OpenMandriva keeps freezing the whole machine
I’ve just installed OpenMandriva 5.0 (Iodine) (Rock) and the graphical environment keeps freezing to the point where I have no choice but to hard reset. I cannot even get to another virtual console to even use the command-line. I’ve checked dnf and there are no updates availble for me to install.
Eg.
[james@jamespc ~]$ su -
Password:
[root@jamespc ~]# dnf check-update
Last metadata expiration check: 4:59:42 ago on Wed 10 Jan 2024 18:08:01.
oma-welcome.noarch 2.5.7-1 rock-updates-x86_64
telegram-desktop.x86_64 4.12.2-1 rock-updates-x86_64
[root@jamespc ~]#
While I understand that a lot of work goes into creating a distro, and it isn’t just a matter of building a few packages and that’s it; the developers of OpenMandriva claim that it is “stable”, but clearly this is not the case. And while I wouldn’t expect, for example, Debian Testing to be “stable”, hence the word “testing”; if you are going to claim your distro is “stable” then make sure it is, BEFORE promoting it as “stable”, please. As my computer is not usable if it’s going to keep freezing for no apparent reason, and at any time. This isn’t good enough guys, I’m sorry, it is not. And unless thing really start to improve, then I’m going to have to switch distro’s, as I need my system working, not randomly freezing up on me. I’ve had to first type this post in KWrite in case it did once again freeze up on me half way through once again. I’m using the KDE desktop environment, and I’ve just had to hard reset AGAIN.
Can the developers of OpenMandriva please actually TEST things before including them in future, BEFORE using them and putting said version into the repo, please. As clearly that’s lacking when the problem I’m talking about can happen within literally two minutes of logging in, without me even really doing much if anything.
Welcome @james to OpenMandriva and our forum. This forum is for users of OpenMandriva Linux operating systems.
We are a small group. All the contributors and developers here are unpaid volunteers.
The first thing when a new user has an issue is to look in the documentation for OMLx. OpenMandriva wiki and Forum Resources guide.
If you don’t find what you are looking for try an Internet search (googling). One can find out a lot from documentation or forum posts at other Linux distros. If user finds something written for another distro but you have some doubt ask at OpenMandriva Chat.
is it in virtual machine (VirtualBox?) or real hardware?
x11 or wayland session?
Please read How to get better results when posting about problems
No it is not a VM - I can’t even use any VM’s as the package for Virtualbox does not even include the kernel drivers, and if it does, they do not build (and yes, I do have the kernel development packages installed, for the kernel version I’m running), therefore I’m running it on bare-metal. And no, it’s not a problem with hardware, as the old version of OpenMandriva did not have any of these issues - these issues have only appeared since installing OpenMandriva 5.0.
So it is once again most certainly people not testing newer versions of things before packaging them and putting them into the repo’s. Firefox from the repo’s also segfaults randomly, I can’t even build Virtualbox from the .run file, as it refuses to build the kernel drivers, even though I once again have the relevant kernel development packages/headers installed.
As I also need Virtualbox working as well, and it would be nice if I could just install an actual working version of it from the repos, rather than having to build it myself (or try to in this case).
Again, one should not be having any of these issues where the developers of OpenMandriva claim it’s “stable” and it’s not a hardware issue with my machine. If it were a hardware issue, I would have been having the same problems well before now. And I’ve been using Linux for long enough to know, or to be able to figure out if it’s hardware or software at fault. So please just understand that.
When are updated packages going to released to fix these issues?
Or should I just start looking for a different distro?
Edit: I believe it’s an X11 session.
Oh, so it is not possible that we do test and use OMLx ourselves but we are a small group that does not have your hardware to test on? There are users using what you claim does not work and was not tested. Users that use it because they like it and find it to be stable. There are people testing to the best of our ability and resources. Our resources are admittedly limited. As posted above we are a small group, that is both advantageous and disadvantageous. But there is a big difference in resources, people involved, and hardware available to test compared to Debian.
You haven’t given us anything to fix other than that all OM contributors are lazy idiots. We may have some disagreement on that…
If you do want some things fixed could we calm the rhetoric and get down to nuts and bolts?
Nuts and bolts would be things like system logs so we can get to a cause of the freezes. Could you please run these commands and post the files created?
$ dmesg > dmesg.txt
$ inxi -F > inxi.txt
$ sudo journalctl > journal.txt
Those will create the files dmesg.txt, inxi.txt, and journal.txt which you can post here. Maybe with logs we can find a cause and then find something to work with/on.
If you are any user are experiencing issues with any version of OMLx we certainly do wish to find the cause of the issue and correct it if at all possible.
Please answer some basic questions
Where did you download the ISO file and which one exactly (link and filename)?
