Need to install 88x2bu rtl driver
  • OpenMandriva Lx version:
    Rome
KDE and Icewm
    cc command not found when manual installion and when i use installer script
    i encounter this error
Error! Bad return status for module build on kernel: 6.13.0-desktop-0.rc1.1omv2490 (x86_64)
Consult /var/lib/dkms/rtl88x2bu/5.13.1/build/make.log for more information.
Command exited with non-zero status 10
Compile time: 1.03 seconds
An error occurred. dkms build error: 10
Please report this error.
Please copy all screen output and paste it into the problem report.
Run the following before reattempting installation.
$ sudo ./remove-driver.sh
Welcome @dengesizkokarca to OpenMandriva and our forum. This forum is for users of OpenMandriva Linux operating systems.
How can someone reproduce what you are trying to do? Also [Forum] How to post code as code. You can go back and edit previous posts to mark code as code. It really helps.
For help with wireless drivers you would get a much faster answer in OM-Chat. Edit: This forum is mostly users helping other users. If you need a wireless driver that is not already in the Linux kernel you need developer help.
Fork of rtl88x2bu driver for clang
Does it help?
I tried in past but it failed cant renember error. later i used rincat’s 88x2bu i could install but it may be not correctly working.
