Yes I have dkms-broadcom-wl and dkms-broadcom-wl-common installed. And I tried again the dkms installation. Which errors out:
I tried:
$ sudo dkms autoinstall
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' -j12 -C /lib/modules/6.13.0-desktop-0.rc5.1omv2490/build M=/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.13.0-desktop-0.rc5.1omv2490 (x86_64)
Consult /var/lib/dkms/dkms-broadcom-wl/6.30.223.271-5/build/make.log for more information.
And then dkms build:
$ sudo /usr/sbin/dkms --rpm_safe_upgrade build -m dkms-broadcom-wl -v 6.30.223.271-5 --kernelsourcedir /usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/
Preparing kernel 6.13.0-desktop-0.rc5.1omv2490 for module build:
(This is not compiling a kernel, just preparing kernel symbols)
/usr/sbin/dkms: line 1222: warning: command substitution: ignored null byte in input
Storing current .config to be restored when complete
Running Generic preparation routine
make mrproper.....
using /proc/config.gz
make oldconfig....(bad exit status: 2)
make prepare...(bad exit status: 2)
Building module:
'make' -j12 -C /usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/ M=/home/mario...(bad exit status: 2)
And this is the make.log:
DKMS make.log for dkms-broadcom-wl-6.30.223.271-5 for kernel 6.13.0-desktop-0.rc5.1omv2490 (x86_64)
Tue Jan 14 02:16:29 PM CET 2025
make: Entering directory '/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490'
make[1]: Entering directory '/home/mario'
/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/Makefile:777: /usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/include/config/auto.conf: No such file or directory
make[1]: *** [/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/Makefile:251: __sub-make] Error 2
make[1]: Leaving directory '/home/mario'
make: *** [Makefile:251: __sub-make] Error 2
make: Leaving directory '/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490'
So i tried autoconfig in/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490
$ sudo make autoconfig
make[2]: *** No rule to make target 'autoconfig'. Stop.
make[1]: *** [/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/Makefile:733: autoconfig] Error 2
Then I tried
$ sudo make mrproper
CLEAN scripts/basic
CLEAN scripts/kconfig
CLEAN .config
$ sudo make oldconfig V=1 ARCH=x86
make --no-print-directory -C /usr/src/linux-6.13.0-desktop-0.rc5.1omv2490 \
-f /usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/Makefile oldconfig
make -f ./scripts/Makefile.build obj=scripts/basic
# HOSTCC scripts/basic/fixdep
gcc -Wp,-MMD,scripts/basic/.fixdep.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -o scripts/basic/fixdep scripts/basic/fixdep.c
make -f ./scripts/Makefile.build obj=scripts/kconfig oldconfig
# HOSTCC scripts/kconfig/conf.o
gcc -Wp,-MMD,scripts/kconfig/.conf.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/conf.o scripts/kconfig/conf.c
# HOSTCC scripts/kconfig/confdata.o
gcc -Wp,-MMD,scripts/kconfig/.confdata.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/confdata.o scripts/kconfig/confdata.c
# HOSTCC scripts/kconfig/expr.o
gcc -Wp,-MMD,scripts/kconfig/.expr.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/expr.o scripts/kconfig/expr.c
# LEX scripts/kconfig/lexer.lex.c
flex -oscripts/kconfig/lexer.lex.c -L scripts/kconfig/lexer.l
# YACC scripts/kconfig/parser.tab.[ch]
bison -o scripts/kconfig/parser.tab.c --defines=scripts/kconfig/parser.tab.h -t -l scripts/kconfig/parser.y
# HOSTCC scripts/kconfig/lexer.lex.o
gcc -Wp,-MMD,scripts/kconfig/.lexer.lex.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -I ./scripts/kconfig -c -o scripts/kconfig/lexer.lex.o scripts/kconfig/lexer.lex.c
# HOSTCC scripts/kconfig/menu.o
gcc -Wp,-MMD,scripts/kconfig/.menu.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/menu.o scripts/kconfig/menu.c
# HOSTCC scripts/kconfig/parser.tab.o
gcc -Wp,-MMD,scripts/kconfig/.parser.tab.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -I ./scripts/kconfig -c -o scripts/kconfig/parser.tab.o scripts/kconfig/parser.tab.c