Did you verify the file to confirm ISO integrity?
How did you transfer the image to the USB pendrive?
Booting to Live mode works properly or same issues as in installed system?
Any chance that re-installing will make the things better?
Random notes:
No need
sudo dnf --refresh install virtualbox
rpm -q firefox
run firefox from console and post the output
I personally have cooker, ROME and 5.0 installed on different partitions and daily using sometimes one and sometimes other.
To be honest they are all pretty well working
That’s an option too, if it’s what you wish.
Incorrect. The kernel modules are included. After sudo dnf --refresh install virtualbox you have to reboot or modprobe the virtualbox kernel modules.
$ sudo modprobe vboxdrv
$ sudo modprobe vboxnetflt
$ sudo modprobe vboxnetad
After either rebooting or modprobing the modules virtualbox will then work.
Edit: I use VirtualBox for testing things with all versions of OMLx nearly every day, And I test on hardware, that hardware being the one laptop I currently have
Addendum:
FWIW I make strong use of VirtualBox in each system I run because this lazy and idiot person, as you have implicitly stated, is testing almost every new ISO we build (cooker, rolling and rock).
Never had any issue.
Right :+1:
Hi @james
Thank you for your feedback. I understand you are not satisfied with your last experience with OpenMandriva, so please go ahead and switch distro.
No shame in being disappointed, and we are clearly not going anywhere with this discussion.
The support section is primary available to get help, not to complain. I guess you can complain while being helpt, as explained by @ben79 there are a few rules to follow to let @rugyada or other contributors help you. (Giving a few info of your system, filling a bug report, etc…)
Thank you for trying OpenMandriva Lx 5 or being a user, and best of luck for your future.
The freeze could be due to hardware acceleration by the video card. Try to disable it (compositing) in Plasma settings, switch to XRender.
Well, I tend to believe that if an user spent some time starting a topic and reporting what he/she/them feel not working maybe h/s/t does care.
To just give up and leave is not fruitful in my opinion.
OpenMandriva developers are glad to receive bug reports, they actually exhort the users to file them in order to fix issues. But they must be proper bug reports.
On the other hand a feedback just full of complaints, and not even that much veiled blaming, without providing any info useful to get help, makes me wonder what one wants to achieve with it…
Last but not least, please show a bit of respect - if not gratitude - towards people who work unpaid just for passion and make avalable stuff that you can get for free and enjoy if you like it.
That said, can we restart from scratch this discussion?
We are looking forward to read requested informations from the OP.
I don’t know if I was cursed but this happened to me this morning :sleepy: It was frozen for a long minute. Everything started by default, the notification popped up (Wifi started, VPN launched, …) and then stuck. I could only move the mouse.
Looking at the journal (journalctl -k) the cause was the proprietary apple_bcm kernel module I installed myself. I need to use a “virtual USB host controller” to access the built-in the keyboard / sound / micro / camera on the MacBook Air. Nothing related to OM core.
Here is the log :
janv. 14 12:19:18 omv kernel: usb usb4: Product: xHCI Host Controller
janv. 14 12:19:18 omv kernel: usb usb4: Manufacturer: Linux 6.6.2-desktop-1omv2390 xhci-hcd
janv. 14 12:19:18 omv kernel: usb usb4: SerialNumber: 0000:00:14.0
janv. 14 12:19:18 omv kernel: hub 4-0:1.0: USB hub found
janv. 14 12:19:18 omv kernel: hub 4-0:1.0: 6 ports detected
janv. 14 12:19:19 omv kernel: cryptd: max_cpu_qlen set to 1000
janv. 14 12:19:19 omv kernel: AVX2 version of gcm_enc/dec engaged.
janv. 14 12:19:19 omv kernel: AES CTR mode by8 optimization enabled
janv. 14 12:19:19 omv kernel: ACPI: bus type drm_connector registered
janv. 14 12:19:19 omv kernel: nvme nvme0: pci function 0000:74:00.0
janv. 14 12:19:19 omv kernel: nvme nvme0: 1/0/0 default/read/poll queues
janv. 14 12:19:19 omv kernel:  nvme0n1: p1 p2 p3 p4 p5
janv. 14 12:19:19 omv kernel: usb 3-2: new high-speed USB device number 2 using xhci_hcd
janv. 14 12:19:19 omv kernel: EXT4-fs (nvme0n1p5): orphan cleanup on readonly fs
janv. 14 12:19:19 omv kernel: EXT4-fs (nvme0n1p5): mounted filesystem 042c94c0-07a6-4acb-908e-ead19d31f50e ro with>
janv. 14 12:19:19 omv kernel: usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
janv. 14 12:19:19 omv kernel: usb 3-2: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
janv. 14 12:19:19 omv kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:19 omv kernel: usb 3-2: Product: USB2.0 Hub
janv. 14 12:19:19 omv kernel: usb 3-2: Manufacturer: VIA Labs, Inc.
