For a compilation I want to use gcc and not clang but I did not find where to change the default compiler.
export CC=/usr/bin/gcc;export CXX=/usr/bin/g++;
doesn’t work as I want
Usually export CC=gcc;export CXX=g++ should do the trick – all the build related macros (%configure, %cmake, etc.) check for CC and CXX variables.
Note that %prep, %build and %install are run in separate scripts, so if you export CC=gcc in %prep, it’s NOT still set in %build.
Also, some makefiles are simply broken and hardcode “cc” or so as the name of the C compiler.
If this doesn’t help, please post some context so we can take a look.
