Trying the alternative dkms-long-lived and nvidia related,
1 installation failed
there has been a problem during installation:
file /etc/ld.so.conf.d/GL.conf from installation of x11-driver-video-nvidia-long-lived-340.58-1.x86_64 conflicts with the file of package x11-server-common-1.18.4-2.x86_64
Yes, nVidia Optimus, but it works pretty well with OMV 2013, 2014.0, 2014.1, and 2014.2! I guess it will work with lx 3.0 as well as soon as I can install nvidia drivers.
Raphael, sad to here you can’t install 3.0. Is this a proprietary driver problem? Right now as a group our support for proprietary drivers seems weak (being polite). I don’t understand when we have missing dependencies reported for days or weeks that can’t be fixed.
As a complement, a fedora 24 user told me that its rpms for nvidia were not installed (there is no libGLdispatch as well) and, for proprietaty driver use he had to use the nvidia installer.
So far, I could not install the new nvidia packages via MCC. I select dkms, nvidia cuda toolkit and nvidia cuda tookit devel (I need them) and all required dependencies. Then, when I apply, the window “Distribution Upgrade” pop up fully black, no download or installation information, and after a while this window vanish.
Don’t know yet if the cause is some internet connection problem here.
Tried command line (urpmi …) and the download seems too slow or not working. The following line is seen but nothing happens:
Unfortunatelly, after rebooting sddm does not start and the system hangs out.
I had no graphical support.
It is really weird in this case because this laptop has its primary graphical support on intel graphical card.
I need nvidia support just to run some gpu demanding executables with the help of bumblebee.
It used to work properly at OMV 2014 but does not seems to work with OMV LX 3.0.
After uninstall of nvidia, dkms-nvidia, and its dependecies, the system started with sddm.
It can be similar. Don’t know if it has the same root. However, it seems to differ because here the basic graphical support is provided by the intel graphic card. NVidia is just another, more powerful, graphic card with GPU capabilities.
