Any way to select items with keyboard instead of using the mouse so to exclude a mouse issue?
Something with the Tab and the arrows keys…
Not sure if the best version but it is the latest, just build ![]()
https://abf.openmandriva.org/platforms/rolling/products/179/product_built_lists/3300
@deltakprime and other users. It is a good idea to install icewm desktop inorder to have a reliable graphical backup desktop. It is simple but can make it a lot easier to fix problems sometimes.
Also if I install a P6 Wayland system after installation I also install task-plasma6-x11 for yet another backup. If install P6 X11 then I install task-plasma6-wayland.
This link does not open for me… how do I download this file?
I get message “File not downloaded. Potential security risk.”
Even if I choose to allow the file, it still doesn’t download.
Using ROME P6 znver1 Wayland I see high CPU temps. compared to X11.
Wayland example cpu temperature using sensors:
acpitz-acpi-0
Adapter: ACPI interface
temp1: +85.0 C
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +85.2 C
X11 example cpu temperature using sensors:
acpitz-acpi-0
temp1: +43.0 C
k10temp-pci-00c3
Tctl: +43.5 C
Downloaded the 3300 version, Calamares failed the install, loaded gdb per instruction, installed successfully, standard recommended update procedure came back saying nothing to do.
So far, looks good.
Thanks for the help, guys.
Mike
Glad that you came with a working system.
Next time/s you decide to upgrade your ROME system you want to check for latest comments, if we will add any, HERE.
Ok, thanks!
