Wi-Fi issue
I updated OM with February 2026 upgrades and frequently Wi-fi diisconnects, often with this
asking for the correct password. But the latter is correctly saved.
Spontaneously, Wi-Fi reconnects, then after a while, disconnects again. An so on.
Nothing similar happened with the previous release.
Hi! I had this issue on Fedora 43 KDE Plasma 6 and OpenMandriva Cooker xLibre Plasma 6. I have three different wifi USB sticks adapters, and only one of them consistently reproduces this issue. This might be “KDE vs. Hardware” issue, since OpenMandriva Cooker is pretty distant from Fedora 43.
Does this help per se? Probably not. But if you can get another wifi adapter, you can test it and issue may resolve itself. Linux in general is notoriously laborous in terms of hardware troubleshooting, the key price we pay consistently for decades.
Please select more carefully the proper forum category.
Moving topic to Support
Postedit:
Done.
Now you are required to provide the informations in the Support template you would have found if you had chosen the right category. :slight_smile:
Sorry, I thought I’id put it unto the support category; it was a mistake of mine..
Se hai il bluetooth integrato insieme alla scheda wifi prova a disattivarlo
:backhand_index_pointing_up:
I’m outside for holidays. Cannot afford PC.
