Will dnfdrake replace dnfdragora
Will DnfDragora be replaced with DnfDrake? If so, it’s going to be a little annoying because it launches out of bounds for me and can’t be resized. Other than that issue, it’s a solid DNF manager :+1:
Edit: The answer to the title is no. If user wants to use dnfdrake that is a user install. One may install this from OM-Welcome.
Discover and dnfdragora are still on Plasma6 iso. I do not believe these will be removed from repos anytime soon.
The change is that i686 repos were removed from /etc/yum.repos.d. That removes those repos from Discover and dnfdragora,
This is Cooker Plasma 6 x86_64 iso made Feb. 3.
There are 32-bit library packages in our regular repositories. (aarch64, x86_64, and znver1). These have been there since we quit using i686 repos.
The changes to etc/yum.repos.d, Discover, and dnfdragora will appear in next major ROME upgrade and in Rock/6.0.
Hi, could you attach the output of:
~ $ xrandr
do you use X11 or Wayland?
What happens if you click on this?
If people wish to discuss the dnfdrake window issue please open a separate thread with a descriptive title.
If you solve the problem in this thread other users will not be able to find your solution.
