CLI Issue with Open Mandriva on Almost all my Computers
OpenMandriva ROME 25.11
KDE
When I turned three out of four of my Open Mandriva computers, it just brings me to CLI. After logging in and doing startx, I get back into my normal user space, however, KDE wallet and wifi needed a new password input to work. This has only started happening recently, especially after I upgraded them after realizing that the auto-update config has not been working for months.
Kernel Version: 6.15.0-desktop-0.rc2.3omv2590 (64-bit)
`sudo systemctl enable sddm`
`sudo systemctl start sddm`
Reboot and see if that fixes it. The wallet thing should have been a onetime occurrence because of the switch from Xorg to xlibre.
It worked beautifully! No Kwallet issues anymore either, even though that issue was happening with each reboot previously. This has fixed every single one of my computers. Thanks so much for your help!
Unfortunately, on one of my computers, it is constantly logging me out to the SDDM screen and then I have to log back in, only for it log me back out to SDDM a few minutes later. The only way to stop it is to run sudo systemctl disable sddm. However, I would like to have SDDM enabled.