# HOSTCC scripts/kconfig/preprocess.o
gcc -Wp,-MMD,scripts/kconfig/.preprocess.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/preprocess.o scripts/kconfig/preprocess.c
# HOSTCC scripts/kconfig/symbol.o
gcc -Wp,-MMD,scripts/kconfig/.symbol.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/symbol.o scripts/kconfig/symbol.c
# HOSTCC scripts/kconfig/util.o
gcc -Wp,-MMD,scripts/kconfig/.util.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -std=gnu11 -I ./scripts/include -c -o scripts/kconfig/util.o scripts/kconfig/util.c
# HOSTLD scripts/kconfig/conf
gcc -o scripts/kconfig/conf scripts/kconfig/conf.o scripts/kconfig/confdata.o scripts/kconfig/expr.o scripts/kconfig/lexer.lex.o scripts/kconfig/menu.o scripts/kconfig/parser.tab.o scripts/kconfig/preprocess.o scripts/kconfig/symbol.o scripts/kconfig/util.o
scripts/kconfig/conf --oldconfig Kconfig
crypto/Kconfig:1458: can't open file "arch/mips/crypto/Kconfig"
make[2]: *** [scripts/kconfig/Makefile:85: oldconfig] Error 1
make[1]: *** [/usr/src/linux-6.13.0-desktop-0.rc5.1omv2490/Makefile:733: oldconfig] Error 2
And I don’t know why it wants mipse here crypto/Kconfig:1458: can't open file "arch/mips/crypto/Kconfig" or how to change that. I don’t know what to here…
Any help would be appreciated!
Here is my system, if that helps:
System:
Host: mario-mac-openmandriva Kernel: 6.13.0-desktop-0.rc5.1omv2490
arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.2.4 Distro: OpenMandriva Lx 24.12 ROME
Machine:
Type: Laptop System: Apple product: Macmini8,1 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-7BA5B2DFE22DDD8C v: Macmini8,1
serial: <superuser required> UEFI: Apple v: 2069.40.2.0.0 (iBridge:
22.16.12093.0.0,0) date: 11/13/2024
CPU:
Info: 6-core model: Intel Core i7-8700B bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 800 min/max: 800/4600 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Graphics:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Display: x11 server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4 driver:
X: loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
resolution: 2560x1440
API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.2
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
API: Vulkan v: 1.4.303 drivers: N/A surfaces: xcb,xlib
Audio:
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: Apple Audio driver: N/A
API: ALSA v: k6.13.0-desktop-0.rc5.1omv2490 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active
Network:
Device-1: Broadcom BCM4364 802.11ac Wireless Network Adapter driver: N/A
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
IF: enp4s0 state: down mac: f4:34:f0:e3:17:3b
Device-3: MediaTek MT7612U 802.11a/b/g/n/ac Wireless Adapter
driver: mt76x2u type: USB
IF: wlp0s20f0u4 state: up mac: 00:c0:ca:b0:63:39
Device-4: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
IF: enp0s20f0u5u3u1 state: down mac: 00:0e:c6:de:38:69
IF-ID-1: wt0 state: unknown speed: N/A duplex: N/A mac: N/A
Drives:
Local Storage: total: 113 GiB used: 31.36 GiB (27.7%)
ID-1: /dev/nvme0n1 vendor: Apple model: SSD AP0128M size: 113 GiB
Partition:
ID-1: / size: 40.71 GiB used: 31.34 GiB (77.0%) fs: btrfs
dev: /dev/nvme0n1p5
ID-2: /boot size: 40.71 GiB used: 31.34 GiB (77.0%) fs: btrfs
dev: /dev/nvme0n1p5
ID-3: /boot/efi size: 299.3 MiB used: 11.8 MiB (3.9%) fs: vfat
dev: /dev/nvme0n1p1
ID-4: /home size: 40.71 GiB used: 31.34 GiB (77.0%) fs: btrfs
dev: /dev/nvme0n1p5
ID-5: /var/log size: 40.71 GiB used: 31.34 GiB (77.0%) fs: btrfs
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: zram size: 8 GiB used: 34.2 MiB (0.4%) dev: /dev/zram0
ID-2: swap-2 type: partition size: 2 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
Sensors:
System Temperatures: cpu: 54.0 C pch: 63.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 32 GiB available: 31.21 GiB used: 5.81 GiB (18.6%)
Processes: 341 Uptime: 4h 32m Shell: Bash inxi: 3.3.36