janv. 14 12:19:19 omv kernel: hub 3-2:1.0: USB hub found
janv. 14 12:19:19 omv kernel: i915 0000:00:02.0: [drm] VT-d active for gfx access
janv. 14 12:19:19 omv kernel: hub 3-2:1.0: 4 ports detected
janv. 14 12:19:19 omv kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
janv. 14 12:19:19 omv kernel: i915 0000:00:02.0: [drm] Using Transparent Hugepages
janv. 14 12:19:19 omv kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:own>
janv. 14 12:19:19 omv kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/icl_dmc_ver1_09.bin (v1.>
janv. 14 12:19:19 omv kernel: usb 2-2: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
janv. 14 12:19:19 omv kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:19 omv kernel: usb 2-2: Product: USB3.0 Hub
janv. 14 12:19:19 omv kernel: usb 2-2: Manufacturer: VIA Labs, Inc.
janv. 14 12:19:19 omv kernel: hub 2-2:1.0: USB hub found
janv. 14 12:19:19 omv kernel: hub 2-2:1.0: 4 ports detected
janv. 14 12:19:19 omv kernel: usb 3-2.1: new high-speed USB device number 3 using xhci_hcd
janv. 14 12:19:19 omv kernel: usb 3-2.1: New USB device found, idVendor=2109, idProduct=d101, bcdDevice= 1.13
janv. 14 12:19:19 omv kernel: usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:19 omv kernel: usb 3-2.1: Product: USB Keyboard
janv. 14 12:19:19 omv kernel: usb 3-2.1: Manufacturer: VIA Labs, Inc.
janv. 14 12:19:19 omv kernel: usb 3-2.1: SerialNumber: 0000000000000001
janv. 14 12:19:19 omv kernel: usb 3-2.4: new high-speed USB device number 4 using xhci_hcd
janv. 14 12:19:19 omv kernel: usb 2-2.4: new SuperSpeed USB device number 3 using xhci_hcd
janv. 14 12:19:19 omv kernel: usb 3-2.4: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
janv. 14 12:19:19 omv kernel: usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:19 omv kernel: usb 3-2.4: Product: USB2.0 Hub
janv. 14 12:19:19 omv kernel: usb 3-2.4: Manufacturer: VIA Labs, Inc.
janv. 14 12:19:19 omv kernel: hub 3-2.4:1.0: USB hub found
janv. 14 12:19:19 omv kernel: hub 3-2.4:1.0: 4 ports detected
janv. 14 12:19:19 omv kernel: usb 2-2.4: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
janv. 14 12:19:19 omv kernel: usb 2-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:19 omv kernel: usb 2-2.4: Product: USB3.0 Hub
janv. 14 12:19:19 omv kernel: usb 2-2.4: Manufacturer: VIA Labs, Inc.
janv. 14 12:19:19 omv kernel: hub 2-2.4:1.0: USB hub found
janv. 14 12:19:19 omv kernel: hub 2-2.4:1.0: 4 ports detected
janv. 14 12:19:20 omv kernel: usb 3-2.4.2: new high-speed USB device number 5 using xhci_hcd
janv. 14 12:19:20 omv kernel: usb 3-2.4.2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
janv. 14 12:19:20 omv kernel: usb 3-2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:20 omv kernel: usb 3-2.4.2: Product: USB2.1 Hub
janv. 14 12:19:20 omv kernel: usb 3-2.4.2: Manufacturer: GenesysLogic
janv. 14 12:19:20 omv kernel: hub 3-2.4.2:1.0: USB hub found
janv. 14 12:19:20 omv kernel: hub 3-2.4.2:1.0: 4 ports detected
janv. 14 12:19:20 omv kernel: usb 2-2.4.2: new SuperSpeed USB device number 4 using xhci_hcd
janv. 14 12:19:20 omv kernel: usb 2-2.4.2: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.54
janv. 14 12:19:20 omv kernel: usb 2-2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:20 omv kernel: usb 2-2.4.2: Product: USB3.1 Hub
janv. 14 12:19:20 omv kernel: usb 2-2.4.2: Manufacturer: GenesysLogic
janv. 14 12:19:20 omv kernel: hub 2-2.4.2:1.0: USB hub found
janv. 14 12:19:20 omv kernel: hub 2-2.4.2:1.0: 4 ports detected
janv. 14 12:19:20 omv kernel: i915 0000:00:02.0: [drm] Skipping intel_backlight registration
janv. 14 12:19:20 omv kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
janv. 14 12:19:20 omv kernel: ACPI: video: Video Device [IGPU] (multi-head: yes  rom: no  post: no)
janv. 14 12:19:20 omv kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/in>
janv. 14 12:19:20 omv kernel: acpi device:11: registered as cooling_device4
janv. 14 12:19:20 omv kernel: usb 3-2.4.2.1: new low-speed USB device number 6 using xhci_hcd
janv. 14 12:19:20 omv kernel: fbcon: i915drmfb (fb0) is primary device
janv. 14 12:19:20 omv kernel: Console: switching to colour frame buffer device 180x56
janv. 14 12:19:20 omv kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
janv. 14 12:19:21 concorde systemd-journald[514]: Collecting audit messages is disabled.
