Just to report, kinfocenter is always freezing in live mode when one tries to figure out vídeo properties…
Well they aren’t written exactly correct should be:
- Does ISO boot to systemd.unit=multi-user.target?
- Does ISO boot to systemd.unit=graphical.target?
They are for changing target environment at boot time as described here. There is some short description here and here.
Arguably we should be asking if we should add rescue.target and/or multi-user.target options to grub2 menu for out iso’s? Don’t think this would be hard to do and doesn’t it make some sense? rescue.target maybe makes most sense?
@mrnhmath did you get this sorted or are you still having problems?
Translating last image:
Installation failed:
The installer could not create partitions at NVMe Device …
… and translating that right menas:
the installer could not create swap on the device because the device
itself was busy… Which usually means something mounted , or a different
operation did ‘something’ with the device.
