@WilsonPhillips @zeroability @richp @LeeTalbert
Hi All Hope you are well. I did a clean install today of OMLx…
After installing the Nvidia driver I had a NOTICEABLE increase in Plasmashell crashes.
OM boots, gets to the user password screen and I enter my password and sometimes a few seconds after loading the desktop or minutes after loading the desktop the plasmashell will crash all on its own, other times the plasmashell will crash while I am starting up an application like dolphine or Konsol.
I installed KDbg and have a crash report that I will post below…
This has been happening on and off now for quite a few times. After the crash I type in ctrl+alt+F4 I then enter my user, my password and then type in sudo reboot now and then my password and the PC will reboot, sometimes the user password screen will come up after reboot and I can enter my password other times it will just crash right at the screen… As I am a total noob I do not know what to do here…
Any help welcome. Crash report below
Application: plasmashell (plasmashell), signal: Segmentation fault
warning: Can't open file /memfd:JSGCHeap:QtQml (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:JITCode:QtQml (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:unknown-usage:QtQml (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:/.nvidia_drv.XXXXXX (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:/.glXXXXXX (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:JSVMStack:QtQml (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:pulseaudio (deleted) during file-backed mapping note processing
[New LWP 1606]
[New LWP 1378]
[New LWP 1487]
[New LWP 1395]
[New LWP 1396]
[New LWP 1602]
[New LWP 1597]
[New LWP 1607]
[New LWP 1608]
[New LWP 1501]
[New LWP 1603]
[New LWP 1610]
warning: could not convert 'main' from the host encoding (ISO-8859-1) to UTF-32.
This normally should not happen, please file a bug report.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Core was generated by `/usr/bin/plasmashell --no-respawn'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f88688a246c in __pthread_kill_implementation () from /lib64/libc.so.6
[Current thread is 1 (Thread 0x7f8832bfe6c0 (LWP 1606))]
/tmp/drkonqi.wOSnib:3: Error in sourced command file:
/usr/share/drkonqi/gdb/python/gdb_preamble/preamble.py:4: Error in sourced command file:
Undefined command: "import". Try "help".
Thread 12 (Thread 0x7f881a9ff6c0 (LWP 1610)):
#0 0x00007f8868918ecb in ioctl () from /lib64/libc.so.6
#1 0x00007f885ad2b410 in ?? () from /lib64/libnvidia-glcore.so.565.77
#2 0x00007f885adc9437 in ?? () from /lib64/libnvidia-glcore.so.565.77
#3 0x00007f885a863b5f in ?? () from /lib64/libnvidia-glcore.so.565.77
#4 0x00007f885a87b3e3 in ?? () from /lib64/libnvidia-glcore.so.565.77
#5 0x00007f885a851b02 in ?? () from /lib64/libnvidia-glcore.so.565.77
#6 0x00007f885a82394d in ?? () from /lib64/libnvidia-glcore.so.565.77
#7 0x00007f885a812864 in ?? () from /lib64/libnvidia-glcore.so.565.77
#8 0x00007f88688a072a in start_thread () from /lib64/libc.so.6
#9 0x00007f886891d258 in __clone3 () from /lib64/libc.so.6
Thread 11 (Thread 0x7f88333ff6c0 (LWP 1603)):
#0 0x00007f8868910266 in ppoll () from /lib64/libc.so.6
#1 0x00007f88692befff in qt_safe_poll(pollfd*, unsigned long, QDeadlineTimer) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#2 0x00007f88681cb2ca in QNativeSocketEngine::waitForReadOrWrite(bool*, bool*, bool, bool, QDeadlineTimer, bool*) () from /usr/lib64/qt6/lib/libQt6Network.so.6
#3 0x00007f88681c4260 in QAbstractSocket::waitForReadyRead(int) () from /usr/lib64/qt6/lib/libQt6Network.so.6
#4 0x00007f886831842b in KIO::Connection::waitForIncomingTask(int) () from /lib64/libKF6KIOCore.so.6
#5 0x00007f8868359035 in KIO::SlaveBase::dispatchLoop() () from /lib64/libKF6KIOCore.so.6
#6 0x00007f88683d80cd in KIO::WorkerThread::run() () from /lib64/libKF6KIOCore.so.6
#7 0x00007f88692c1aca in QThreadPrivate::start(void*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
Thread 10 (Thread 0x7f884a5ff6c0 (LWP 1501)):
#1 0x00007f8867b0f9cc in g_main_context_iterate_unlocked () from /lib64/libglib-2.0.so.0
#2 0x00007f8867b791e8 in g_main_context_iteration () from /lib64/libglib-2.0.so.0