janv. 14 12:19:21 concorde systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
janv. 14 12:19:21 concorde systemd[1]: Started systemd-journald.service - Journal Service.
janv. 14 12:19:21 concorde systemd-journald[514]: Received client request to flush runtime journal.
janv. 14 12:19:21 concorde kernel: apple_bce: loading out-of-tree module taints kernel.
janv. 14 12:19:21 concorde kernel: apple_bce: module verification failed: signature and/or required key missing - >
janv. 14 12:19:21 concorde kernel: apple-bce: capturing our device
janv. 14 12:19:21 concorde kernel: apple-bce: handshake done
janv. 14 12:19:21 concorde kernel: bce-vhci bce-vhci: BCE VHCI Host Controller
janv. 14 12:19:21 concorde kernel: bce-vhci bce-vhci: new USB bus registered, assigned bus number 5
janv. 14 12:19:21 concorde kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
janv. 14 12:19:21 concorde kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
janv. 14 12:19:21 concorde kernel: usb usb5: Product: BCE VHCI Host Controller
janv. 14 12:19:21 concorde kernel: usb usb5: Manufacturer: Linux 6.6.2-desktop-1omv2390 bce-vhci
janv. 14 12:19:21 concorde kernel: usb usb5: SerialNumber: bce-vhci
janv. 14 12:19:21 concorde kernel: hub 5-0:1.0: USB hub found
janv. 14 12:19:21 concorde kernel: hub 5-0:1.0: 10 ports detected
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=1 p2=40285
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=2 p2=40285
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=3 p2=40285
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=4 p2=40285
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=5 p2=402a5
janv. 14 12:19:21 concorde kernel: bce-vhci: Unhandled system event: 18 s=0 p1=6 p2=40285
janv. 14 12:19:21 concorde kernel: aaudio: capturing our device
janv. 14 12:19:21 concorde kernel: aaudio 0000:74:00.3: enabling device (0000 -> 0002)
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: bs len = 400000
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Received alive notification from remote
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Continuing init
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Remote device 21 Digital Mic
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Remote device 25 Codec Output
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Remote device 39 Speaker
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Remote device 3f Bridge Loopback
janv. 14 12:19:21 concorde kernel: aaudio aaudio: Remote device 44 Codec Input
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: BufferStruct ver = 3
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Num devices = 5
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 0 Bridge Loopback
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 0 Stream 0: Output; Buffer Count = 1
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 1 Speaker
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 1 Stream 0: Output; Buffer Count = 1
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 2 Codec Output
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 2 Stream 0: Output; Buffer Count = 1
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 3 Digital Mic
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 4 Codec Input
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 3 Host Stream; Input
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 0 Host Stream; Input
janv. 14 12:19:21 concorde kernel: zram0: detected capacity change from 0 to 16777216
janv. 14 12:19:21 concorde kernel: aaudio aaudio: aaudio: Device 4 Host Stream; Input
janv. 14 12:19:21 concorde systemd-journald[514]: /var/log/journal/81ae9ce976ca402890e32484389fcf55/system.journal>
janv. 14 12:19:21 concorde systemd-journald[514]: Rotating system journal.
janv. 14 12:19:21 concorde kernel: input: Apple T2 Audio Codec Output as /devices/pci0000:00/0000:00:1c.4/0000:74:>
janv. 14 12:19:21 concorde kernel: ACPI: AC: AC Adapter [ADP1] (on-line)
janv. 14 12:19:21 concorde kernel: bce_vhci_reset_device 1
janv. 14 12:19:21 concorde kernel: acpi-tad ACPI000E:00: Missing _PRW
janv. 14 12:19:21 concorde kernel: intel-lpss INT34BA:00: error -ENXIO: IRQ index 0 not found
janv. 14 12:19:21 concorde kernel: intel-lpss: probe of INT34BA:00 failed with error -22
janv. 14 12:19:21 concorde kernel: smbus_hc ACPI0001:00: SBS HC: offset = 0x20, query_bit = 0x10
janv. 14 12:19:21 concorde kernel: Adding 8388604k swap on /dev/zram0.  Priority:100 extents:1 across:8388604k SSD>
janv. 14 12:19:21 concorde kernel: vboxdrv: Found 4 processor cores/threads
janv. 14 12:19:21 concorde kernel: vboxdrv: TSC mode is Invariant, tentative frequency 1113599803 Hz
janv. 14 12:19:21 concorde kernel: vboxdrv: Successfully loaded version 7.0.12 r159484 (interface 0x00330004)
janv. 14 12:19:21 concorde kernel: VBoxNetFlt: Successfully started.
