Hyprland 0.48.1
When I try to open any pdf file with zathura, it does not open, the output in the terminal is as follows:
error: could not open plugin directory: /usr/lib64/zathura
error: Found no plugins. Please install at least one plugin.
error: Could not determine file type.
When I try to search for other zathura packages in the repos nothing comes up except the app.
❯ meson build
The Meson build system
Version: 1.7.2
Source dir: /home/humam/.applications/zathura-pdf-poppler
Build dir: /home/humam/.applications/zathura-pdf-poppler/build
Build type: native build
Project name: zathura-pdf-poppler
Project version: 0.3.3
C compiler for the host machine: cc (clang 19.1.7-1 "OpenMandriva 19.1.7-1 clang version 19.1.7 (/builddir/build/BUILD/llvm-19.1.7-build/llvm-project-llvmorg-19.1.7/clang f6577d7ceed75def4c4c7db30fa2d30a053fc852)")
C linker for the host machine: cc ld.lld 19.1.7-1
Host machine cpu family: x86_64
Host machine cpu: x86_64
Found pkg-config: YES (/sbin/pkg-config) 2.1.1
Dependency zathura found: NO. Found 0.5.2 but need: '>=0.5.3'
Found CMake: /sbin/cmake (4.0.1)
Run-time dependency zathura found: NO (tried pkgconfig and cmake)
Looking for a fallback subproject for the dependency zathura
Cloning into 'zathura'...
fatal: unable to access 'https://git.pwmt.org/pwmt/zathura.git/': Could not resolve host: git.pwmt.org
ERROR: Subproject zathura is buildable: NO
meson.build:18:10: ERROR: Git command failed: ['/sbin/git', 'clone', 'https://git.pwmt.org/pwmt/zathura.git', 'zathura']
even though zathura is installed on my system. should i just build both from source?
that error is saying that your version of zathura is too old. Go ahead and make a package request for the plugin and someone should notice the outdated zathura package too.
