I guess it is because meld has never been rebuild in OpenMandriva ABF. How should I proceed in this case?
the best way to proceed in this case is to go to the github of opendriva Association
and then you look for the project. (Find a repository …)
with a search with “meld” you have two responses
you can fork meld in your github
I pushed meld 3.16.1 in file store (fe003ba49433a735713bf93f06994e480b45384d )
see here GitHub - joeltess/meld
with no change except version I tried a build with no success. the reason is at least the spec file use make ! (very old version in fact)
so you have to change spec file
ex:
for build something like
%build
CFLAGS=“%{optflags}” python setup.py build
for install something like
%install
%{__python} setup.py install --root %{buildroot} --install-purelib=%{python_sitelib}
I have no time to go further. it is best to take inspiration from a spec file of a python 2 module
good luck ![]()
log in into abf, then project like this
you see your project, choose settings of the project you want change
push red erase button
about your bug https://issues.openmandriva.org/show_bug.cgi?id=1772
I use qupzilla always and I have not this problem
maybe a cache problem
try this adress ABF
Thank you. I did so.
In this case my ABF repo has not been synchronized with my github account. (Is is not a problem, I’ll wait for the fist build)
I erased null project from my ABF account but the packages I built are still in my personal repo.
log in > platforms choose the platform ( mandian_personal), in right corner choose main (or other)
click on the cross you want
It is all OK now.
Thank you for all your patience.
Command failed:
# [‘/usr/sbin/urpmi.addmedia’, ‘–xml-info=never’, ‘–urpmi-root’, ‘/var/lib/mock-urpm/openmandriva-x86_64/root/’, ‘luca_personal_main_release’, ‘http://abf-downloads.openmandriva.org/luca_personal/repository/3.0/x86_64/main/release’]
adding medium “luca_personal_main_release”
…retrieving failed: curl failed: exited with 22
Hi,
I’ve got an error building a project in my personal repo.
http://abf-downloads.openmandriva.org/luca_personal/repository/3.0 is missing.
Who can create it?
Thanks in advance.
question waiting on IRC. I hope an answer
@jojodu34 thanks
It’s easier they respond to you than to me
I had no problem to build in http://abf-downloads.openmandriva.org/luca_personal/repository/cooker
[16:55] <\HisShadow_> joel_tess_: yeah, I’ll fix it, gotta create it manually
thank you very much!
Hi,
I’ve still some problems with ABF. The first is an error at publishing stage. I succeeded to publish some packages on y personal repo but all them cause a ‘Publishing error’ on ABF I can’t understand what it refers to. I dont’n know if it is because all my packages are not signed but I can’t find the way to make it.
Also I would like to compile a package which depends on one or more packages in my personal repo. Is there a way to do this (maybe i should add an extra repositories before to start the build)?
Finally I wonder if the option ‘Use cached chroot’ in the Build panel may speed up the build of a package. Or it may be unsafe?
seems the same problem:
http://ml.openmandriva.org/pipermail/om-cooker_ml.openmandriva.org/2016-July/001557.html
I’ve solved deleting the existing synthesis.hdlist.cz
So I.
Thank you.
btw I some problem to compile a package for the 2014.0. Has that version already been deprecated?
I don’t think, updates are still arriving in repos.
I don’t see openmandriva2014.0 branch on my personal repo. You have it.
yes, I have it as target platform
It is like rpmbuild can’t fetch sources from remote in 2014.0.
