On boot, after selecting the live option, the process stops with a fatal error message regarding
Spectre V2: WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
I also got this warning when I checked out OpenMandriva for the first time today.
This causes programs to crash, in my case sddm borked
kernel: traps: sddm[1053] trap invalid opcode ip:7f6b0a398d65 sp:7fffa8bbc850 error:0
To fix this you have to edit your kernel command in grub by adding ‘mitigations=off’
(rugyada)
July 23, 2024, 8:30pm
2
@rbekken Welcome
Download from SouceForge?
Which ISO image please?
Thank you for the workaround. We’ll have to investigate further.
I tried the following ISO’s
SouceForge
e2c677ac34e9abe5904d5a2045fe2b4e7598fcfeb33904df41b25a47de7e5189 openmandriva.rome-24.07-plasma6.x11.x86_64.iso
abf (dot) openmandriva (dot) org/platforms/rolling/products/175/product_build_lists/3255
c765b5454fbc9bc8a2c49a7b40823e447447b67ef0ac7e4b88284b543fd5c258 OpenMandrivaLx.rolling-slim-plasma6x11.x86_64.iso
Motherboard DMI: ASUS System Product Name/ROG MAXIMUS XI HERO (WI-FI), BIOS 2004 11/02/2021
CPU: i9-9900KS
dmesg.txt (99.0 KB)
journalctl.txt (145.4 KB)
That option is also available in grub menu. No need to edit anything, just selecting entry.
Indeed that looks like sddm crash
ben79
(Ben Bullard)
July 24, 2024, 2:59am
6
rbekken:
Look like I was wrong about this in post #4 . We are looking in to this issue.
ben79
(Ben Bullard)
August 24, 2024, 1:34pm
7
@rbekken This needs a bug report from someone that has this issue. The issue is why some security patches like Spectre/Meltdown and others trigger this invalid opcode in OMLx systems?
mitigations=off is a boot parameter but systems with this issue are booting the problem is sddm fails and that should not be happening. At least my user level knowledge thinks it shouldn’t.
system
(system)
Closed
September 23, 2024, 1:38pm
8
