Handful of users seem to thing OM Lx 4 is “lacking application”.
A few users have mentioned that OM Lx 4 is “lacking applications”. Developers suggested that “lacking applications” is to generic of a statement. How could anyone fix that. Developers want to know specifically what applications are missing that our users or potential new users would like to see included in our repositories? So please if you think there is something missing let us know in this thread.
I also asked developers “What software have Y’all removed from repositories”. Answer other than drakxtools nothing comes to mind. So developers are well baffled by the “lacking applications”, they don’t understand what people think is missing.
The dropping drakxtools has been announced and pretty well covered previously and over time we hope to develop new software or backport software from other sources to replace these. That is a WIP (Work in Progress) that will continues after OM Lx 4 is released. The reason for doing this is that it has gotten to difficult to develop with up to date Linux tool-chain packages and keep the ancient, decrepit code of drakxtools working. In retrospect we probably should have done this a few years ago. But then hindsight is 20/20.
So the situation with both drakxtools and URPM is not something missing it is something being replaced. Granted in the case of drakxtools that is going to take some time but that is unavoidable with our current resources.
Drakxtools are basically system administration tools. Obviously one can do most things drakxtools could do a whole lot more from the command line. Now is the perfect time for users to weigh in on what they want in the way of GUI system administration tools.
Tempted to Close this thread> lack of interest among users. But note the title. We asked users what applications are missing from OM Lx 4 and got nothing here. We did get an occasional mention in other threads of individual package and these are mostly built and in use now. A few are to deprecated upsteam or to old and difficult code for us to try to maintain. But the ones we can do we have done.
There are still some projects on back burner we work on from time to tie like using TV as Monitor with Intel and nVidia hardware.
nVidia proprietary drivers is going to be difficult until we get a package maintainer for nVidia proprietary drivers. Right now we don’t have anyone with enough time to tackle this so we’ll keep asking the community for volunteers. We will also need volunteers (w/nvidia driver hardware) to test nVida proprietary drivers if we ever get the maintainer.
Those are all unmaintained packages upstream. Our developers have looked at all 3 and given up on scan2pdf and kompozer as far as I know. Currently someone is looking at gftp but so far all build attempts have failed.
gftp can be replaced by filezilla
as @raphael suggests kompozer can be replaced with BlueGriffon.
scan2pdf I’m less sure about. Skanlite and Simple Scan are listed on some websites as alternatives to scan2pdf.
Post-edit (Jan. 06): gftp package is moved to unsupported/release repo in Lx 4.1 and unsupported/updates repo in Lx 4.0. We can supply specific installation instructions if anyone has need. In Lx 4.0 if you set your repos as described in post #2 above then this should just install normally from Konsole or dnfdragora.
I tried installing gftp and bluegriffon using dnfdragora but I couldn’t find them …
I just have some very basic notions for linux … do an installation from a DVD, and install software through dnfdragora I get there, but after …: o): o)
Thanks to all the developers for the work
Start with the right (IMO) approach: forget dnfdragora and use a terminal/console.
You will find that it’s the most easy way for someone suggesting ‘how to’ and the most easy for you to do.
Ok Ben …
It works, I found GFTP with dnfdragora …
I do not master Linux commands well … when I have a problem I am lost … I even reinstalled Openmandriva following a problem which I could not find a solution …: joy:: joy:: joy:
I have been using Openmandriva for 15/20 years
