Trying to make a demo video and discovered that Video Capture is not working. First wondering if I’m missing something? In the past I just selected Settings>Display>Video Capture “Enable Video Capture” and it worked. Anyone know anything about this?
All I do is to right click the icon in the little bottom bar and select video capture. The capture starts immediately and to stop it I just select it again.
Thanks, but starting it isn’t the problem. The problem is that when it is supposedly started it does not save the .webm file so no video was actually captured.
I can do this with the VBox 5.2.18 version from Oracle website. It is OM’s package (currently 5.2.16) that does not seem working.
Ah ok, I did not understand what exactly wasn’t working for you and as I don’t change anything in settings I wondered if there is something different in the way we do it
Maybe it’s a different way to do the same thing, and maybe it’s also the quickest. Anyway I always did so.
Actually I don’t use the vb video capture anymore because of bad quality of the video produced.
When I select Video Capture and start VBox I see that the Icon is spinning as if it is active and when I hover on it it shows where the video .webm file should be saved. But no video file is saved.
I don’t know. But the directory where is is supposed to save the file is listed in the settings. It is supposed to save the webm file in the same folder where the guest VM is located.
