As announced here there was just a major software upgrade for OM ROME branch.
If user sees any error similar to this, or any error message that mentions 5.240.0 packages:
* Problema 1: package plasma-desktop-5.27.5-1.x86_64 from @System requires libkworkspace5.so.5()(64bit), but none of the providers can be installed
* - cannot install both lib64kworkspace5-5.240.0-0.20230527.1.x86_64 from rolling-x86_64 and lib64kworkspace5-5.27.5-1.x86_64 from @System
* - cannot install both lib64kworkspace5-5.27.5-1.x86_64 from rolling-x86_64 and lib64kworkspace5-5.240.0-0.20230527.1.x86_64 from rolling-x86_64
* - cannot install the best update candidate for package plasma-desktop-5.27.5-1.x86_64
* - cannot install the best update candidate for package lib64kworkspace5-5.27.5-1.x86_64
You do not want to install those packages. Those packages are for the future when Plasma 6 is released and the Plasma 6 packages are packaged for OMLx by OM developers. To workaround these errors run this command in Konsole (terminal):
$ sudo dnf clean all ; sudo dnf dsync -x *5.240.0*
Some users may see these issues:
Printing from Chromium crashes browser (The workaround is to use Falkon or other browser if you need to print something from browser)
Can’t login from sddm with new user passwd. (Workaround: sudo dnf rm kwallet-pam)
nVidia proprietary drivers are not built yet for the new kernel-6.3.4-3. For now if user needs the proprietary driver then they need to use the old kernel. (Developers are working on this)
Note: I started this post about 2 weeks ago, apologies for not getting it posted sooner.
Note-2: Sometimes there are errors blocking a dsync that can be alleviated by using the --allowerasing option. OMLx user should be aware of this and use it if needed. Some people use this for all dsync transactions. You use it like this:
$ sudo --allowerasing dnf dsync
or
$ sudo --allowereasing dnf dsync -x *5.240.0*
Users that want to know more about dnf commands and options may read here. It is a good idea to know why we recommend commands like dnf clean all, or options like --refresh, and --alloweraing. There are other useful commands and options as well.