janv. 14 12:19:21 concorde kernel: VBoxNetAdp: Successfully started.
janv. 14 12:19:21 concorde kernel: EXT4-fs (nvme0n1p3): warning: maximal mount count reached, running e2fsck is re>
janv. 14 12:19:21 concorde kernel: EXT4-fs (nvme0n1p3): mounted filesystem bea4e7af-e724-da01-90a4-e7afe724da01 r/>
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: device descriptor read/64, error -71
janv. 14 12:19:21 concorde kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
janv. 14 12:19:21 concorde kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 >
janv. 14 12:19:21 concorde kernel: usb 5-1: new high-speed USB device number 2 using apple-bce
janv. 14 12:19:21 concorde kernel: bce_vhci_enable_device
janv. 14 12:19:21 concorde kernel: bce_vhci_cmd_device_create 1 -> 1
janv. 14 12:19:21 concorde kernel: ACPI: bus type thunderbolt registered
janv. 14 12:19:21 concorde kernel: bce-vhci: Not implemented: wait for pending output requests
janv. 14 12:19:21 concorde kernel: thunderbolt 0000:00:0d.2: can't derive routing for PCI INT A
janv. 14 12:19:21 concorde kernel: thunderbolt 0000:00:0d.2: PCI INT A: not connected
janv. 14 12:19:21 concorde kernel: thunderbolt 0000:00:0d.2: device links to tunneled native ports are missing!
janv. 14 12:19:21 concorde kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
janv. 14 12:19:21 concorde kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
janv. 14 12:19:21 concorde kernel: i2c i2c-15: 2/2 memory slots populated (from DMI)
janv. 14 12:19:21 concorde kernel: Bluetooth: Core ver 2.22
janv. 14 12:19:21 concorde kernel: NET: Registered PF_BLUETOOTH protocol family
janv. 14 12:19:21 concorde kernel: Bluetooth: HCI device and connection manager initialized
janv. 14 12:19:21 concorde kernel: Bluetooth: HCI socket layer initialized
janv. 14 12:19:21 concorde kernel: Bluetooth: L2CAP socket layer initialized
janv. 14 12:19:21 concorde kernel: Bluetooth: SCO socket layer initialized
janv. 14 12:19:21 concorde kernel: hci_bcm4377 0000:73:00.1: can't disable ASPM; OS doesn't have ASPM control
janv. 14 12:19:21 concorde kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
janv. 14 12:19:21 concorde kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
janv. 14 12:19:21 concorde kernel: FAT-fs (nvme0n1p1): utf8 is not a recommended IO charset for FAT filesystems, f>
janv. 14 12:19:21 concorde kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
janv. 14 12:19:21 concorde kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_o>
janv. 14 12:19:21 concorde kernel: hid: raw HID events driver (C) Jiri Kosina
janv. 14 12:19:21 concorde kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
janv. 14 12:19:21 concorde kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
janv. 14 12:19:21 concorde kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
janv. 14 12:19:21 concorde kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
janv. 14 12:19:21 concorde kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/ca>
janv. 14 12:19:21 concorde kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/ca>
janv. 14 12:19:21 concorde kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/ca>
janv. 14 12:19:21 concorde kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/ca>
janv. 14 12:19:21 concorde kernel: usbcore: registered new interface driver brcmfmac
janv. 14 12:19:21 concorde kernel: brcmfmac 0000:73:00.0: enabling device (0000 -> 0002)
janv. 14 12:19:21 concorde kernel: usb 5-1: New USB device found, idVendor=05ac, idProduct=8233, bcdDevice= 2.01
janv. 14 12:19:21 concorde kernel: usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:21 concorde kernel: usb 5-1: Product: Apple T2 Controller
janv. 14 12:19:21 concorde kernel: usb 5-1: Manufacturer: Apple Inc.
