"Some packages could not be installed:
task-plasma-5.9.2-1-omv2015.0.noarch (due to the lack of kwin-wayland[>= 5.9.2])
task-plasma-minimal-5.9.2-1-omv2015.0.noarch (due to the lack of plasma-workspace[>= 5.9.2])
Proceed installation anyway? (Y/n) n "
It happened a few days ago with another package. Following Crisb, the problem was that
“accidently” a package from cooker entered the LX 3.0 repositories. Did it happen again?
I think discover do not show broken packages in the updating list. Then, people that use discover do not know about this problem. I have been using urpmi for updating and have this broken packages alarm.
Fully agree. We have the magic words ‘urpmi --auto-update’ which let you have the control on whatever is going to happen while updating so why not use it?
Aside, one might argue that GUI is more user-friendly than CLI… But what the hell we are on Linux and can take advantage of its great features. So personally I love the console as long as it makes my life easier by just remembering some quick commands. There are times for GUI and times for CLI
Using MCC, I found out that this two broken packages belongs to main32-updates.
I have added comments to a closed/fixed bug on the same type of problem (bug 2047). I’m almost sure this is caused by another accidental issue of testing packages.
I’ve tried a number of times/ways to reproduce this problem and I simply can’t. The packages Y’all are talking about are working just fine, I can’t reproduce a problem with updates. Obviously this is with regular and testing repos enabled as none of the packages mentioned would be called without main-testing repo enabled.
In ‘drakrpm-edit’media’ in upper left hand corner select ‘Options>Global options’ select ‘Download program to use’ and select your preferred choice. Then you shouldn’t need to add --wget everytime.
so don’t use these repos for the time being. If anyone does not have testing repos enabled but they are pulling task-plasma 5.9.2 packages then change your repo. It’s a repo problem as I suggested a long time ago…
