OpenMandrivaLx.rolling-snapshot.20251109.4292-plasma6x11.znver1.iso
os-release.txt (496 Bytes)
The same behaviour also happens on
OpenMandrivaLx.rolling-slim-plasma6x11.znver1
(build 4310)
KDE Plasma6; X11
Hardware
Mobo: MSI MAG X870E Tomahaw WiFi
CPU: Ryzen 9950X3D
GPU: Radeon 9070 XT
On every boot after installation, after logging in at the GUI / Splash Screen, if nothing is touched after hitting enter on log-in, the system boots to tty1 with a blinking cursor. More happens after this, below is an approximate (+/- 2sec) timeline of the behaviour.
Timeline
Point A - 00:00.0 -Hit enter on log-in. Screen switches to a blinking cursor on tty1
Point B - 00:30.0 -Screen switches to DE on tty2
Point C - 01:30.0 -Black Screen, no cursor, no inputs work
Point D - 02:00.0 -GUI Log-in screen
Point E - 02:05.0 -Blinking Cursor, no inputs work. Ctrl+Alt+Fn either does nothing, or all terminals are the blinking cursor.
(I took a video of this cycle from my laptop but I can’t upload it.)
Other events I have noted when interfering in the above sequence.
- If I manually switch to the DE on tty2 within the 30 sec between A and B, the system seems to run normally and stably (for at least 20 min).
- Between B and C; If I manually switch to tty3, then back to tty2, then at point C it drops to tty3, with a terminal log-in prompt, instead of the black screen.
The rest of the timeline remains the same after this if left untouched.
If I try logging in at this terminal more odd terminal swapping happens that I didn’t manage to note down properly, (I think the DE might have been on tty3 at one point). - If I start using the system normally after point B, it will still drop out to the black screen at point C.
- If I log in within the 5 sec between D and E, it will drop to another GUI Log-in screen instead of going to the unresponsive blinking cursor at point E.
This seems to actually be resetting the cycle back to point A. - There was more odd behaviour other than this, but I didn’t manage to note it all down.
Below is the process I followed to reproduce this on this latest installation and gather data/log files, with those files included at the relevant points.
loaded live environment from USB written with dd as described here
Installed using
$ pkexec calamares -d 2>&1 | tee /home/live/calamares-installation-log.txt
Installation was done with default “Erase disk” settingscalamares-installation-log.txt (118.8 KB)
copied that file to a USB and removed it
Rebooted
Logged in @ GUI/splash screen (and took video)
Hard restart button at end of cycle when system had frozen.
Logged in and switched to tty2 manually
Opened Konsole
sudo journalctl > journal.txtjournal.txt (814.1 KB)
cat /etc/os-release > os-release.txt
(posted above) -
inxi -Fz > inxi.txtinxi.txt (3.0 KB)
dmesg > dmesg.txtdmesg.txt (144.1 KB)
Copied files to USB
Shutdown
Version and Installation media details
This installation was done using a “dd” written ISO, but the same behaviour happens when using ventoy or balena etcher.
The same behaviours happen on Plasma Slim (build 4310)
BIOS/UEFI settings (Not sure if these are relevant, but just in case)
{Secure Boot}, {TPM}, and {CSM mode} are all OFF
{Legacy USB Support}, and {XHCI Hand-off} are both ON
{Initiate Graphics} is set to PEG; {UMA} is set to Auto; {Hybrid Graphics} is Enabled
I have also had the same behaviour with No GPU installed at all (IGP only)
and also with GPU installed, but {Hybrid Graphics} disabled.
{EXPO} is enabled, but I’ve had the same results with it disabled also.
All other bios settings are defaults (other than the “download driver automatically” I turned that #$%^ off too)
I am posting this from my laptop so the above process would not involve doing anything to the system other than that mentioned. I did this thinking it would minimise variables and log/file sizes to make troubleshooting easier/quicker.
If you want me to post from the effected machine to gather more info, or to use matrix, I will install ProtonPass and do so (and figure out how to use matrix lol).
This installation was done as a temporary/test installation. If you think I will need to join matrix and just follow instructions to resolve this then I will do a proper install, with an actual user and pc name, and password first.
I hope there isn’t too much useless stuff in this post, and that what is included is clear. Please let me know if I do need to clarify anything, or if more info is needed
Thank you for your time.
