Hanisch
(Ch. Hanisch)
August 31, 2019, 7:30am
1
_OpenMandriva Lx version: _LX 4.0
Desktop environment (KDE, LXQT…): KDE, LXQT
I have installed the OpenMandriva LX 4.0 via Calamares from the ‘OpenMandrivaLx.4.0-plasma.x86_64.iso’.
After that I have had:
$ dnf repolist --all|grep enabled
OpenMandriva Cooker - Unsupported - x86_64 7.8 kB/s | 1.5 kB 00:00
OpenMandriva Cooker - Unsupported - x86_64 4.6 MB/s | 4.9 MB 00:01
OpenMandriva Cooker - Restricted - x86_64 8.4 kB/s | 1.5 kB 00:00
OpenMandriva Cooker - Non-free - x86_64 8.5 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 8.1 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 - Updates 8.9 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 5.3 MB/s | 11 MB 00:02
OpenMandriva Rock - Unsupported - x86_64 - Upda 602 kB/s | 248 kB 00:00
OpenMandriva Rock - Restricted - x86_64 411 kB/s | 140 kB 00:00
OpenMandriva Rock - Restricted - x86_64 - Updat 1.3 kB/s | 344 B 00:00
OpenMandriva Rock - Non-free - x86_64 502 kB/s | 161 kB 00:00
OpenMandriva Rock - Non-free - x86_64 - Updates 46 kB/s | 11 kB 00:00
It’s recommended “Do not mix update channels/releases or you will have problems. ”
Show DISTRO FAQ - Wiki [en] OpenMandriva
What is the reason for mixing Cooker and Rock repositories in a new Installation?
with regards
Ch. Hanisch
Hanisch
(Ch. Hanisch)
August 31, 2019, 9:35am
3
You did it.
No, it is from Calamares.
with regards
Ch. Hanisch
(rugyada)
August 31, 2019, 9:41am
4
This is the ISO in live mode
I don’t see any cooker repo, nor unsupported, restricted or non-free either, so it means you did it.
Hanisch
(Ch. Hanisch)
August 31, 2019, 12:01pm
5
maybe I have unauthorized action appropriated in repo-picker.
I have set in
OM Control Center -> OpenMandriva repo-picker -> Rock and Release
$ dnf repolist
Letzte Prüfung auf abgelaufene Metadaten: vor 0:23:37 am Sa 31 Aug 2019 13:25:40 CEST.
Paketquellen-ID Paketquellen-Name: Status
cooker-x86_64 OpenMandriva Cooker - x86_64 14.971
google-earth-pro google-earth-pro 2
rock-updates-x86_64 OpenMandriva Rock - x86_64 - Updates 476
rock-updates-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 - Updates 12
rock-updates-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 - Updates 0
rock-updates-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 - Updates 57
rock-x86_64 OpenMandriva Rock - x86_64 15.662
rock-x86_64-non-free OpenMandriva Rock - Non-free - x86_64 155
rock-x86_64-restricted OpenMandriva Rock - Restricted - x86_64 164
rock-x86_64-unsupported OpenMandriva Rock - Unsupported - x86_64 13.281
$ sudo dnf --refresh distro-sync
google-earth-pro 17 kB/s | 1.3 kB 00:00
OpenMandriva Cooker - x86_64 6.3 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 8.9 kB/s | 1.5 kB 00:00
OpenMandriva Rock - x86_64 - Updates 7.9 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 7.5 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Unsupported - x86_64 - Updates 8.3 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 8.0 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Restricted - x86_64 - Updates 8.2 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 9.1 kB/s | 1.5 kB 00:00
OpenMandriva Rock - Non-free - x86_64 - Updates 9.0 kB/s | 1.5 kB 00:00
Abhängigkeiten sind aufgelöst.
Nichts zu tun.
It’s OK now?
with regards
Ch. Hanisch
Hanisch
(Ch. Hanisch)
August 31, 2019, 2:47pm
6
I have a problem with the line:
I think it is not right, therefore I have set ‘enabled=0’ in /etc/yum.repos.d/openmandriva-cooker-x86_64.repo
Now
$ dnf repolist
Letzte Prüfung auf abgelaufene Metadaten: vor 0:11:38 am Sa 31 Aug 2019 16:30:20 CEST.
Is that the system, what I will?
But with this settings ‘skypeforlinux’ don’t run.
How can I in
OM Control Center -> OpenMandriva repo-picker -> set the only ROCK Repositories?
with regards
Ch. Hanisch
ben79
(Ben Bullard)
August 31, 2019, 4:48pm
7
I can look in the ISO build script and confirm that what @rugyada says above is absolutely 100% true. A default install of OM Lx 4.0 has enabled 2 and only 2 repositories rock-x86_64 and rock-updates-x86_64. Also after having done 40-50 installs during testing this is what I saw on every single install I have done.
If @Hanisch or anyone else somehow has an ISO doing anything else it should be destroyed and never used. Download the correct ISO and don’t ever mix repositories from different releases.
(rugyada)
August 31, 2019, 5:51pm
8
Q: How to start repo-picker?
A: From application menu
