Able to log into failsafe, but not desktop
OpenMandriva Lx release 25.11 (ROME) Rolling for x86_64
KDE Plasma 6
Unable to login to Wayland desktop
ASUS K55A laptop for the hardware.
I installed the latest updates via Dnfdrake after receiving a notification. I then walked away. Some time later, I came back, expecting the screen to be locked as it always is, but it wasn’t. I closed Dnfdrake, as it had finished. Then I tried to do a Super-L to lock the screen, and the keyboard shortcut failed. I then went into System Settings to see if the keyboard shortcuts got messed up, and under ‘Input & Output’ the keyboard shortcuts were gone. There was not even an item listed inside the left-side index.
This has happened before, and I was always able to get everything back with a simple reboot and login. Only this time, I am not able to login to the Wayland desktop at the SDDM screen. But I am able to go into failsafe and get a very small terminal box in the left corner of the now otherwise black display.
When I tried to login to the Wayland desktop at the SDDM screen, the screen would go to black for a few seconds, and then I would be returned to the SDDM screen.
I was able to pull the attached log using 'journalctl -b > /media/shares/test_folder/bootlog.txt and then copy it to this computer over the lan, seeing as I still had network connectivity.
If this is the wrong boot log file, let me know where to find the correct one and how to retrieve it.
bootlog.txt (472.5 KB)
Make sure your upgrade was successful. Run in failsafe session distro-sync command
sudo dnf distro-sync --refresh
Reboot after that and try again.
Did that. Updated and loaded every repository. Then I was informed there was nothing to do.
No change. Still unable to login to the desktop. But failsafe still works. It replies with, “Nothing to do” when I do a sudo dnf distro-sync --refresh from the failsafe terminal.
Can you try solution from this post: Upgrading ROME(rolling) after Nov. 9, 2025 upgrade
Tried everything in that post. Everything worked until I came to this:
$ rpm -qa | grep sddm
sddm-0.21.0-11.znver1
sddm-theme-breeze-6.5.2-1.znver1
sddm-kcm-6.5.2-1.znver1
My result:
sddm-0.21.0-11.x86_64
sddm-theme-breeze-6.5.2-1.x86_64
sddm-kcm-6.5.2-1.x86_64
This is an old ASUS laptop from 2012. Definitely not a Zen laptop. I suspect that is why I get a different result.
Bottom line: No change. Still can’t login to the desktop. Only the failsafe terminal.
My impression from reading what I could from the log file, one or more Plasma desktop files are corrupted.
Is there a way to reinstall Plasma desktop, forcing an update of all related files?
If you know what package is corrupted try sudo dnf reinstall package_name
if not, somethings like this can work/or/not
sudo dnf reinstall plasma* --skip-unavailable
sudo dnf reinstall kf6* --skip-unavailable
etc.
In extreme cases, you can reinstall all packages installed on your system, but this may take some time
sudo dnf reinstall \* --skip-broken
None of that worked, including:
can you provide the output of these commands:
rpm -qa|grep plasma
rpm -qa|grep KF6
rpm -qa|grep kwin
rpm -qa|grep sddm
Here is the output of each command:
KF6_log.txt (3.0 KB)
kwin_log.txt (253 Bytes)
plasma_log.txt (706 Bytes)
sddm_log.txt (79 Bytes)
Looks like there is mix of plasma5 bits and plasma6. While plasma6 installation is not fully covered.
Try installing
sudo dnf install task-plasma6 task-plasma6-minimal task-plasma6-wayland
if package is installed remove it with
sudo rpm -e –nodeps task-plasma6
sudo rpm -e –nodeps task-plasma6-minimal
sudo rpm -e –nodeps task-plasma6-wayland
and then install again with
I suspect there may be package conflicts with the p5 version. But let’s try; at most, you can remove the conflicting packages from p5.
That line fixed it after I rebooted. The desktop is back, fully intact. Thank you very much. I have no idea how you figured it out. Five-star solution that works.
I have no idea how Plasma 5 parts got in there. When I installed OpenMandriva Rome back in February, I installed Plasma 6.
plasma5 is sneaky
:disguised_face:
