Testing OM-Welcome
Version      : 2.9.2
Release      : 1
Architecture : noarch
Source       : om-welcome-2.9.2-1.src.rpm
Repository   : @System
From repo    : rolling-znver1
Summary      : OpenMandriva Lx Welcome Page
URL          : https://github.com/OpenMandrivaAssociation/om-welcome
License      : GPLv2
Description  : Startup and configuration tool for OpenMandriva Lx.
Welcome tab
Shouldn’t Click here to be sure you read the latest Release Notes and Errata be a different color or underlined to show as a link? If I did not read “click here” I would not have known it existed.
The icon with the red heart. I had no idea it went to the donate page till I tried it. Do we want to label it?
Features tab
OpenMandriva application Software Repository Selector shows name and icon but not clickable.
OpenMandriva application Bug report tool shows name and icon but not clickable.
If you are going to show them, make them real.
ABF page shows a link and hover makes the cursor change but the link does nothing.
http://abf.openmandriva.org
Configure tab
Cursor changes to show clickable on * System
Cursor does not change on any of the programs to show they are clickable. They change to blue, but I expect to see the cursor change. It makes me unsure what to click. With no hourglass to show busy, I don’t know if my click worked and I ended up with multiple windows opening to do a system update.
It installs and opens DNFDrake, but it is wider than my ultra-wide monitor and I cannot change it. I know that is unrelated, but still…
Applications tab
Games
Endless Sky does nothing when clicked
Repositories tab
Why is “Manage Repositories with OM Software Repository Selector” blue if I can’t click on it?
Why is “Please use only Software Repository Selector to enable/disable repositories” if I can’t click on it?
Why isn’t OpenMandriva repo-picker blue when I can click it? Make it and the icon the same size as others on the other tabs.
Contribute tab
Same issue as other tabs. Cursor does not change to show clickable or busy.
About is different from the other buttons. You have to click the icon or the word about. The rest, you can click anywhere blue.
@WilsonPhillips thanks. I will go through the list asap.
Postedit:
asap means at best tomorrow CET, it’s 01:15 of the night here :grin:
JFYI
I have to write my devotion, then I will trial everything.
Brave did not install for me from OMWelcome. It looked like it wanted too but it never actually downloaded it.
The latest version?
I would think so since I downloaded it from the WIKI page 4 days ago. When I click on the “about” button in it nothing happens so i really cant say right now. If you still want me to figure out what version I have I can study later on how to figure it out.
Did you add the repo first?
Or does the link to install it add the repo as well?
I just tried it on a fresh Cooker installation, did a system update and then installed brave from om-welcome and had no issue.
Wilson, it was a fresh install and the first thing I did was try and install it from OMWelcome. It did bring the install window up but just sat there and didnt do anything. I then installed it from Konsole.
go to Konsol after enabling the brave browser from OM-Welcome and then type in
“sudo dnf in brave-browser”
That did not answer the question, did you add the repo first? If the repo is not added, the install would just time out. If you weren’t doing it from the command line, you would not get an error message that the file was not found. I already have Brave, so I can’t tell.
Also this is testing OM-Welcome in the testing repo before it is released to ROME to replace the one that is there.
Im sorry I shouldnt have piped up, I clearly dont know what Im doing.
I dont know what you mean by “add the repo”. OM booted up after the installation and the first thing I did was to open OMWelcome and navigated to the Brave Browser installation tab, clicked it and the OpenMandiva repository picker popped up, I checked the extra, restricted, non-free and the Brave Browser boxes and hit ok. It didnt work. After searching on google a bit I found the command to type into Konsole to install brave so I did that and it worked.
[uriah@openmandriva-x8664 ~]$ sudo dnf in brave-broswer
[sudo] password for uriah:
brave 8.0 kB/s | 2.0 kB 00:00
brave 194 kB/s | 47 kB 00:00
Brave Browser 20 kB/s | 2.0 kB 00:00
Brave Browser 186 kB/s | 47 kB 00:00
OpenMandriva Rolling - x86_64 4.3 kB/s | 2.4 kB 00:00
OpenMandriva Rolling - x86_64 1.9 MB/s | 5.4 MB 00:02
OpenMandriva Rolling - Extra - x86_64 7.6 kB/s | 2.4 kB 00:00
OpenMandriva Rolling - Restricted - x86_64 5.4 kB/s | 2.4 kB 00:00
OpenMandriva Rolling - Non-free - x86_64 7.1 kB/s | 2.4 kB 00:00
No match for argument: brave-broswer
Error: Unable to find a match: brave-broswer
O.K., that helps to know you added the repo. :grinning:
Although the file appears to install the repo before it installs brave-browser, but it fails. If it were run from the command line we might see the error message. Since I have brave installed, it opens it with no error, but I am guessing that if I did not have it installed I would see an error that it requires sudo. @LinNoob did it ask you for the sudo password? If you remember, fine. If not, that’s fine too. :smiley:
I am looking at the file usr/share/om-welcome/apps/install-brave.run
#!/bin/bash
. /usr/share/htmlscript/helpers
if command -v brave-browser; then
	exec brave-browser
else
	APP=$"Brave Browser"
	if kdialog --title $"OpenMandriva" --yesno $"Do you want to install $APP?"; then
    ProgressDialog $"Installing $APP"
    pkexec sh -c "dnf install dnf-plugins-core --assumeyes --refresh && dnf config-manager --add-repo https://brave-browser-rpm-release.s3.brave.com/brave-browser.repo && dnf install brave-browser --assumeyes --refresh"
	ProgressDialog --close
		kdialog --title $"OpenMandriva" --msgbox $"Installation succeeded."
	else
		kdialog --title $"OpenMandriva" --msgbox $"Installation failed."
	fi
fi
fi
I tested it by editing
to
if command -v brave-browser.old; then
and ran it and it worked.
You misspelled browser. It’s
Sudo dnf in brave-browser
He Copy and Pasted you. :grinning:
We’ve all done it.
Poor @LinNoob got stuck in here with us accidentally. It’s all fun though.
I was typing it out on my phone at first. my bad @LinNoob I guess I am the real noob in all this. lol
I changed it in the original post.
[uriah@openmandriva-x8664 ~]$ sudo dnf in brave-browser
Last metadata expiration check: 1:00:10 ago on Sat 25 Jan 2025 08:47:05 PM CST.
Package brave-browser-1.74.50-1.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Most of the stuff I clicked on opened and installed. The only issue I saw was with Fine Additional Applications. the dnfdragora selector. It would not work when clicked. It may be because I am using cooker and it wont let you select that if you are using that repo.
I know you accidentally ended up in here with us, but we wouldn’t know it failed if you hadn’t. Thank you.
so it is installed and ready for use. Again, we would not recommend using cooker for a stable distro if you do not know how to break and fix things. Just FYI
