dnf install lib64yui-mga8-qt
Please don’t add that as a hard dependency in the spec because you can use the ncurses version as well (unset DISPLAY or launch it from a text mode prompt)…
I installed python-yaml, lib64yui-mga8-qt, and then dnfdragora. Yet somehow happiness is elusive.
Konsole output of dnfdragora:
dnfdragora-konsole.txt (5.8 KB)
Post-edit: Worth noting is that after I close dnfdragora something called dnfdaemon-syste is not closed:
Which will lead to this next time I try to run dnfdragora:
Which may be another bug perhaps?
In a fresh install of latest ISO 2348 I still have to install manually python-yaml, lib64yui-mga8-qt then install dnfdragora but then it bleeping works.