#3 0x00007f88693d794e in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#4 0x00007f886910ce65 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#5 0x00007f886921ce27 in QThread::exec() () from /usr/lib64/qt6/lib/libQt6Core.so.6
#6 0x00007f886ab12907 in QQuickPixmapReader::run() () from /usr/lib64/qt6/lib/libQt6Quick.so.6
Thread 9 (Thread 0x7f8831bfc6c0 (LWP 1608)):
#0 0x00007f886889d1ee in __futex_abstimed_wait_common () from /lib64/libc.so.6
#1 0x00007f886889fc95 in pthread_cond_timedwait () from /lib64/libc.so.6
#2 0x00007f88692d0207 in QWaitConditionPrivate::wait(QDeadlineTimer) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#3 0x00007f88692d0339 in QWaitCondition::wait(QMutex*, QDeadlineTimer) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#4 0x00007f88692c8cd3 in QThreadPoolThread::run() () from /usr/lib64/qt6/lib/libQt6Core.so.6
#5 0x00007f88692c1aca in QThreadPrivate::start(void*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#6 0x00007f88688a072a in start_thread () from /lib64/libc.so.6
#7 0x00007f886891d258 in __clone3 () from /lib64/libc.so.6
Thread 8 (Thread 0x7f88323fd6c0 (LWP 1607)):
Thread 7 (Thread 0x7f884973f6c0 (LWP 1597)):
#0 0x00007f886890fd2f in poll () from /lib64/libc.so.6
#1 0x00007f8849cac4f9 in _Z4pollP6pollfdU17pass_object_size1mi (__fds=0x7f88340071a0, __nfds=2, __timeout=-1) at /usr/include/bits/poll2.h:44
#2 poll_func (ufds=0x7f88340071a0, nfds=2, timeout=-1, userdata=0x55ea9a39dc70) at ../src/pulse/thread-mainloop.c:70
#3 0x00007f8849c99d7c in pa_mainloop_poll (m=0x55ea9a379180) at ../src/pulse/mainloop.c:863
#4 0x00007f8849cac9d9 in pa_mainloop_iterate (m=0x55ea9a379180, block=1, retval=0x0) at ../src/pulse/mainloop.c:945
#5 pa_mainloop_run (m=0x55ea9a379180, retval=0x0) at ../src/pulse/mainloop.c:963
#6 thread (userdata=0x55ea9a3755c0) at ../src/pulse/thread-mainloop.c:101
#7 0x00007f88499eaf57 in internal_thread_func (userdata=<optimized out>) at ../src/pulsecore/thread-posix.c:81
Thread 6 (Thread 0x7f88397ff6c0 (LWP 1602)):
#6 0x00007f8839b11165 in KCupsConnection::run() () from /lib64/libkcupslib.so.6.2.5
Thread 5 (Thread 0x7f88621fe6c0 (LWP 1396)):
#1 0x00007f886b9559e2 in ?? () from /lib64/libxcb.so.1
#2 0x00007f886b958759 in xcb_wait_for_event () from /lib64/libxcb.so.1
#3 0x00007f8864bc0b34 in QXcbEventQueue::run() () from /usr/lib64/qt6/lib/libQt6XcbQpa.so.6
#4 0x00007f88692c1aca in QThreadPrivate::start(void*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#5 0x00007f88688a072a in start_thread () from /lib64/libc.so.6
#6 0x00007f886891d258 in __clone3 () from /lib64/libc.so.6
Thread 4 (Thread 0x7f88629ff6c0 (LWP 1395)):
#6 0x00007f886959d395 in QDBusConnectionManager::run() () from /usr/lib64/qt6/lib/libQt6DBus.so.6
Thread 3 (Thread 0x7f886089d6c0 (LWP 1487)):
#6 0x00007f88692c1aca in QThreadPrivate::start(void*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#7 0x00007f88688a072a in start_thread () from /lib64/libc.so.6
#8 0x00007f886891d258 in __clone3 () from /lib64/libc.so.6
Thread 2 (Thread 0x7f8864c38500 (LWP 1378)):
#1 0x00007f886889f980 in pthread_cond_wait () from /lib64/libc.so.6
#2 0x00007f88692d019b in QWaitConditionPrivate::wait(QDeadlineTimer) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#4 0x00007f886abd20a2 in QSGThreadedRenderLoop::polishAndSync(QSGThreadedRenderLoop::Window*, bool) () from /usr/lib64/qt6/lib/libQt6Quick.so.6
#5 0x00007f886abd0327 in QSGThreadedRenderLoop::exposureChanged(QQuickWindow*) () from /usr/lib64/qt6/lib/libQt6Quick.so.6
#6 0x00007f886997ecc7 in QWindow::event(QEvent*) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#7 0x00007f886aa0017d in QQuickWindow::event(QEvent*) () from /usr/lib64/qt6/lib/libQt6Quick.so.6
#8 0x00007f886b2d582d in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt6/lib/libQt6Widgets.so.6
#9 0x00007f886b2d359a in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt6/lib/libQt6Widgets.so.6