janv. 14 12:19:21 concorde kernel: usb 5-1: SerialNumber: 0000000000000000
janv. 14 12:19:21 concorde kernel: bce_vhci_reset_device 2
janv. 14 12:19:21 concorde kernel: usbcore: registered new interface driver usbhid
janv. 14 12:19:21 concorde kernel: usbhid: USB HID core driver
janv. 14 12:19:21 concorde kernel: ACPI: Smart Battery System [SBS0]: Battery Slot [BAT0] (battery present)
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: new low-speed USB device number 7 using xhci_hcd
janv. 14 12:19:21 concorde kernel: intel_tcc_cooling: TCC Offset locked
janv. 14 12:19:21 concorde kernel: intel_rapl_common: Found RAPL domain package
janv. 14 12:19:21 concorde kernel: intel_rapl_common: Found RAPL domain core
janv. 14 12:19:21 concorde kernel: intel_rapl_common: Found RAPL domain uncore
janv. 14 12:19:21 concorde kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4377b3-pcie for chip BCM43>
janv. 14 12:19:21 concorde kernel: brcmfmac 0000:73:00.0: Direct firmware load for brcm/brcmfmac4377b3-pcie.apple,>
janv. 14 12:19:21 concorde kernel: brcmfmac 0000:73:00.0: Direct firmware load for brcm/brcmfmac4377b3-pcie.txcap_>
janv. 14 12:19:21 concorde kernel: usb 5-2: new high-speed USB device number 3 using apple-bce
janv. 14 12:19:21 concorde kernel: bce_vhci_cmd_device_create 2 -> 2
janv. 14 12:19:21 concorde kernel: iTCO_vendor_support: vendor-support=0
janv. 14 12:19:21 concorde kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f4 0c 58 12 03 00
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: New USB device found, idVendor=045e, idProduct=077d, bcdDevice= >
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: Product: Comfort Mouse 6000
janv. 14 12:19:21 concorde kernel: usb 3-2.4.2.1: Manufacturer: Microsoft
janv. 14 12:19:21 concorde kernel: hci_bcm4377 0000:73:00.1: enabling device (0000 -> 0002)
janv. 14 12:19:21 concorde kernel: hid-generic 0003:2109:D101.0001: hiddev0,hidraw0: USB HID v1.10 Device [VIA Lab>
janv. 14 12:19:21 concorde kernel: iTCO_wdt iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/>
janv. 14 12:19:21 concorde kernel: hci_bcm4377 0000:73:00.1: Unable to load firmware; tried 'brcm/brcmbt4377b3-app>
janv. 14 12:19:21 concorde kernel: hci_bcm4377 0000:73:00.1: Failed to load firmware
janv. 14 12:19:21 concorde kernel: hci_bcm4377: probe of 0000:73:00.1 failed with error -2
janv. 14 12:19:21 concorde kernel: input: Microsoft Comfort Mouse 6000 Consumer Control as /devices/pci0000:00/000>
janv. 14 12:19:21 concorde kernel: input: Microsoft Comfort Mouse 6000 Mouse as /devices/pci0000:00/0000:00:14.0/u>
janv. 14 12:19:21 concorde kernel: hid-generic 0003:045E:077D.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft >
janv. 14 12:19:22 concorde kernel: bce_vhci_enable_device
janv. 14 12:19:22 concorde kernel: usb 5-2: New USB device found, idVendor=05ac, idProduct=8514, bcdDevice= 2.01
janv. 14 12:19:22 concorde kernel: usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:22 concorde kernel: usb 5-2: Product: FaceTime HD Camera (Built-in)
janv. 14 12:19:22 concorde kernel: usb 5-2: Manufacturer: Apple Inc.
janv. 14 12:19:22 concorde kernel: usb 5-2: SerialNumber: CC201940ADMK0CH4Y
janv. 14 12:19:22 concorde kernel: bce_vhci_reset_device 3
janv. 14 12:19:22 concorde kernel: thunderbolt: probe of 0000:00:0d.2 failed with error -110
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.2: new high-speed USB device number 8 using xhci_hcd
janv. 14 12:19:22 concorde kernel: usb 5-3: new high-speed USB device number 4 using apple-bce
janv. 14 12:19:22 concorde kernel: bce_vhci_cmd_device_create 3 -> 3
janv. 14 12:19:22 concorde kernel: bce-vhci: Not implemented: wait for pending output requests
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.2: New USB device found, idVendor=0500, idProduct=9131, bcdDevice= >
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
janv. 14 12:19:22 concorde kernel: hub 3-2.4.2.2:1.0: USB hub found
janv. 14 12:19:22 concorde kernel: hub 3-2.4.2.2:1.0: 3 ports detected
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.3: new full-speed USB device number 9 using xhci_hcd
janv. 14 12:19:22 concorde kernel: usb 5-3: New USB device found, idVendor=05ac, idProduct=8262, bcdDevice= 2.01
janv. 14 12:19:22 concorde kernel: usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:22 concorde kernel: usb 5-3: Product: Ambient Light Sensor
janv. 14 12:19:22 concorde kernel: usb 5-3: Manufacturer: Apple Inc.
