Qt-Creator 15rc1 on ROME: undefined symbol in libUtils.so.14
  • OpenMandriva Lx version: 24.12
When trying to launch Qt Creator 15 rc1, Qt Creator does not launch. When run from the command line, it shows an error about a missing symbol in libUtils.so.14. Full error message below.
Error message:
qtcreator: symbol lookup error: /usr/lib64/qtcreator/libUtils.so.14: undefined symbol: _ZN19QAbstractFileEngine14beginEntryListERK7QString6QFlagsIN4QDir6FilterEERK5QListIS0_E, version Qt_6_PRIVATE_API
Package:
Version : 15.0.0
Release : 0.rc1.1
Architecture : x86_64
From repo : rolling-x86_64
Am I just missing a dependency that should have been installed, or is this a packaging bug?
Have you seen and tried the recommendation in this thread?
Welcome @superfly and @mKay.
For information: [Forum] How to post code as code
The Problem is confirmed in both Cooker and ROME. I started a new cooker build to see if this is just a new dependency issue. We should know later today. Also informed developers in OM-Chat.
Great stuff, thanks!
qt-creator-15.0.0-0.rc1.2 built in Cooker, installs and opens. I do not use this so beyond it opening I do not know. I am backporting this to rolling repositories will let you know when it is in repos,
Thanks! I’ll test it out once it’s uploaded, and let you know.
qt-creator-15.0.0-0.rc1.2 published to rolling repos. Should be available in mirrors in a few hours if not sooner. I have not tested it in ROME yet but there was no harm in publishing given it works in Cooker and the current package in ROME does not work at all.
I just installed Qt Creator in ROME, and it works, woohoo! Thanks @ben79 !
Thanks for reporting the issue and thanks for the feedback. It helps.