#10 0x00007f88690fcd61 in QCoreApplication::notifyInternal2(QObject*, QEvent*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#11 0x00007f8869928995 in QGuiApplicationPrivate::processExposeEvent(QWindowSystemInterfacePrivate::ExposeEvent*) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#12 0x00007f886998659a in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#13 0x00007f8864bbfdfe in xcbSourceDispatch(_GSource*, int (*)(void*), void*) () from /usr/lib64/qt6/lib/libQt6XcbQpa.so.6
#14 0x00007f8867b31b94 in g_main_context_dispatch_unlocked () from /lib64/libglib-2.0.so.0
#15 0x00007f8867b0fa20 in g_main_context_iterate_unlocked () from /lib64/libglib-2.0.so.0
#16 0x00007f8867b791e8 in g_main_context_iteration () from /lib64/libglib-2.0.so.0
#17 0x00007f88693d794e in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#18 0x00007f886910ce65 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#19 0x00007f88691039c1 in QCoreApplication::exec() () from /usr/lib64/qt6/lib/libQt6Core.so.6
#20 0x000055ea74b29783 in main ()
Thread 1 (Thread 0x7f8832bfe6c0 (LWP 1606)):
[KCrash Handler]
#4 0x00007f885a93bb95 in ?? () from /lib64/libnvidia-glcore.so.565.77
#5 0x00007f885a5c7e00 in ?? () from /lib64/libnvidia-glcore.so.565.77
#6 0x00007f885a5c94ac in ?? () from /lib64/libnvidia-glcore.so.565.77
#7 0x00007f885a5c96f4 in ?? () from /lib64/libnvidia-glcore.so.565.77
#8 0x00007f8869ca8eee in QRhiGles2::bindCombinedSampler(QGles2CommandBuffer*, QGles2Texture*, QGles2Sampler*, void*, unsigned int, int, int*, bool*) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#9 0x00007f8869ca8646 in QRhiGles2::executeCommandBuffer(QRhiCommandBuffer*) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#10 0x00007f8869c9c792 in QRhiGles2::endFrame(QRhiSwapChain*, QFlags<QRhi::EndFrameFlag>) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#11 0x00007f8869b3719e in QRhi::endFrame(QRhiSwapChain*, QFlags<QRhi::EndFrameFlag>) () from /usr/lib64/qt6/lib/libQt6Gui.so.6
#12 0x00007f886abccf25 in QSGRenderThread::run() () from /usr/lib64/qt6/lib/libQt6Quick.so.6
#13 0x00007f88692c1aca in QThreadPrivate::start(void*) () from /usr/lib64/qt6/lib/libQt6Core.so.6
#14 0x00007f88688a072a in start_thread () from /lib64/libc.so.6
#15 0x00007f886891d258 in __clone3 () from /lib64/libc.so.6
Installed packages:
Regards C
EDIT:
I just plugged in my second screen and it crashed plasmashell again just by plugging in my second monitor.
Below a screenshot of the crashes so far. The log below of the newest one.
PID: 1933 (xdg-desktop-por)
UID: 1001 (cg)
GID: 1006 (cg)
Signal: 6 (ABRT)
Timestamp: Sat 2025-01-25 14:49:05 CAT (3min 43s ago)
Command Line: /usr/lib64/libexec/xdg-desktop-portal-kde
Executable: /usr/lib64/libexec/xdg-desktop-portal-kde
Control Group: /user.slice/user-1001.slice/user@1001.service/session.slice/plasma-xdg-desktop-portal-kde.service
Unit: user@1001.service
User Unit: plasma-xdg-desktop-portal-kde.service
Slice: user-1001.slice
Owner UID: 1001 (cg)
Boot ID: a3b4d8c3e8ab467caa8902e4ebb1e428
Machine ID: fc9729bbf753417b954abdf9e4f3ba39
Hostname: cgpc
Storage: /var/lib/systemd/coredump/core.xdg-desktop-por.1001.a3b4d8c3e8ab467caa8902e4ebb1e428.1933.1737809345000000.zst (present)
Size on Disk: 1M
Message: Process 1933 (xdg-desktop-por) of user 1001 dumped core.
Stack trace of thread 1933:
#0 0x00007f403eea246c __pthread_kill_implementation (libc.so.6 + 0x9246c)
#1 0x00007f403ee4f1d2 raise (libc.so.6 + 0x3f1d2)
#2 0x00007f403ee384b0 abort (libc.so.6 + 0x284b0)
#3 0x00007f403f664436 _Z6qAbortv (libQt6Core.so.6 + 0x264436)
#4 0x00007f403f66a1b7 _ZL10qt_message9QtMsgTypeRK18QMessageLogContextPKcP13__va_list_tag (libQt6Core.so.6 + 0x26a1b7)
#5 0x00007f403f6722b7 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x2722b7)
#6 0x00007f403ff1bfa6 _ZL13init_platformRK7QStringS1_S1_RiPPc (libQt6Gui.so.6 + 0x31bfa6)
#7 0x00007f403ff17a90 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt6Gui.so.6 + 0x317a90)
#8 0x00007f403ff1e87f _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x31e87f)
#9 0x00007f403f7021da _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x3021da)
#10 0x00007f403ff15abe _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x315abe)
#11 0x00007f40408d2851 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0x2d2851)
#12 0x000056511636667c n/a (n/a + 0x0)
ELF object binary architecture: AMD x86-64
Regards C
