Brave browser crashes randomly. Chromium too!
Thank you, that’s very good to know. I may start updating ROME once again, after all.
I woke up and started brave from the command line. Here is the error message when it crashed.
┌──[wilson@heisenberg] Fri Apr 25, 09:50:57 [~]
└──[ <$> brave-browser
[44104:44104:0426/053405.563253:ERROR:profile_attributes_storage.cc(1011)] Failed to PNG encode the image.
KMS: DRM_IOCTL_MODE_CREATE_DUMB failed: Permission denied
[44104:44126:0426/053407.813128:ERROR:registration_request.cc(291)] Registration response error message: DEPRECATED_ENDPOINT
[44104:44126:0426/053428.651331:ERROR:registration_request.cc(291)] Registration response error message: DEPRECATED_ENDPOINT
[44104:44170:0426/053435.515667:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[44104:44171:0426/053435.515671:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[44104:44172:0426/053435.515667:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[0426/053435.522152:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.522211:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.522720:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.523351:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.525651:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.525704:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.526047:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.526254:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/053435.526401:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.526480:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.530158:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.530165:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.530411:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.530414:ERROR:process_memory_range.cc(75)] read out of range
[0426/053435.533762:ERROR:directory_reader_posix.cc(43)] opendir /home/wilson/.config/BraveSoftware/Brave-Browser/Crash Reports/attachments/c6faad1e-e168-4772-a879-d125638f04c6: No such file or directory (2)
/usr/bin/brave-browser: line 39: 44104 Trace/breakpoint trap   (core dumped) "$HERE/brave" "$@"
Of course, no crash report is written and the directory is indeed empty. /home/wilson/.config/BraveSoftware/Brave-Browser/Crash Reports/attachments/ contains nothing.
I went over to the Brave forum and posted about the issue. I don’t see where it is effecting others.
Just a follow up. Is this happening only to people running znver1, or does anyone on x86_64 have this issue? We need to know.
x86_64
gnome wayland
brave-keyring-1.17-1.noarch
brave-browser-nightly-1.80.3-1.x86_64
I haven’t had a Brave crash in probably a few months.
From everything I have seen, this only happens on znver1.
I have crashing Brave on x86_64, sometime couple times in a row.
If you have Reporting enabled
you can go to:
brave://crashes/
to see if brave logged any crashes
you can also launch it from command line to try and determine the root cause with the following:
No experiments, no extensions, no GPU acceleration
brave-browser -n --args --no-experiments --disable-extensions --disable-gpu
If all works well and nothing crashes try enabling different parts one by one until a crash happens, i.e. enable GPU acceleration first, then extensions, then experiments
Also, it would help knowing your exact brave version brave://version as well as OM environment and versions if applicable.
I have:
Brave: 1.77.101 Chromium: 135.0.7049.115 (Official Build) (64-bit)
Operating System: OpenMandriva ROME 25.04
KDE Plasma Version: 6.3.4
Qt Version: 6.9.0
Kernel Version: 6.15.0-desktop-0.rc2.3omv2590 (64-bit)
Graphics Platform: Wayland
And haven’t experienced any crashes, granted Brave is not my day to day and I don’t have any extensions installed.
I do have reporting enabled and it has sent a lot of them since this started on March 2, 2025. I just can’t open them to see what they say and post it here for our devs.
By the way, I have all extensions off and no graphic acceleration and it still crashed while I was posting.
@WilsonPhillips can you check it on live iso with x86_64?
@AngryPenguin I can and will. Here is another copy and paste from the terminal.
┌──[wilson@heisenberg] Sat Apr 26, 11:31:50 [~]
[2093:2093:0426/113200.088909:ERROR:profile_attributes_storage.cc(1011)] Failed to PNG encode the image.
[2093:2115:0426/113202.384115:ERROR:registration_request.cc(291)] Registration response error message: DEPRECATED_ENDPOINT
[2093:2163:0426/113230.034088:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[2093:2162:0426/113230.034088:ERROR:browser_main_loop.cc(274)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[2093:2164:0426/113230.034133:ERROR:browser_main_loop.cc(274)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[0426/113230.040302:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.040362:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.040853:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.041464:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.043843:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.043886:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.044202:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.044406:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0426/113230.044549:ERROR:process_memory_range.cc(75)] read out of range
[0426/113230.044627:ERROR:process_memory_range.cc(75)] read out of range
[0426/113230.048400:ERROR:process_memory_range.cc(75)] read out of range
[0426/113230.048407:ERROR:process_memory_range.cc(75)] read out of range
[0426/113230.048666:ERROR:process_memory_range.cc(75)] read out of range
[0426/113230.048669:ERROR:process_memory_range.cc(75)] read out of range
/usr/bin/brave-browser: line 39:  2093 Trace/breakpoint trap   (core dumped) "$HERE/brave" "$@"
The ISO is writing to the thumbdrive.
