It isn’t stopped here. I rarely have a problem downloading OM ISO’s.
I can say that I believe ISO 1512 is the most stable LXQt ISO available anywhere in OpenMandrivaand is most likely better than ISO 1300 was. 1300 was the previous LXQt ISO.
The following is one users experience:
“In my experience a Lx 3.03beta ISO is a lot easier to work with today than the Lx 3.02 ISO is (or Lx 3.01, or LX 3.0). Though technically Lx 3.03beta is beta and Lx 3.02 is GA or Final ISO for that release. So to me the Lx 3.03beta ISO I would consider to be more stable based on my own experience and knowledge. This is because these releases are primarily Lx 3 with the most up to date packages at that time. Hence Lx 3.02 would be better than Lx 3.01 but Lx 3.03 would be better than either simply because of a vast number of bug fixes, security updates, patches applied, and so on. I believe this would be true for any user.”
I haven’t done this in a while but I use DownThemAll in Firefox and I used to be able to pause and resume downloads from ABF with it. Don’t know if using this would help if downloads are stopped by what ever is stopping jjm’s downloads. Maybe worth a try? It’s no secret that it is better for ISO and package downloads to not interrupt the download.
No not automatically started in Firefox. User has to select DTA or Firefox uses it’s own Download Manager. When I do downloads I right click on what I want and in the context menu I select “DownThemAll”. Screenshot:
Just did a test with DownThemAll and it is not possible to Pause downloads at least not from ABF. I don’t know if it will help this situation or not. It may be faster than Firefox download manager.
I confirm that resuming isn’t possible from ABF (I don’t know why however). This is the reason why sometimes I temporarily put the isos on the Omv CMS server, which offers the resume possibility, to let people download them conveniently.
Obviously, we cannot store all the isos there, due to lack of space. Build 1512 LXQt x86_64 Build 1530 x86_64 Build 1531 i586 Sha1sums
Note:
to make the above links work, please add this line in your /etc/hosts 212.129.32.94 test2574
the links will be active for a few days, unless you request a longer period of time
if you experience any issue, please report it here
EDIT: Build 1512 and sha1sums added
EDIT2: The links above are no longer available (11/07/17)
So my input wasn’t useless but did not help the original problem at all. This is a issue I’d like to see addressed. Not sure what to do about it but at some point it will be discussed with our ABF maintainers.
Fait. Je n’avais pas ajouté les sommes car elles sont disponibles sur la plateforme.
Tu n’as pas de problème pour télécharger les isos avec ces liens ?
The links and the line in /etc/hosts are correct. You might try to flush your dns cache: systemctl restart nscd
Merci jcl.
Mais malgré quelques essais, je ne me souviens plus comment procéder.
De plus, j’utilise Mageia 6, OMA non disponible suite à un problème de HDD.
$ wget -c 212.129.32.94 test2574/openmandrivalx.3.02-lxqt.x86_64.iso
--2017-10-31 11:34:50-- http://212.129.32.94/
Connexion à 212.129.32.94:80… connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : non indiqué [text/html]
Sauvegarde en : « index.html »
index.html [ <=> ] 566 --.-KB/s ds 0s
2017-10-31 11:34:50 (8,88 MB/s) - « index.html » sauvegardé [566]
--2017-10-31 11:34:50-- http://test2574/openmandrivalx.3.02-lxqt.x86_64.iso
Résolution de test2574… 212.129.32.94
Réutilisation de la connexion existante à 212.129.32.94:80.
requête HTTP transmise, en attente de la réponse… 404 Not Found
2017-10-31 11:34:50 erreur 404 : Not Found.
Terminé — 2017-10-31 11:34:50 —
Temps total effectif : 0,1s
Téléchargés : 1 fichiers, 566 en 0s (8,88 MB/s)
Avec cette commande tu essaies de charger 2 fichiers :
_http://212.129.32.94/_ c’est-à-dire le fichier index affiché par défaut par le serveur web (nginx)
openmandrivalx.3.02-lxqt.x86_64.iso : qui effectivement n’existe pas. Problème de casse. Il faut écrire : wget -c http://test2574/OpenMandrivaLx.3.02-LXQt.x86_64_B1512.iso
Le lien donné plus haut est correct. Pour éviter ce type d’inconvénient en ligne de commande, on peut procéder ainsi :
– clic droit sur le lien dans le navigateur, puis copier l’adresse du lien
– dans la console, taper le début de la commande puis appuyer sur les touches CTL MAJ C, soit : wget -c [CTL MAJ C]
Ce qui va donner : wget -c http://test2574/OpenMandrivaLx.3.02-LXQt.x86_64_B1512.iso
The only reason I see is that the link is http, not https because I did the things as simple as possible (that is: too quickly). I could try to force https in some way.