janv. 14 12:19:22 concorde kernel: usb 5-3: SerialNumber: 000000000000
janv. 14 12:19:22 concorde kernel: hid-generic 0003:05AC:8262.0003: hiddev1,hidraw2: USB HID v1.01 Device [Apple I>
janv. 14 12:19:22 concorde kernel: bce_vhci_reset_device 4
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.3: New USB device found, idVendor=0d8c, idProduct=0014, bcdDevice= >
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.3: Product: USB Audio Device
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.3: Manufacturer: C-Media Electronics Inc.
janv. 14 12:19:22 concorde kernel: input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00>
janv. 14 12:19:22 concorde kernel: usb 5-4: new high-speed USB device number 5 using apple-bce
janv. 14 12:19:22 concorde kernel: bce_vhci_cmd_device_create 4 -> 4
janv. 14 12:19:22 concorde kernel: hid-generic 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media E>
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.2.2: new full-speed USB device number 10 using xhci_hcd
janv. 14 12:19:22 concorde kernel: brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
janv. 14 12:19:22 concorde kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4377/4 wl0: Jan 14 2023 01:22:18 >
janv. 14 12:19:22 concorde kernel: usb 5-4: New USB device found, idVendor=05ac, idProduct=8103, bcdDevice= 2.15
janv. 14 12:19:22 concorde kernel: usb 5-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:22 concorde kernel: usb 5-4: Product: Headset
janv. 14 12:19:22 concorde kernel: usb 5-4: Manufacturer: Apple
janv. 14 12:19:22 concorde kernel: usb 5-4: SerialNumber: 000000000000
janv. 14 12:19:22 concorde kernel: input: Apple Headset as /devices/pci0000:00/0000:00:1c.4/0000:74:00.1/apple-bce>
janv. 14 12:19:22 concorde kernel: brcmfmac 0000:73:00.0 wlp115s0f0: renamed from wlan0
janv. 14 12:19:22 concorde kernel: hid-generic 0003:05AC:8103.0005: input,hidraw4: USB HID v1.01 Device [Apple Hea>
janv. 14 12:19:22 concorde kernel: bce_vhci_reset_device 5
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.4: new low-speed USB device number 11 using xhci_hcd
janv. 14 12:19:22 concorde kernel: usb 5-5: new high-speed USB device number 6 using apple-bce
janv. 14 12:19:22 concorde kernel: bce_vhci_cmd_device_create 5 -> 5
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.4: New USB device found, idVendor=1a2c, idProduct=4324, bcdDevice= >
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.4: Product: USB Keyboard
janv. 14 12:19:22 concorde kernel: usb 3-2.4.2.4: Manufacturer: SEM
janv. 14 12:19:22 concorde kernel: input: SEM USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.4/3-2.>
janv. 14 12:19:22 concorde kernel: hid-generic 0003:1A2C:4324.0006: input,hidraw5: USB HID v1.10 Keyboard [SEM USB>
janv. 14 12:19:22 concorde kernel: input: SEM USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/us>
janv. 14 12:19:22 concorde kernel: input: SEM USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb3>
janv. 14 12:19:22 concorde kernel: hid-generic 0003:1A2C:4324.0007: input,hidraw6: USB HID v1.10 Device [SEM USB K>
janv. 14 12:19:22 concorde kernel: usb 5-5: New USB device found, idVendor=05ac, idProduct=0280, bcdDevice= 9.20
janv. 14 12:19:22 concorde kernel: usb 5-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:22 concorde kernel: usb 5-5: Product: Apple Internal Keyboard / Trackpad
janv. 14 12:19:22 concorde kernel: usb 5-5: Manufacturer: Apple Inc.
janv. 14 12:19:22 concorde kernel: usb 5-5: SerialNumber: FM7018701AJN1QYA7+HDB
janv. 14 12:19:22 concorde kernel: mc: Linux media interface: v0.10
janv. 14 12:19:22 concorde kernel: bce_vhci_reset_device 6
janv. 14 12:19:22 concorde kernel: cmedia_hs100b 0003:0D8C:0014.0004: Fixing CMedia HS-100B report descriptor
janv. 14 12:19:22 concorde kernel: usbcore: registered new interface driver snd-usb-audio
janv. 14 12:19:22 concorde kernel: cmedia_hs100b 0003:0D8C:0014.0004: input,hidraw3: USB HID v1.00 Device [C-Media>
janv. 14 12:19:22 concorde kernel: dbus-broker-lau[822]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL>
janv. 14 12:19:23 concorde kernel: usb 5-6: new high-speed USB device number 7 using apple-bce
janv. 14 12:19:23 concorde kernel: bce_vhci_enable_device
janv. 14 12:19:23 concorde kernel: bce_vhci_cmd_device_create 6 -> 6
janv. 14 12:19:23 concorde kernel: bce_vhci_reset_device 6
janv. 14 12:19:23 concorde kernel: bce-vhci: Not implemented: wait for pending output requests
janv. 14 12:19:23 concorde kernel: usb 5-6: New USB device found, idVendor=05ac, idProduct=8102, bcdDevice= 2.01
janv. 14 12:19:23 concorde kernel: usb 5-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
janv. 14 12:19:23 concorde kernel: usb 5-6: Product: Touch Bar Backlight
janv. 14 12:19:23 concorde kernel: usb 5-6: Manufacturer: Apple Inc.
