25.06 (ROME) Rolling for x86_64
KDE Plasma 6.3.4 (X11)
Description of the issue:
Titanium (app development framework) fails with [ERROR] 32-bit glibc library is not installed during the app build process for Android emulation. I’ve been trying to install the library from several packages but unsuccessful.
I’m pretty clueless on how to get it so some help would be greatly appreciated, thanks.
If we don’t have the 32 bit library (which it doesn’t seem we do), are you able to use a flatpak or appimage? I don’t think 32 bit glibc is even needed for Steam, and that is what we primarily have 32 libraries for.
After poking around in Titanium’s source code looking for what’s causing the error, I think I found the issue. It’s trying to find the glibc.x86_64 package but the RegExp patterns below are wrong so it always returns null which is falsy, triggering the error.
Hardcoding the boolean to true or fixing the patterns allows the emulator to launch with zero issues.
if (/^glibc-/.test(line)) {
if (/\.i[36]86$/.test(line)) {
result.glibc = true;
} else if (result.glibc !== true) {
result.glibc = false;
It seems I resolved the issue myself lmao. My apologies for opening this ticket, I was stomped for a good while there until the last-ditch idea of fiddling with the source code came up. Luckily it paid off.
