good as the prompts that we give them.
The wire stripper mix-up is a good illustration of why the output needs checking against a spec sheet rather than taken at face value. On the other point, the distinction between AI-assisted development and just accepting whatever comes back seems like the useful line to draw. The rebuild-versus-scratch point also matters: inherited bugs aren’t the new tool’s fault, but they still have to be tested for. Testing more, as you say, is the part that doesn’t get skipped when the code is reviewed by someone who knows the requirements.
I have another example of AI screwing up because the wingnuts responsible for writing the AI are just that, overpaid wingnuts without any concept of reality.
Today I get an email from my cable Internet service provider informing me that I need to replace my cable modem, which I own, not rent. Why? It doesn’t do gigabit Internet. The best it will do is 357 mbps. “We demand you replace it now with one of these models!”
What does the AI that generated the email give me? A list of modems that have been out of production for several years and no longer available. :roll_eyes:
As for me, I am still paying for 25 mbps Internet but receiving 174 mbps, more or less. More during the day with the local kids are in school. Less when they are home watching porn on their phones because all of them know how to press the “yes I am 18” button on the screen. Which proves that age verification will never work so long as kids lie. But that was covered in a previous thread a few month ago.
Anyway, so why get a new modem that is no longer available? Because poorly written AI said so? Don’t think so. I will wait until Docsis 4.0 becomes available and keep using my 6 year old modem. Do I need more speed? For what I use it for, no. I started out with a 300 baud dial up modem that required an actual phone so I could do the actual dialing. Two toggles. One was connect and disconnect. The other was client or host.