janv. 14 12:19:23 concorde kernel: usb 5-6: SerialNumber: 0000000000000000
janv. 14 12:19:23 concorde kernel: usbcore: registered new device driver apple-mfi-fastcharge
janv. 14 12:19:23 concorde kernel: apple 0003:05AC:0280.0008: hiddev2,hidraw7: USB HID v1.01 Device [Apple Inc. Ap>
janv. 14 12:19:23 concorde kernel: hid-sensor-hub 0003:05AC:8262.0003: hiddev1,hidraw2: USB HID v1.01 Device [Appl>
janv. 14 12:19:23 concorde kernel: usbcore: registered new interface driver cdc_mbim
janv. 14 12:19:23 concorde kernel: usbcore: registered new interface driver cdc_wdm
janv. 14 12:19:23 concorde kernel: cdc_ncm 5-1:1.0 enp116s0f1u1: renamed from eth0
janv. 14 12:19:23 concorde kernel: NET: Registered PF_PACKET protocol family
janv. 14 12:19:23 concorde kernel: ieee80211 phy0: brcmf_p2p_set_firmware: failed to update device address ret -52
janv. 14 12:19:23 concorde kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: set p2p_disc error
janv. 14 12:19:23 concorde kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlp115s type 10 failed: err=-52
janv. 14 12:19:24 concorde kernel: usb 3-2.4.2.2: clear tt 2 (8090) error -71
janv. 14 12:19:25 concorde kernel: usb 3-2.4.2.2: clear tt 2 (8090) error -71
janv. 14 12:19:25 concorde kernel: usb 3-2.4.2.2.2: New USB device found, idVendor=05ac, idProduct=9223, bcdDevice= 1.14
janv. 14 12:19:25 concorde kernel: usb 3-2.4.2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
janv. 14 12:19:25 concorde kernel: usb 3-2.4.2.2.2: Product: Apple Cinema HD Display
janv. 14 12:19:25 concorde kernel: usb 3-2.4.2.2.2: can't set config #1, error -71
janv. 14 12:19:37 concorde systemd-journald[514]: /var/log/journal/81ae9ce976ca402890e32484389fcf55/user-1001.journal: Journal file uses a different >
janv. 14 12:19:39 concorde kernel: aaudio_pcm_pointer while not started
janv. 14 12:19:39 concorde kernel: warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
janv. 14 12:19:40 concorde kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
janv. 14 12:19:40 concorde kernel: Bluetooth: BNEP filters: protocol multicast
janv. 14 12:19:40 concorde kernel: Bluetooth: BNEP socket layer initialized
janv. 14 12:19:49 concorde kernel: tun: Universal TUN/TAP device driver, 1.6
janv. 14 12:17:41 concorde systemd-journald[514]: Time jumped backwards, rotating.
janv. 14 12:18:04 concorde kernel: applesmc: probe of applesmc.768 failed with error -5
janv. 14 12:18:53 concorde kernel: usb 3-2.4.2-port1: cannot reset (err = -71)
janv. 14 12:18:53 concorde kernel: usb 3-2.4.2.1: reset low-speed USB device number 7 using xhci_hcd
janv. 14 12:18:54 concorde kernel: usb 3-2.4.2.3: reset full-speed USB device number 9 using xhci_hcd
janv. 14 12:18:54 concorde kernel: usb 3-2.4.2.3: 1:0: usb_set_interface failed (-71)
janv. 14 12:18:58 concorde kernel: applesmc: driver init failed (ret=-5)!
Needed to reboot for me and everything’s back to normal :sunglasses:
@artenaki Indeed disabling compositor might be a start, I’m curious on how do you do that if you can’t access the control panel. You launch / boot in “safe mode / recovery mode” ? :thinking:
Not to say systemd is not perfect in every respect but that is normal solution to problems like that. Sometimes something does not go right in systemd and it is best to just reboot and let it start over.
