Rolling Edition
RPM Downloaded from Team Viewer website…
Last question and I’ll quit bothering ya’all. I"m trying to install TeamViewer and the failure is 'missing libminizip.so.1" nothing supplies this so the install fails. Anybody using TeamViewer ? I appreciate your time… Thank You
In situation with 3rd party software the tar package usually contains all dependencies needed. Downloading .rpm’s for Fedora, Suse, or other Linux may or may not work in OMLx. OM has no goal or commitment to be compatible with library software of other Linux distros.
Well this is embarrassing but apparently I was installing it incorrectly with your post above I’ve made it work… I’m really loving the work you all have done here and the support you have provided. I think I’ll be OK now, as I have the tools I need to function. Thank You !
