OMV LX 3.0
Some clamav files, required for a broader clamav operation, are not open source. Are they restricted? Are they available somewhere?
Thanks
OMV LX 3.0
Thanks
Like which ones ?
Well,
Since I cannot be technical about this (donât know much about) I will summarize as follows:
To be effective, Clamav requires lots of viruses, worms, âŚ,âvaccineâ files where virus and other malicious softwares are described.
Without this files, clamav cannot be that efficient . The problem is that these files are not free/openâŚ
Are you referring to the ClamAV virus database?
Yes. The clamav database. I once receive a message about some files not being free. Then the clamav database is typically made of the free ones only.
I was googling around searching for references on this and could not find. Hope Iâm not caughting your attention and time with âfake newsâ âŚ
Itâs the first time I heard about this. However AFAIK usually clam updates its database by itself and puts it into some path into /var (maybe /var/cache/clam or something similar) so the database is not provided by the package.
Postedit1: maybe the database is into /var/lib/clamav.
Postedit2: about the virus databases after a short search it is like the official database is free but there exist some other âunofficialâ third-party databases may be not fully free.
I would suggest to contact Clamav directly and ask them. Otherwise also an Internet search (âGoogleâ) might find something.
Please post here if you do find something.
Note: REAL Linux users donât use Google.