Just a note, I normally don’t have much of an issue with this crashing, as it only seems to happen right after I start up. Since I don’t do that very often I don’t worry about it. But this morning, I decided to make this my focus for the day and fired it up from the command line. :rofl:
@AngryPenguin I am on the live environment right now. Several restarts and no crashes.
[live@omv-3856 ~]$ brave-browser
[9602:9602:0426/185114.518988:ERROR:network_service_instance_impl.cc(612)] Network service crashed, restarting service.
/usr/bin/xdg-mime: line 885: qtpaths: command not found
touch: cannot touch '/home/live/.local/share/icons/hicolor/.xdg-icon-resource-dummy': No such file or directory
[9602:9708:0426/185511.441248:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[17342:17342:0426/185542.132695:ERROR:atom_cache.cc(231)] Add chromium/x-internal-source-rfh-token to kAtomsToCache
[17342:17367:0426/185705.796910:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
Several restarts and reboots of the live usb and not a single crash of brave. I have to say it is a znver1 thing. The question is, can it be fixed without a reinstall?
I hope not, because that means that my issue is something else, I will also try to get some crash reports back at home. I have also a OMLx x86_64 installed inside qemu virtual machine and no single crash there (configuration is synced between native and vm, so same extensions etc.).
I have Searched found this topic related to the issue Brave browser crashes randomly. Chromium too!
**OpenMandriva Lx version:6
Desktop environment (KDE, ):
Fresh installed open mandriva 6
Enabled repositories
 sudo dnf repolist
[sudo] hasło użytkownika kuba:
identyfikator repozytorium        nazwa repozytorium
brave        brave
rock-updates-x86_64        OpenMandriva Rock - x86_64 - Updates
rock-updates-x86_64-extra        OpenMandriva Rock - Extra - x86_64 - Updates
rock-updates-x86_64-non-free        OpenMandriva Rock - Non-free - x86_64 - Updates
rock-updates-x86_64-restricted        OpenMandriva Rock - Restricted - x86_64 - Updates
rock-x86_64        OpenMandriva Rock - x86_64
rock-x86_64-extra        OpenMandriva Rock - Extra - x86_64
rock-x86_64-non-free        OpenMandriva Rock - Non-free - x86_64
rock-x86_64-restricted        OpenMandriva Rock - Restricted - x86_64
kuba@kuba:~$ brave-browser
[0430/193410.401327:ERROR:directory_reader_posix.cc(43)] opendir /home/kuba/.config/BraveSoftware/Brave-Browser/Crash Reports/attachments/54f7324b-cf49-4a17-800c-88dc401fb323: No such file or directory (2)
[4768:4768:0430/193414.992140:ERROR:CONSOLE(2971)] "[Settings] Appearance Page cannot find use default theme button template", source: chrome://settings/settings.js (2971)
[4768:4768:0430/193414.993040:ERROR:CONSOLE(2971)] "[Settings] Appearance Page cannot find use default theme button template", source: chrome://settings/settings.js (2971)
[4768:4855:0430/193440.660529:ERROR:browser_main_loop.cc(274)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[4768:4857:0430/193440.660538:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[4768:4856:0430/193440.660532:ERROR:browser_main_loop.cc(276)] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[0430/193440.669641:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.669722:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.670640:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.671569:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.674923:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.674985:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.675767:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.676026:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0430/193440.676237:ERROR:process_memory_range.cc(75)] read out of range
[0430/193440.676353:ERROR:process_memory_range.cc(75)] read out of range
[0430/193440.680330:ERROR:process_memory_range.cc(75)] read out of range
[0430/193440.680337:ERROR:process_memory_range.cc(75)] read out of range
[0430/193440.680624:ERROR:process_memory_range.cc(75)] read out of range
[0430/193440.680627:ERROR:process_memory_range.cc(75)] read out of range
/usr/bin/brave-browser: linia 39:  4768 "$HERE/brave" "$@" Debugger trap/breakpoint (memory dump)
kuba@kuba:~$
So, it is effecting x86_64 as well as znver1.
@grafi this thread already existed, so I moved your thread into this one.
