4.1 Rock Zen -
KDE -
I’m attempting to compile a program using system libs. I get an error message that BerkeleyDB is not found. I’m unsure what libraries should be installed, if there are any available. This is the code:
# -*- cmake -*-
# - Find BerkeleyDB
# Find the BerkeleyDB includes and library
# This module defines
# DB_INCLUDE_DIR, where to find db.h, etc.
# DB_LIBRARIES, the libraries needed to use BerkeleyDB.
# DB_FOUND, If false, do not try to use BerkeleyDB.
# also defined, but not for general use are
# DB_LIBRARY, where to find the BerkeleyDB library.
FIND_PATH(DB_INCLUDE_DIR db.h
/usr/local/include/db4
/usr/local/include
/usr/include/db4
/usr/include
SET(DB_NAMES ${DB_NAMES} db)
FIND_LIBRARY(DB_LIBRARY
NAMES ${DB_NAMES}
PATHS /usr/lib /usr/local/lib
IF (DB_LIBRARY AND DB_INCLUDE_DIR)
SET(DB_LIBRARIES ${DB_LIBRARY})
SET(DB_FOUND "YES")
ELSE (DB_LIBRARY AND DB_INCLUDE_DIR)
SET(DB_FOUND "NO")
ENDIF (DB_LIBRARY AND DB_INCLUDE_DIR)
IF (DB_FOUND)
IF (NOT DB_FIND_QUIETLY)
MESSAGE(STATUS "Found BerkeleyDB: ${DB_LIBRARIES}")
ENDIF (NOT DB_FIND_QUIETLY)
ELSE (DB_FOUND)
IF (DB_FIND_REQUIRED)
MESSAGE(FATAL_ERROR "Could not find BerkeleyDB library")
ENDIF (DB_FIND_REQUIRED)
ENDIF (DB_FOUND)
# Deprecated declarations.
SET (NATIVE_DB_INCLUDE_PATH ${DB_INCLUDE_DIR} )
GET_FILENAME_COMPONENT (NATIVE_DB_LIB_PATH ${DB_LIBRARY} PATH)
MARK_AS_ADVANCED(
DB_LIBRARY
DB_INCLUDE_DIR
And here is a snippet of the terminal:
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Check for working C compiler: /usr/bin/gcc-9.2.1
-- Check for working C compiler: /usr/bin/gcc-9.2.1 -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/g++-9.2.1
-- Check for working CXX compiler: /usr/bin/g++-9.2.1 -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- GCC version (dots removed): 921
-- Version of viewer is 1.28.0.9
CMake Error at cmake/FindBerkeleyDB.cmake:39 (MESSAGE):
Call Stack (most recent call first):
cmake/BerkeleyDB.cmake:16 (include)
cmake/APR.cmake:7 (include)
cmake/LLCommon.cmake:7 (include)
llappearance/CMakeLists.txt:6 (include)
-- Configuring incomplete, errors occurred!
Any ideas?
