How to use ABF to build rpms
in github do you have a 2014.0 branch?
have you this configuration here
@luca No, I haven’t. It is mandatory?
@jojodu34 yes I have the same configuration.
Here is an example of the error. I also tried with a customized live of openmandriva 2014.0 and I got the same error so I think it isn’t an abf issue but a rpmbuild.
I’m not sure, but take a look at another project present in 2014.0/3.0/cooker
I see
Building target platforms: x86_64
Fetching(Source0): https://github.com/bwalex/tc-play/archive/v2.0.tar.gz
error: Fetching Source0 failed: Unknown or unexpected error
error: Missing Source0: v2.0.tar.gz: No such file or directory
seems bad address or bad name something like that
The same woks in 3.0
So I’ll try.
maybe v2.0.tar.gz and tc-play-2.0.tar.gz names differs? and that is a problem?
I’ve seen that in 3.0 works:
–2016-08-15 16:54:52-- https://github.com/bwalex/tc-play/archive/v2.0.tar.gz
Resolving github.com (github.com)… 192.30.253.113
Connecting to github.com (github.com)|192.30.253.113|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://codeload.github.com/bwalex/tc-play/tar.gz/v2.0 [following]
–2016-08-15 16:54:53-- https://codeload.github.com/bwalex/tc-play/tar.gz/v2.0
Resolving codeload.github.com (codeload.github.com)… 192.30.253.120
Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443… connected.
try with
In any way putting that link in the browser works. The link with the full name doesn’t work.
Usually github uses a link containing only the version number but when you click on it using a browser it saves an archive with the name and the version. This doesn’t happened with wget, of course. But the archive in the OpenMandriva file-store contains the full name so I use the full name in the file .abf.yml and the real link in the spec. I don’t know if it is the right way.
I already tried this but is doesn’t solve. I also tried with another package using a direct link to the file (i.e. without redirections) but I got a similar error.
It fails even with branches :cry:
seem solved refering to file store
+Source0: tc-play-2.0.tar.gz
at least in 2014.0, maybe stop to work in 3.0 :wink:
So I must pay more attention to the name of the archive before to load in file-store, at least for 2014.x.
Thank you!
I was following the tutorial but I had this problem where the site http://file-store.openmandriva.org does not show the option to search for the file
as you can see in this screenshot
Add files does not work?
Nor drag&drop?
in the tutorial he asks to look for the sha1 file (dos2unix) on the site but doesn’t have the option to search the site
Look at this post: https://forum3.openmandriva.org/t/how-can-humble-user-upgrade-packages/2518/2
I have also similar question, like how can I get the sha 1 file. with out the file will it be possible to move forward, that I want to build in https://penmypaper.com/. Looking for the answer, and thanks in advance.
