In VirtualBox it is faster to run OM Lx (All) directly from the .iso file.
Explanation in pictures:
It is a recommended to remove the .iso file from VBox settings after doing the install.
Should you have problems please report in the English Support forum with a descriptive title and enough of a description and information for someone to be able to help you. If your issue is a serious technical issue then please file a bug report.
